Asmusr Posted October 19, 2013 Share Posted October 19, 2013 It works for me on my PAL console. In Classic99 it returns immediately. REF VWTR DEF START VDPST EQU >8802 START LIMI 0 LI R1,>0170 VDP Reg 1, Enable IE bit.(mode bits may vary) BLWP @VWTR CLR R12 9901 base cru SBO 2 vdp int via 9901, enable LI R1,60*10 duration in 60th of a second slice WAIT1 CLR R12 WAIT2 TB 2 vdp interrupt? (via 9901) JEQ WAIT2 no, spin and wait SBO 2 enable 9901 int (tests show this may not be needed) MOVB @VDPST,R2 read status to clear 9918 VDP Interrupt DEC R1 counter expired? JNE WAIT1 no, tick off another 60th of a second BLWP @0 END START 2 Quote Link to comment Share on other sites More sharing options...
Asmusr Posted October 19, 2013 Share Posted October 19, 2013 And it also works on my US console with the F18A. Edit: ... and in MESS. 1 Quote Link to comment Share on other sites More sharing options...
+InsaneMultitasker Posted October 19, 2013 Share Posted October 19, 2013 In my test code I presume R2 (or memory location of your choosing) would subsequently be used to determine coincidence or 5th sprite flags (via ANDI or COCB / CZCB test). I revisited the 9918 manual and thought I'd share these snippets that may be of some use for the thread: 5.1.2 Register I (Contains Eight VDP Control Bits) Bit 2 = IE (Interrupt Enable)O-Disables VDP interrupt1 -Enables VDP interruptIf the VDP interrupt is connected in hardware and enabled by this bit, it will occur at the end ofthe active screen display area, just before vertical retrace starts. [For our use, VDPINT is tied to the 9901]. Exceptionally smooth, clean pattern drawing and sprite movement can be achieved by writing to the VDP during the periodthis interrupt is active. [i do not quite know what to make of this statement.] 5.2.1The VDP Status Register contains the Interrupt Flag, Coincidence Flag, Fifth Sprite Flag, andthe Fifth Sprite Number (if one exists). Each of these is explained in the following paragraphs. Interrupt Flag (F)The F flag in the Status Register is set equal to 1 at the end of the raster scan of the last line ofthe active display, just before the Backdrop color at the bottom of the screen begins. It is resetto a 0 after the Status Register is read or whenever the VDP is externally reset (hardwarereset). If the Interrupt Enable bit located in VDP Register 1 is active (1), then the VDP interruptoutput line (INT) will be active (0) whenever the F status flag is 1. [read via 9901] NOTE ¯The Status Register needs to be read frame-by-frame in order to clear the interruptand receive the new interrupt for the next frame [e.g., read the status byte once per each 60th of a second] 5.2.2 Coincidence Flag ©The C status flag will be set to a 1 if two or more sprites coincide. Coincidence occurs if anytwo sprites on the screen have at least one overlapping pixel. Sprites set to the VDP colortransparent, as well as those partially or completely off the screen, are considered. Spritesbeyond the Attribute Table terminator of Hex DO are not considered. The C flag is clearedwhenever the VDP Status Register is read or the VDP is externally reset.5.2.3 Fifth Sprite Flag (5S) and NumberThe Fifth Sprite Flag is set to a 1 whenever there are five or more sprites active on a horizontalline. The Fifth Sprite Flag is cleared to a 0 after the Status Register is read or whenever theVDP is externally reset. The number of the lowest priority sprite on the horizontal line isloaded into thee lower five bits of the Status Register whenever the Fifth Sprite Flag is set andis valid whenever the Fifth Sprite Flag is a 1. The setting of the Fifth Sprite Flag will not generatean interrupt. Quote Link to comment Share on other sites More sharing options...
marc.hull Posted October 21, 2013 Author Share Posted October 21, 2013 Dang it..... CLR R12 SBZ 0 INT MODE (might need to only set once at program start) SBO 2TMLP1 TB 2 VDP INT? JEQ TMLP1 spin SBO 2 I cannot get this thing to work. As it stands the console just free wheels with no throtteling. Changing the JEQ to JNE creates a hang up. I Have tried it on three NTSC consoles at this point. Either NTSC consoles are not what they seem or more likely I'm still missing something. Quote Link to comment Share on other sites More sharing options...
+InsaneMultitasker Posted October 21, 2013 Share Posted October 21, 2013 It works for me on my PAL console. In Classic99 it returns immediately. REF VWTR DEF START VDPST EQU >8802 START LIMI 0 LI R1,>0170 VDP Reg 1, Enable IE bit.(mode bits may vary) BLWP @VWTR CLR R12 9901 base cru SBO 2 vdp int via 9901, enable LI R1,60*10 duration in 60th of a second slice WAIT1 CLR R12 WAIT2 TB 2 vdp interrupt? (via 9901) JEQ WAIT2 no, spin and wait SBO 2 enable 9901 int (tests show this may not be needed) MOVB @VDPST,R2 read status to clear 9918 VDP Interrupt DEC R1 counter expired? JNE WAIT1 no, tick off another 60th of a second BLWP @0 END START It was pointed out to me that the VWTR routine uses R0, not R1. Sorry! Fortunately, it doesn't seem to impact the test as the interrupt bit default is 'enabled'. Quote Link to comment Share on other sites More sharing options...
