dafivehole Posted August 18, 2013 Share Posted August 18, 2013 (edited) RESET works fine when running the self test but the others don't (so I can't really start the self test). Is this an easy fix? All other keys work just fine. Thanks, Roger Another 130XE question: should the little slit light on the lower left corner of the keyboard be red? Edited August 18, 2013 by dafivehole Quote Link to comment Share on other sites More sharing options...
Roydea6 Posted August 18, 2013 Share Posted August 18, 2013 (edited) The LED is Mono color so if the factory put a red led then the light should be red, but can be changed for any other color led you would like.. Edited August 18, 2013 by rdea6 Quote Link to comment Share on other sites More sharing options...
dafivehole Posted August 18, 2013 Author Share Posted August 18, 2013 Thank you. I opened 'er up and saw the red plastic piece over the LED Oddly enough, after I blew off the dust and put the case back together, everything works fine now! Roger Quote Link to comment Share on other sites More sharing options...
flashjazzcat Posted August 18, 2013 Share Posted August 18, 2013 Only certain XE models had the colourless light conductors (notably the 800XE) - all the others I've seen were red. Quote Link to comment Share on other sites More sharing options...
