+5-11under Posted November 8, 2013 Share Posted November 8, 2013 ... and only one of the RAM chips. ... the untested and somewhat incomplete PM, by the way. Quote Link to comment Share on other sites More sharing options...
JamesD Posted November 8, 2013 Share Posted November 8, 2013 (edited) Check the datasheet at http://map.grauw.nl/resources/sound/generalinstrument_ay-3-8910.pdf BDIR=0 BC2=1 BC1=0 must be generated by default (inactive chip, that is not accessed) BDIR=0 BC2=1 BC1=1 must be generated by port 52H BDIR=1 BC2=1 BC1=0 must be generated by port 51H BDIR=1 BC2=1 BC1=1 must be generated by port 50H So go ahead and make decoding logic that generates these signals Note that in datasheet you can see there are three possible BDIR/BC2/BC1 combinations for inactive chip, choose the best one to reduce logic use. For decoding you'll need only IORQ, A7-A4 and A1-A0. BC2 is always 1 and could be tied to +5v. That means you only need to generate BDIR and BC1. BDIR=0 BC1=0 must be generated by default (inactive chip, that is not accessed) BDIR=0 BC1=1 must be generated by port 52H BDIR=1 BC1=0 must be generated by port 51H BDIR=1 BC1=1 must be generated by port 50H The following could be wrong so you'd want to verify it but... The smallest way to do this would be a PAL or GAL capable of at least 10 inputs and 2 outputs. Valid Address logic (50h - 52h) during IO request: VA = ! IORQ * A7 * A5 * !(A6 + A4 + A3 + A2) * !(A1 * A0) AY control logic: BDIR = VA * RD BC1 = VA * !A0 At least if RD logic works like I think it does which would be active (ow) during IORQ read and inactive (high) during IORQ write. If I could get my device programmer software to work with my current OS I'd burn you a GAL. *edit* I haven't written PAL ASM in quite a while so I make no promises that's written correctly. BTW, I think 50H would actually be read/write and 52H wouldn't really be needed. Why they used another port I don't know. Perhaps MSX does. Edited November 8, 2013 by JamesD Quote Link to comment Share on other sites More sharing options...
chart45 Posted November 9, 2013 Author Share Posted November 9, 2013 i take help from all of you and everything that someone can teach me ill take it thanks Quote Link to comment Share on other sites More sharing options...
JamesD Posted November 9, 2013 Share Posted November 9, 2013 This will help you read the logic from the PAL ASM. GAL ASM is pretty much the same for what I used.Jump to page 15 to see how to read the operators.http://www.taskit.de/fileadmin/taskit/download/manuals/GAL-ASM-Starterkit_Manual.pdf Quote Link to comment Share on other sites More sharing options...
JamesD Posted November 10, 2013 Share Posted November 10, 2013 BC2 is always 1 and could be tied to +5v. That means you only need to generate BDIR and BC1. BDIR=0 BC1=0 must be generated by default (inactive chip, that is not accessed) BDIR=0 BC1=1 must be generated by port 52H BDIR=1 BC1=0 must be generated by port 51H BDIR=1 BC1=1 must be generated by port 50H The following could be wrong so you'd want to verify it but... The smallest way to do this would be a PAL or GAL capable of at least 10 inputs and 2 outputs. Valid Address logic (50h - 52h) during IO request: VA = ! IORQ * A7 * A5 * !(A6 + A4 + A3 + A2) * !(A1 * A0) AY control logic: BDIR = VA * RD BC1 = VA * !A0 At least if RD logic works like I think it does which would be active (ow) during IORQ read and inactive (high) during IORQ write. If I could get my device programmer software to work with my current OS I'd burn you a GAL. *edit* I haven't written PAL ASM in quite a while so I make no promises that's written correctly. BTW, I think 50H would actually be read/write and 52H wouldn't really be needed. Why they used another port I don't know. Perhaps MSX does. I *think* BDIR should actually be: BDIR = VA * !A1 Quote Link to comment Share on other sites More sharing options...
