Laner Posted November 23, 2013 Share Posted November 23, 2013 So I dug out my 800 last night after years of sitting in the closet. Unfortunately, I cannot get it to recognize my 810 drive, or the SIO2USB, and while my AtariMax flash cart will boot, none of the games will load. I've tried multiple SIO cables, no luck. BASIC and AtariWriter carts seem to work OK. With no cart installed, I just get the Memo Pad. If I have BASIC inserted and type DOS, same thing. With the Atarimax flash cart, I have Rich's Multi-Cart installed, and I can browse through the titles, but launching them does nothing. Any ideas? Is this fixable or am I up a creek? I don't have any other systems to test on, other than a 130XE that I can't find the power cord for. Quote Link to comment Share on other sites More sharing options...
Roydea6 Posted November 23, 2013 Share Posted November 23, 2013 (edited) Most probably an OS problem does your 800 have Rev OSB or Rev OSA. and most cartridges similar to Atarimax would need an 800XL/XE because most converted XEX files require Rev 2 OS. Do you have game cartridges for the 800 most of the earlier ones will work with the 800. Reflash your Atari Max Cartridge with only OSB compatible games and set the Cartridge to OSB mode. AS for the SIO and Disk drives It might work to leave power plugged in and turn on for several hours to normalize all the electronics.. Edited November 23, 2013 by rdea6 Quote Link to comment Share on other sites More sharing options...
Laner Posted November 23, 2013 Author Share Posted November 23, 2013 OK, one mystery solved. I needed to get the 64 bit SIO2PC drivers. I'll check on OSB games for the atarimax cart as well - thanks. Quote Link to comment Share on other sites More sharing options...
Roydea6 Posted November 23, 2013 Share Posted November 23, 2013 (edited) Some 8bit game dumps I got off the Atari Max site. It is an 8mb file but a you need the studio file to flash into a Cart. It is a zipped workbook for the Cartridge programmer.. Mitch 8bit Dumps.bin Mitch 8bit Dumps.zip Edited November 23, 2013 by rdea6 Quote Link to comment Share on other sites More sharing options...
Kyle22 Posted November 23, 2013 Share Posted November 23, 2013 (edited) Atarimax 1M Flash + MyIDE cart with SpartaDOS-X on it works on my unmodified 800. Not enough memory for the IDE driver to load, but other than that, it works. Edited November 23, 2013 by Kyle22 Quote Link to comment Share on other sites More sharing options...
sup8pdct Posted November 24, 2013 Share Posted November 24, 2013 There could be one of seversl things wrong. Pokey isn.t working properly, pia (same thing) or the chips and connectors need to be re seated. Getting replacemrnt chips isnt too hard. Reseating everything is easy and only costs a bit of time so is the first plsce to start. James Quote Link to comment Share on other sites More sharing options...
BillC Posted November 24, 2013 Share Posted November 24, 2013 Atarimax 1M Flash + MyIDE cart with SpartaDOS-X on it works on my unmodified 800. Not enough memory for the IDE driver to load, but other than that, it works. It depends on the version of SDX whether it works on the 800. The original ICD versions do, v4.42 doesn't, v4.46 does, I don't know about the others. Quote Link to comment Share on other sites More sharing options...
Kyle22 Posted November 24, 2013 Share Posted November 24, 2013 SDX 4.46. Check your C012294 POKEY. I had one go out (for no apparent reason) on my 1200XL. It is unlikely to see a PIA go out like that.... Possible, though. Quote Link to comment Share on other sites More sharing options...
Panther Posted November 24, 2013 Share Posted November 24, 2013 I just had to replace the PIA chip in a 1050 drive today. Anything's possible! Quote Link to comment Share on other sites More sharing options...
1050 Posted November 24, 2013 Share Posted November 24, 2013 It is unlikely to see a PIA go out like that.... Possible, though. While I have had three 800s with bad PIAs and good POKEYs. Same symptom, disk drive access is a no go until the PIA is changed out for a good one. Hitachi 68B21 is an exact drop in replacement for the 6520 PIA, Jameco has them among others, even FleaBay though I haven't looked recently myself for any. Quote Link to comment Share on other sites More sharing options...
Rybags Posted November 24, 2013 Share Posted November 24, 2013 Insert Basic, type ? FRE(0) Let's verify first that this thing actually has a decent amount of RAM installed and is seeing it. Games and the like - the bulk of games out there should work fine on a 48K 800, regardless of OS A or B. Quote Link to comment Share on other sites More sharing options...
Kyle22 Posted November 24, 2013 Share Posted November 24, 2013 While I have had three 800s with bad PIAs and good POKEYs. Same symptom, disk drive access is a no go until the PIA is changed out for a good one. Hitachi 68B21 is an exact drop in replacement for the 6520 PIA, Jameco has them among others, even FleaBay though I haven't looked recently myself for any. If it is the PIA, WDC also makes a nice one W65C21S. 1 Quote Link to comment Share on other sites More sharing options...
