atari8warez Posted September 26, 2013 Share Posted September 26, 2013 (edited) My daily use 130XE, modified to include a U1MB and an internal SIO2PC just started to act strangely. It started to happen after I played with my IDE+2 for a while and I left it ON overnight last night. When I started to use it today I noticed SDX in U1MB does not boot properly but gives all sorts of error messages. First I thought it may be due to U1MB so I disconnected it to see if the machine will work properly without it, but it didn't. The video shows what happens when I try to boot SD 3.2 from a 1050. If you watch and listen carefully you will see that the machine beeps twice towards the end of the boot process and then drops to BASIC. I then type DOS and go to the dos prompt. I then try to type DIR but the machine types DHR instead, the I key is typed as H. Some other keys also malfunction, for instance 1 is typed as 0, but if i hold the 1 key down then the key repeats as 1,0,1,0,1,0 etc... Also note that when I try to type DIR at the DOS prompt I sometimes get it right, but when I press ENTER the computer does nothing, at this point the machine is useless. I performed all self-test routines (including an extended RAM test) and everything including the keyboard checks OK during self-test. I thought maybe POKEY is malfunctioning, but if it is so then I should have seen problems during self-test too, but i don't, so I am quite clueless at this point as to what might be wrong with this 130XE? Did anybody experience something similar or have any ideas on what to check next? http://youtu.be/PYs7Te6tNUw Edited September 26, 2013 by atari8warez Quote Link to comment Share on other sites More sharing options...
atari8warez Posted September 26, 2013 Author Share Posted September 26, 2013 And this is what happens when I drop into BASIC (happens the same way every time) Quote Link to comment Share on other sites More sharing options...
Van Posted September 26, 2013 Share Posted September 26, 2013 Can't help much, but have a 600xl that has a similar flu. After several hours of use (temp related?) wrong characters read/displayed; I think there was also an issue with stored values in ram changing (flakey DRAM chip?). Didn't spend too much time testing it; no access to a logic analyzer or even a scope, so not too much I can do aside from replacing parts. At first I thought that it might be a POKEY problem, but that wouldn't account for the corruption of mem values. So thinking it is a DRAM refresh issue. Yogi Quote Link to comment Share on other sites More sharing options...
atari8warez Posted October 1, 2013 Author Share Posted October 1, 2013 Turns out it was a case of a flaky RAM module and a loose capacitor (C1). So the 130XE is back to daily duty 2 Quote Link to comment Share on other sites More sharing options...
