Wally1 Posted September 22, 2013 Share Posted September 22, 2013 I am trying to print from Atariwriter with my Panasonic 1150 printer. I am also using the MPP-1150 printer interface. I select printer option '4' from the print menu (Atari 822) but the printer keeps printing over the same line, without carriage returns. what can I do? thanks Quote Link to comment Share on other sites More sharing options...
flashjazzcat Posted September 22, 2013 Share Posted September 22, 2013 You need to get the interface to send line feeds to the printer. On the P:R: Connection, there's a jumper for this. Not sure about the MPP-1150. It could also be done via software (by explicitly sending the CR/LF sequence from the word processor). Quote Link to comment Share on other sites More sharing options...
Wally1 Posted September 22, 2013 Author Share Posted September 22, 2013 (edited) I figured out that CTRL-J is a line feed and it works. but do i have end every line with a ctrl-j? and i cant insert them in an Atariwriter document. Edited September 22, 2013 by Wally1 Quote Link to comment Share on other sites More sharing options...
HiassofT Posted September 22, 2013 Share Posted September 22, 2013 According to the user manual you can enable "Auto LF" using the panel buttons (see page 27/28 of the manual for details). Most of the old printers have such a feature, usually on a dip-switch block, your panasonic printer seems to be somewhat newer and use an eeprom for that BTW: in general it's better to enable auto-lf in the printer than in the interface. When printing graphics converting 155 to 13,10 would totally mess up the output, converting 155 to 13 only shows up as a slight distortion in the graphics. so long, Hias Quote Link to comment Share on other sites More sharing options...
UNIXcoffee928 Posted September 22, 2013 Share Posted September 22, 2013 (edited) The Panasonic 1080 & 1091 had a DIP-switch (inside the printer) that was to be manually set (by the user) to fix this. Check your Panasonic manual for the DIP-switch settings, to correct the problem. It's been about 30 years, but I think that it was the last switch in the bank, for those two models. edit: oh, looks like Hias answered it as I was typing. Edited September 22, 2013 by UNIXcoffee928 Quote Link to comment Share on other sites More sharing options...
Wally1 Posted September 22, 2013 Author Share Posted September 22, 2013 big thanks to both you guys Quote Link to comment Share on other sites More sharing options...
BillC Posted September 22, 2013 Share Posted September 22, 2013 The setup disk for the 1150 is still available as well: http://panasonic.net/pcc/products/printer/download/p1150download.html Quote Link to comment Share on other sites More sharing options...
