Mr SQL Posted December 12, 2013 Share Posted December 12, 2013 Is anyone familiar with an FCC psuedo op equiv for DASM? FCC (form constant character) allows a contiguous block of data to be formed without comma's. .byte $f3,$a2,$f4,$e1 could be written as .FCC $f3a2f4e1 FDB was another useful pseudo op that allowed two bytes between commas; I had used them with EDTASM+ in the 80's. Quote Link to comment Share on other sites More sharing options...
alex_79 Posted December 12, 2013 Share Posted December 12, 2013 (edited) I think the HEX preudo op does what you need. From the dasm v.2.12 documentation: [label] HEX hh hh hh.. This sets down raw HEX data. Spaces are optional between bytes. NO EXPRESSIONS are allowed. Note that you do NOT place a $ in front of the digits. This is a short form for creating tables compactly. Data is always layed down on a byte-by-byte basis. Example: HEX 1A45 45 13254F 3E12 Edited December 12, 2013 by alex_79 1 Quote Link to comment Share on other sites More sharing options...
Mr SQL Posted December 12, 2013 Author Share Posted December 12, 2013 I think the HEX preudo op does what you need. From the dasm v.2.12 documentation: Thanks Alex, that is right along the lines of what I am looking for but I need to put the data in binary; I've tried BIN and BINARY but they just throw an error. Quote Link to comment Share on other sites More sharing options...
ScumSoft Posted December 13, 2013 Share Posted December 13, 2013 I don't think there is any directive for binary like you want, but the source to dasm is available and it could be added if you really need it. Quote Link to comment Share on other sites More sharing options...
Mr SQL Posted December 13, 2013 Author Share Posted December 13, 2013 I don't think there is any directive for binary like you want, but the source to dasm is available and it could be added if you really need it. Thanks I can't add it, I need the feature to be available by default to other programmers. Too bad theres no generic form or % prefix on the HEX block! Quote Link to comment Share on other sites More sharing options...
Thomas Jentzsch Posted December 13, 2013 Share Posted December 13, 2013 Maybe you could use a macro? Quote Link to comment Share on other sites More sharing options...
SeaGtGruff Posted December 13, 2013 Share Posted December 13, 2013 That was my first thought, too-- that a macro might be possible. What is the purpose of this? For example, is it going to be used to code playfield data? Are there any restrictions, needs, or wants as to how this is supposed to function, like needing the binary data to be flipped for every other byte's worth of 1s and 0s? Quote Link to comment Share on other sites More sharing options...
Mr SQL Posted December 13, 2013 Author Share Posted December 13, 2013 That was my first thought, too-- that a macro might be possible. What is the purpose of this? For example, is it going to be used to code playfield data? Are there any restrictions, needs, or wants as to how this is supposed to function, like needing the binary data to be flipped for every other byte's worth of 1s and 0s? Great question SeaGtGruff! I am using a 96x20 bit table to hold WYSIWYG bitmaps for large virtual worlds in my ASDK Framework and I wanted to have a smoother WYSIWYG format than having it interrupted by ",%" after every 8 characters. Maybe you could use a macro? Without a suitable psuedo op I'll probably just leave it but I'm curious, can a macro script easily drop in a block of binary WYSIWYG data (bitmap) similar to the HEX psuedo op, or do you end up writing a page of script? Quote Link to comment Share on other sites More sharing options...
SeaGtGruff Posted December 13, 2013 Share Posted December 13, 2013 When defining a macro you can use {0} to get the entire parameter, which presumably would include a very long string of binary data-- although I'm not sure how you could then divide the string into substrings. It sounds like maybe you'd be best off writing a script or small program that would pre-process the bB program file before bB's own pre-processor, to look for lines that contain some keyword and then replace the binary string with the equivalent BYTE or HEX values, maybe like mydata WYSIWYG 100110100111101011011001 being replaced by mydata BYTE %10011010,%01111010,%11011001 Quote Link to comment Share on other sites More sharing options...
Mr SQL Posted December 15, 2013 Author Share Posted December 15, 2013 When defining a macro you can use {0} to get the entire parameter, which presumably would include a very long string of binary data-- although I'm not sure how you could then divide the string into substrings. It sounds like maybe you'd be best off writing a script or small program that would pre-process the bB program file before bB's own pre-processor, to look for lines that contain some keyword and then replace the binary string with the equivalent BYTE or HEX values, maybe like mydata WYSIWYG 100110100111101011011001 being replaced by mydata BYTE %10011010,%01111010,%11011001 That option would go nicely with a GUI version if someone were interested in developing a Visual ASDK Right now it's form factor is a single asm file that supports using WYSIWYG bitmaps for the virtual worlds inline in the code. The bB compiler could be used to generate the Assembly for the gameloop, but the ASDK is a completely different Framework. I like IDE's too but I prefer just to use a single file in a text editor with asm instead of using a Visual IDE, and also when coding in bB; it feels more retro Quote Link to comment Share on other sites More sharing options...
