+slx Posted September 29, 2013 Share Posted September 29, 2013 I have a SIO2SD by Pigula/Shpoon which is a couple of years old. How can I find out which version I have and are the versions a matter of hardware or software. I.e. can I upgrade older versions to newer ones using software or do I have to select a software version "fitting" for my hardware. I seem to be unable to find that info in the Wiki. Thanks for your help! Quote Link to comment Share on other sites More sharing options...
BillC Posted September 29, 2013 Share Posted September 29, 2013 I have a SIO2SD by Pigula/Shpoon which is a couple of years old. How can I find out which version I have and are the versions a matter of hardware or software. I.e. can I upgrade older versions to newer ones using software or do I have to select a software version "fitting" for my hardware. I seem to be unable to find that info in the Wiki. Thanks for your help! I don't have an SIO2SD but I took a quick look at the V1 and V2 schematics, and the only difference I can see is the addition of the 74HC254N on the V2. If your SIO2SD doesn't have a 74HC245 IC then it's a version 1, if it does have this IC then it's a version 2(or later) Quote Link to comment Share on other sites More sharing options...
