Pset Posted November 22, 2013 Share Posted November 22, 2013 This memory address acts like some kind of control over where the cursor position starts to print text. It seems to jump a number of steps backwards according to the increment value given. Text does not auto wrap around when typing or printing strings that exceed the screen border after a new cursor position is set. 5 print chr$(11) 10 for x = 1 to 22 20 inc=1 : REM increment 30 POKE 14336,I : REM sets cursor position 40 PRINT X 50 NEXT X Maybe someone can find a use for this. Quote Link to comment Share on other sites More sharing options...
mvdsteenoven Posted November 23, 2013 Share Posted November 23, 2013 This memory address acts like some kind of control over where the cursor position starts to print text. It seems to jump a number of steps backwards according to the increment value given. This memory address controls the cursor row position on screen.For more memory addresses than controls the Aquarius behaviour look at http://www.vdsteenoven.com/aquarius/mempointer.html Quote Link to comment Share on other sites More sharing options...
Pset Posted December 10, 2013 Author Share Posted December 10, 2013 (edited) I got distracted trying to making a scrolling game and ended up making digital rain instead.Thanks for the pokes. I wish the inputs to the pokes had some kind of sense to them. 5 PRINT CHR$(11) 10 P = 47 20 REM 14338 & 14337 Address of the cursor within the cursor matrix 100 POKE 14338,P 110 GOSUB 610 130 GOTO 10 610 FOR D=1 TO 25 630 PE = PEEK(14337) 685 gosub 2000 690 NEXT D 695 poke 14336,1 : Rem move print column back 700 RETURN 2000 REm Print here 2025 if rr =0 then rs$= "01100000010000100000100001" 2022 if rr=1 then rs$= "10100010001000100001010110" 2023 if rr=2 then rs$= "11001000100101010110001011" 2024 if rr >3 then rs$= "11100000100010000101010001" 2030 rr=rr+1: if rr = 4 then rr= 0 2050 print rs$ 2060 rs$="" 2100 return Edited December 10, 2013 by Pset Quote Link to comment Share on other sites More sharing options...
Aquaman Posted December 10, 2013 Share Posted December 10, 2013 This was written on the following FAQ about these addresses http://archive.kontek.net/aqemu.classicgaming.gamespy.com/aqfaq2.htm "14336. This location usually is value 0. Poking a 1 will move the normal left margin, governing text appearing on the screen, one location to the LEFT. Larger numbers will push printing further left, making it wrap and reappear on the screen at the right. Thus a POKE 14336,38 moves the margin 38 places to the left and makes it appear (on a 40-column screen) that the margin has been moved two places to the right. Text beyond the right margin may be lost, may wrap, or may wrap and cause reinstatement of the normal left margin" PS Just to be curious, what kind of scrolling game do you have in mind? Quote Link to comment Share on other sites More sharing options...
Pset Posted December 11, 2013 Author Share Posted December 11, 2013 (edited) Scrambler, Vanguard, Defender type. I could probably just go into extended basic and use the locate command to reposition the cursor. I really want the pattern to get the cursor back to 0,0. In theory it should be possible to make a map scroll sideways with left$, mid$, and right$ by shifting characters. Assuming you don't overload a string, ugh. Lol, note from your link "14338, 14342-14343, 14407, 14550-14553, 16313. Avoid poking these locations." I found Poke 14338,47 repeated gives a five column tab set up with the cursor starting to print just above the screen top. 46 and under takes it up and away higher, i can't see what its doing Setting P to 48 in line 10 will cause the printing to hammer the bottom of the screen. Setting it higher can push the printing into the color matrix, then higher it eventually appears to lock the emulator, but Control C a bunch of times and you'll find the cursor scrolling down the screen from some hidden height in. If you totally lose the cursor you can type (in the unseen world) poke 14338,48 a few times and get it back, if not the first time. Edited December 11, 2013 by Pset 1 Quote Link to comment Share on other sites More sharing options...
Pset Posted December 11, 2013 Author Share Posted December 11, 2013 (edited) Well here ya go, this returns to the home position. try this to see it in action poke 14337,1 : poke 14338,48 And here's a scrolling road without the whole window scrolling for an example new 5 print chr$(11) 10 dim road$(20),rm$(21) 20 for r = 0 to 19 30 read road$(r) 50 next r 110 for a= 1 to 19 120 print road$(a) 125 rm$(a-1)=road$(a) 135 next a 199 REM looping road 200 rm$(19)=road$(0) 250 for i=0 to 19 :road$(i)=rm$(i) : next i 300 poke 14337,1:poke 14338,48 400 goto 100 7001 Data "######## ##################" 7002 Data "######### #################" 7003 Data "########## ################" 7004 Data "########### ###############" 7005 Data "############# #############" 7006 Data "######### ###############" 7007 Data "######### #################" 7008 Data "####### ###################" 7009 Data "###### ####################" 7010 Data "######## ##################" 7011 Data "######### ##################" 7012 Data "######### #################" 7013 Data "######## ################" 7014 Data "####### ###################" 7015 Data "###### ####################" 7016 Data "######## ##################" 7017 Data "############ ##############" 7018 Data "############# #############" 7019 Data "############# ###############" 7020 Data "######### #################" 7021 Data "########## #################" run Edited December 11, 2013 by Pset 1 Quote Link to comment Share on other sites More sharing options...
Pset Posted December 11, 2013 Author Share Posted December 11, 2013 missing line 100 in the above code. new 5 print chr$(11) 10 dim road$(20),rm$(21) 20 for r = 0 to 19 30 read road$(r) 50 next r 100 rem looping road 110 for a= 1 to 19 120 print road$(a) 125 rm$(a-1)=road$(a) 135 next a 199 REM looping road 200 rm$(19)=road$(0) 250 for i=0 to 19 :road$(i)=rm$(i) : next i 300 poke 14337,1:poke 14338,48 400 goto 100 7001 Data "######## ##################" 7002 Data "######### #################" 7003 Data "########## ################" 7004 Data "########### ###############" 7005 Data "############# #############" 7006 Data "######### ###############" 7007 Data "######### #################" 7008 Data "####### ###################" 7009 Data "###### ####################" 7010 Data "######## ##################" 7011 Data "######### ##################" 7012 Data "######### #################" 7013 Data "######## ################" 7014 Data "####### ###################" 7015 Data "###### ####################" 7016 Data "######## ##################" 7017 Data "############ ##############" 7018 Data "############# #############" 7019 Data "############# ###############" 7020 Data "######### #################" 7021 Data "########## #################" 1 Quote Link to comment Share on other sites More sharing options...
Aquaman Posted December 11, 2013 Share Posted December 11, 2013 Nicely done!! Have you ever looked at this effort from Martin: http://atariage.com/forums/topic/174798-aquarius-man-goes-on-holiday/?hl=%2Bpanscr&do=findComment&comment=2173637 This is probably done in assembly, so not really comparable, but it shows the potential of the Aquarius. Quote Link to comment Share on other sites More sharing options...
Pset Posted December 12, 2013 Author Share Posted December 12, 2013 Nicely done!! Have you ever looked at this effort from Martin: http://atariage.com/forums/topic/174798-aquarius-man-goes-on-holiday/?hl=%2Bpanscr&do=findComment&comment=2173637 This is probably done in assembly, so not really comparable, but it shows the potential of the Aquarius. Wow that was amazing. Been planning on consolidating all the Aquarius links under one post for 2014, it's a good thing you dug that up! Surprised I didn't see this in the Machine Code thread, the .asm file in this project is well documented, would be a good start for a tutorial. Maybe for building a RAD library, how could that work? Maybe directories sorted into routines like showSprite, moveSprite, getInput, then more specific files, with some replaceable text scheme like playerSpriteLeft2.txt ~spriteName~_left2:ld a, ~asciiValue~ ; ~spriteName~'s head facing left #2 call ~displaySprite~ ret Think I'll try that tonight. Oh boy! Quote Link to comment Share on other sites More sharing options...
Aquaman Posted December 12, 2013 Share Posted December 12, 2013 (edited) Wow that was amazing. Been planning on consolidating all the Aquarius links under one post for 2014, it's a good thing you dug that up! Surprised I didn't see this in the Machine Code thread, the .asm file in this project is well documented, would be a good start for a tutorial. Maybe for building a RAD library, how could that work? Maybe directories sorted into routines like showSprite, moveSprite, getInput, then more specific files, with some replaceable text scheme like playerSpriteLeft2.txt ~spriteName~_left2: ld a, ~asciiValue~ ; ~spriteName~'s head facing left #2 call ~displaySprite~ ret Think I'll try that tonight. Oh boy! So you know a bit of assembler I guess? Something like that would indeed make life easier for us less fortunate and trying to get the hang of it:) Edited December 12, 2013 by Aquaman Quote Link to comment Share on other sites More sharing options...
Pset Posted December 12, 2013 Author Share Posted December 12, 2013 So you know a bit of assembler I guess? Something like that would indeed make life easier for us less fortunate and trying to get the hang of it:) None at all. But the scripting language we developed for my game engine early on was very much like assembler. //igame3d T3DScript macro code begin spinm type 2 axis 7//remember angles mark mark 4 type 1 addf 2,5.0 addf 5,-100 poke 1,1,e collnormal 1 dirToAngles 1,1 addf 1,90 end begin posOnPlane axis setf 10,f2 spinm setf 4,f2 multf 4,-1 roty setf 4,f10 roty spin end Quote Link to comment Share on other sites More sharing options...
Aquaman Posted December 12, 2013 Share Posted December 12, 2013 None at all. But the scripting language we developed for my game engine early on was very much like assembler. Ah I see! Anyway, you seem to have been gifted to easy understand all sorts of programming languages Quote Link to comment Share on other sites More sharing options...
