morelenmir Posted August 23, 2013 Share Posted August 23, 2013 I have found three different circuit diagrams for a USB SIO2PC device on the internet. There are probably more to find. The oldest seem to date to around 1996-1997, so the components might be hard to get hold of now. I wondered if any of you chaps could recommend a specific build, preferably with modern parts? Quote Link to comment Share on other sites More sharing options...
adam242 Posted August 23, 2013 Share Posted August 23, 2013 I've been using Nick Kennedy's one-chip design for years with no problems. SIO2PC.BMP There are newer, more compact designs but this one has worked well for me. Quote Link to comment Share on other sites More sharing options...
kogden Posted August 24, 2013 Share Posted August 24, 2013 (edited) https://www.sparkfun.com/products/718 That's a USB->TTL serial breakout board based on FTDI FT232RL chip. Just buy one of those and get an SIO connector or butcher an SIO cable. $15. Single chip solution that's incredibly reliable. Just need to wire up rx, tx, gnd, and wire SIO command pin to RI. This is the easiest DIY solution I've ever seen. I even got bored and installed one internally in one of my machines. Edited August 24, 2013 by kogden Quote Link to comment Share on other sites More sharing options...
morelenmir Posted August 24, 2013 Author Share Posted August 24, 2013 Many thanks chaps - I may give both a try!!! I like the idea of installing it inside the 800XL case. Very cool and no need to butcher a USB cable. I think I have several SIO leads I could cannibalize and I have certainly seen several of the guys here selling their own plugs. I don't suppose you could suggest a UK, or at least Euro source? Quote Link to comment Share on other sites More sharing options...
adam242 Posted August 24, 2013 Share Posted August 24, 2013 https://www.sparkfun.com/products/718 That's a USB->TTL serial breakout board based on FTDI FT232RL chip. Just buy one of those and get an SIO connector or butcher an SIO cable. $15. Single chip solution that's incredibly reliable. Just need to wire up rx, tx, gnd, and wire SIO command pin to RI. This is the easiest DIY solution I've ever seen. I even got bored and installed one internally in one of my machines. Now that is cool! I may have to try that one. Quote Link to comment Share on other sites More sharing options...
