Paul Westphal Posted December 16, 2013 Share Posted December 16, 2013 I have 2 non working 800xl mainboards. The light comes on but no-one is home on one of them. The other has a solid white bar on the right. I was going to start swapping chips to see if I can get one to work. Any Ideas on which ones more commonly go out? Where should I start? I would hate to scrap them. Quote Link to comment Share on other sites More sharing options...
+David_P Posted December 16, 2013 Share Posted December 16, 2013 Do you have a known working 800xl? If so, use it to determine which chips are working from the two malfunctioning systems. Quote Link to comment Share on other sites More sharing options...
Paul Westphal Posted December 16, 2013 Author Share Posted December 16, 2013 That's a lot of swapping, but a start nonethless. Thanks. I will start with the 6502 and work my way down Can I power up the board without a case? Quote Link to comment Share on other sites More sharing options...
russg Posted December 16, 2013 Share Posted December 16, 2013 That's a lot of swapping, but a start nonethless. Thanks. I will start with the 6502 and work my way down Can I power up the board without a case? yes. Be careful not to set it on a conductor. Would short. Quote Link to comment Share on other sites More sharing options...
Rybags Posted December 16, 2013 Share Posted December 16, 2013 (edited) You can power up without a case no probs, no keyboard needed either but having one attached can be of help if it's only partially malfunctioning. Just ensure nothing can cause shorts - an old shoebox can be ideal for resting motherboards on. Of course though, running a keyboard outside the case might cause potential for shorts in itself so take care there. As was said, swapping one chip at a time into a known good system can make it a whole bunch easier. Stuff I'd be testing in order - CPU, Antic, MMU, OS ROM, RAM, PIA. Generally if the CPU is bad or otherwise unable to run the initial OS powerup stuff the screen will have a dark brown or reddish colour. Sometimes having a game that runs in diag cart mode can help too. Star Raiders and Asteroids are 2 such games, also they only use the bottom 8K RAM although since XL/XEs have Ram such that the 64K systems have chips that contribute 1 or 4 bits of data to every possible address, a failing chip will often affect everything. Edited December 16, 2013 by Rybags Quote Link to comment Share on other sites More sharing options...
