ballyalley Posted September 23, 2013 Share Posted September 23, 2013 I have the Gamebase A800, but my download either lost or never had the gemus.dat file for setup. I want to use the latest version of Altirra (currently 2.3). I'm hoping that a .dat file for this already exists. Anyone have one? Thanks. Quote Link to comment Share on other sites More sharing options...
eeun Posted September 23, 2013 Share Posted September 23, 2013 I don't seem to have a gemus.dat file in my gamebase setup, but it works just fine. For Altirra, in my Gamebase \ Atari 800 folder, there's a file called emulators.ini, and that's where you set the emulator prefs. For Altirra, my entry is listed as below as an example: [Altirra] UseShortFilenames=0 UseDefaultTypes=0 SupportedTypes=atr;xex;bin;rom;com;cas;atx;pro;xfd;dcm;bas; EmulatorPathFile=D:\Emulation\GameBase\Atari 800\Emulators\Altirra-2.10\Altirra.exe ScriptFile=Altirra 22.txt WaitFinish=1 1= Quote Link to comment Share on other sites More sharing options...
ballyalley Posted September 23, 2013 Author Share Posted September 23, 2013 For Altirra, my entry is listed as below as an example: [Altirra] UseShortFilenames=0 UseDefaultTypes=0 SupportedTypes=atr;xex;bin;rom;com;cas;atx;pro;xfd;dcm;bas; EmulatorPathFile=D:\Emulation\GameBase\Atari 800\Emulators\Altirra-2.10\Altirra.exe ScriptFile=Altirra 22.txt WaitFinish=1 1= Thanks. I found it. Mine is quite a but longer. This DOES work (I reset up Gamebase). I wonder if there is a newer version of this ini file for Altirra 2.4. Mine says: [Emulators] 1=Altirra 2=Atari800Win 3=Atari800 4= [Videolan] UseShortFilenames=0 UseDefaultTypes=0 SupportedTypes=flv; EmulatorPathFile=C:\GameBase\Atari 800\VLC\vlc.exe ScriptFile=flv.txt WaitFinish=1 1= [Atari800] UseShortFilenames=0 UseDefaultTypes=0 SupportedTypes=xex;cas;bas;bin;com;rom;xfd; EmulatorPathFile=C:\GameBase\Atari 800\Emulators\atari800-2.2.1-winsdl\atari800.exe ScriptFile=Atari800.txt WaitFinish=1 1= [Atari800Win] UseShortFilenames=0 UseDefaultTypes=0 SupportedTypes=atr;xex;bin;rom;com;cas;bas;xfd;atx; EmulatorPathFile=C:\GameBase\Atari 800\Emulators\Atari800Win4-1\Atari800Win.exe ScriptFile=Atari800Win.txt WaitFinish=1 1= [Altirra] UseShortFilenames=0 UseDefaultTypes=0 SupportedTypes=atr;xex;bin;rom;com;cas;atx;pro;xfd;dcm;bas; EmulatorPathFile=H:\Emulation\Atari 8-Bit\Emulators\Altirra-2.30\Altirra64.exe ScriptFile=Altirra 22.txt WaitFinish=1 1= So, does anyone have a newer version of the ini file? Quote Link to comment Share on other sites More sharing options...
