Kylearan Posted December 19, 2013 Share Posted December 19, 2013 Hi, I have some problems with strobing HMOVE on cycle 71 (so it completes on cycle 74, avoiding the black bars). When I use this on M0 set to three copies close, only the first copy gets moved; the other two are not moved (or moved differently, which is hard to tell). Am I doing something wrong here, or is it just not possible to move all copies? Somewhat related (noobish) question: Regarding RESM0, HMM0, ENAM0 (or RESP0, HMP0, GRP0 etc.), is there a specific order in which to set those up, or is the order irrelevant for the exact position in the end? Thanks in advance, -Kylearan Quote Link to comment Share on other sites More sharing options...
Thomas Jentzsch Posted December 19, 2013 Share Posted December 19, 2013 What do you mean with they are not moved or differently? This would mean, that the spacing between the three copies becomes unequal. Is it that what you see? Can you describe that in more detail? A screenshot would help. Quote Link to comment Share on other sites More sharing options...
Ed Fries Posted December 19, 2013 Share Posted December 19, 2013 I'm guessing that you are changing one or more of the HMxx registers too soon after the HMOVE. Quote Link to comment Share on other sites More sharing options...
Omegamatrix Posted December 19, 2013 Share Posted December 19, 2013 Hi, I have some problems with strobing HMOVE on cycle 71 (so it completes on cycle 74, avoiding the black bars). When I use this on M0 set to three copies close, only the first copy gets moved; the other two are not moved (or moved differently, which is hard to tell). Am I doing something wrong here, or is it just not possible to move all copies? Somewhat related (noobish) question: Regarding RESM0, HMM0, ENAM0 (or RESP0, HMP0, GRP0 etc.), is there a specific order in which to set those up, or is the order irrelevant for the exact position in the end? Thanks in advance, -Kylearan It sounds like a problem where you are respositioning on a line that is displaying the missiles, and the write to RESM0 or RESM1 is what is causing the problem. The first copy gets drawed, and the repositioning takes affect. 1 Quote Link to comment Share on other sites More sharing options...
+SpiceWare Posted December 19, 2013 Share Posted December 19, 2013 When asking for help, it's best to include the source code in question so others can actually see what you're having a problem with. Quote Link to comment Share on other sites More sharing options...
Kylearan Posted December 19, 2013 Author Share Posted December 19, 2013 Sorry for not posting screenshots and code. Somehow I thought this might be a known limitation with late HMOVEs, but maybe it's not - or, more probably, it's a mistake I made, so I'd appreciate some help. Here's the relevant code: sta HMCLR ; just to be sure... ; position vertical lines (M0) without enabling them yet sta WSYNC SLEEP 26 sta RESM0 lda #$30 sta HMM0 SLEEP 37 ; sta WSYNC sta HMOVE lda #%0000011 ; Three copies close sta NUSIZ0 ; show horizontal lines (P0) sta WSYNC lda #%11111111 sta GRP0 SLEEP 20 sta RESP0 ; Disable P0 and enable M0 on next scanlines sta WSYNC lda #0 sta GRP0 lda #%00000010 sta ENAM0 This is what it looks like (the grey borders to the left and right in the screenshot are the window decorations from Stella): Notice the odd spacing between the horizontal lines (P0). If I comment out the SLEEP 37 in line 9 and comment in the sta WSYNC in line 10, it looks like this: This is how I had expected the first version to look like, minus the black comb bar. (This is Stella 3.8.1 by the way; unfortunately I won't have my Harmony cartridge before next year, so cannot test on real hardware.) So now I'm confused: I manipulate HMM0 with a sta HMOVE on cycle 71/74, and the display of P0 gets changed in an odd way...? What am I missing here? Quote Link to comment Share on other sites More sharing options...
Thomas Jentzsch Posted December 19, 2013 Share Posted December 19, 2013 You know that the movement values change when you do an early HMOVE? HMPx values 0 1 2 3 4 5 6 7 8 9 a b c d e f Cyc ------------------------------------------------------------------------ 70 -5 -6 -7 -8 -9 -10 -11 -12 0 0 0 0 -1 -2 -3 -4 ** 71 -6 -7 -8 -9 -10 -11 -12 -13 0 0 0 -1 -2 -3 -4 -5 72 -7 -8 -9 -10 -11 -12 -13 -14 0 0 -1 -2 -3 -4 -5 -6 73 -8 -9 -10 -11 -12 -13 -14 -15 0 -1 -2 -3 -4 -5 -6 -7 74 -8 -9 -10 -11 -12 -13 -14 -15 0 -1 -2 -3 -4 -5 -6 -7 ** 75 0 -1 -2 -3 -4 -5 -6 -7 8 7 6 5 4 3 2 1 HBLANK 76 0 -1 -2 -3 -4 -5 -6 -7 8 7 6 5 4 3 2 1 HBLANK Quote Link to comment Share on other sites More sharing options...
+SpiceWare Posted December 19, 2013 Share Posted December 19, 2013 I did an Early HMOVE demo a while back, full source is included in the post. Quote Link to comment Share on other sites More sharing options...
Omegamatrix Posted December 20, 2013 Share Posted December 20, 2013 This is what it looks like (the grey borders to the left and right in the screenshot are the window decorations from Stella): hmove_3copies_cycle71.png Notice the odd spacing between the horizontal lines (P0). If I comment out the SLEEP 37 in line 9 and comment in the sta WSYNC in line 10, it looks like this: hmove_3copies_wsync.png This is how I had expected the first version to look like, minus the black comb bar. (This is Stella 3.8.1 by the way; unfortunately I won't have my Harmony cartridge before next year, so cannot test on real hardware.) So now I'm confused: I manipulate HMM0 with a sta HMOVE on cycle 71/74, and the display of P0 gets changed in an odd way...? What am I missing here? This looks like what I suspected, except that it is GRP0. You are repositioning with RESP0 while GRP0 is still being drawn. That is why it looks so displaced. With the HMOVE's ending at cycle 73/74 you can only fine move left (or not at all). HMCLR does not work with these HMOVE's as you need to store $80 to the HMxx registers instead of $00 to have no movement. Here are some constants I use: ;HMxx LEFT_7 = $70 LEFT_6 = $60 LEFT_5 = $50 LEFT_4 = $40 LEFT_3 = $30 LEFT_2 = $20 LEFT_1 = $10 NO_MOTION = $00 RIGHT_1 = $F0 RIGHT_2 = $E0 RIGHT_3 = $D0 RIGHT_4 = $C0 RIGHT_5 = $B0 RIGHT_6 = $A0 RIGHT_7 = $90 RIGHT_8 = $80 ;73/74 cycle HMxx LEFT74_15 = $70 LEFT74_14 = $60 LEFT74_13 = $50 LEFT74_12 = $40 LEFT74_11 = $30 LEFT74_10 = $20 LEFT74_9 = $10 LEFT74_8 = $00 LEFT74_7 = $F0 LEFT74_6 = $E0 LEFT74_5 = $D0 LEFT74_4 = $C0 LEFT74_3 = $B0 LEFT74_2 = $A0 LEFT74_1 = $90 NO_MO_74 = $80 Sometimes it is desirable to position an object and hit HMOVE for it in the same scanline. This is not so easy with an early HMOVE since you can't simply use a WSYNC followed by a HMOVE. I wrote a routine to not only do the RESxx strobe, but do a cycle 74 HMOVE after that on the same scanline for any position on the screen. Quote Link to comment Share on other sites More sharing options...
Kylearan Posted December 21, 2013 Author Share Posted December 21, 2013 This looks like what I suspected, except that it is GRP0. You are repositioning with RESP0 while GRP0 is still being drawn. That is why it looks so displaced. Oh, I see. I guess I hadn't spotted this as the displacement didn't happen with the standard HMOVE, but only because the timing was then slightly different and the displacement wasn't really related to the HMOVE . HMCLR does not work with these HMOVE's as you need to store $80 to the HMxx registers instead of $00 to have no movement. Ah, okay! I didn't realize that. I'll also have a look at your source. Thanks a lot! Quote Link to comment Share on other sites More sharing options...
