RetroFiends Posted December 20, 2013 Share Posted December 20, 2013 (edited) EDIT: Disregard, should have waited for my coffee to kick in, I can use on... goto... and have multiples point to the same label. Oops I can get close to this using on... goto..., but that requires some level of linearity to work. I've finally come back to batari basic after a small break, and I've learned about switch statements and am now sorely missing them.My level screens are stored in what is effectively a 2D array (using variable D, +-1 for up/down, +-10 for left and right), upon checking what screen you are on, it loads the corresponding walls for that room, from 0 to 99.Before this re-haul, on... goto... was perfect, as it could simply jump to the room necessary. However, since every wall (north, south, east and west) is ultimately only one of two states, open or closed, I figure I'd save a lot of room by sharing them. I could still use on... goto... if those labels then redirect to the appropriate wall state label, but I wonder if there's a better way. My first thought was just to string a bunch of OR statements but batari basic limits this to only one per statement. I suppose even still, I can use OR to cut the lines needed in half to do this, but this probably gets messy really fast. Any thoughts? Edited December 20, 2013 by RetroFiends Quote Link to comment Share on other sites More sharing options...
SeaGtGruff Posted December 20, 2013 Share Posted December 20, 2013 (edited) I take it you're using a different routine for each room? You may not need to do that. If the rooms are basically identical except for the walls, then you could define some arrays for the wall states. And if there are only two states for each wall, it could be a binary array (1 bit per wall). This could be done two different ways: (1) Use one array, one byte per room. That gives you 8 bits to use for flags for each room. You could use 4 of the bits for the walls, leaving the other 4 bits for something else, like one 0-15 variable, or two 0-3 variables, or whatever, such as an index for a color table, or flags that indicate whether or not the room contains special objects or features (stairs up, stairs down, a trap, or treasure). (2) Use four arrays, one bit per room. That is, one array would be for the north wall, another array for the east wall, another for south, and another for west. Then you'd need to extract the correct bit for the room using a formula, since each byte of an array would hold 8 rooms' worth of data, so you'd need to divide the room number by 8 to get the array index, and use the remainder to determine which bit to look at. Either way, you'd just have a single routine to handle all of the rooms, and when you change rooms the routine would just retrieve the walls data from the array(s) and then redraw the screen as needed. Edited December 20, 2013 by SeaGtGruff Quote Link to comment Share on other sites More sharing options...
RetroFiends Posted December 20, 2013 Author Share Posted December 20, 2013 (edited) I'm already one step ahead of you, there. I'm already doing the game by an on-wall basis, and I already have an array which handles the rooms.I have my walls set as such rem up rem closed if !w{0} then var1 = %11111111 : var2 = %11111111 : var5 = %11111111 : var6 = %11111111 rem open if w{0} then var1 = %00111111 : var2 = %00111111 : var5 = %00111111 : var6 = %00111111 rem right rem closed if !w{1} then var19 = %11000000 : var23 = %11000000 : var27 = %11000000 rem open if w{1} then var19 = %00000000 : var23 = %00000000 : var27 = %00000000 rem down rem closed if !w{2} then var37 = %11111111 : var38 = %11111111 : var41 = %11111111 : var42 = %11111111 rem open if w{2} then var37 = %00111111 : var38 = %00111111 : var41 = %00111111 : var42 = %00111111 rem left rem closed if !w{3} then var16 = %11000000 : var20 = %11000000 : var24 = %11000000 rem open if w{3} then var16 = %00000000 : var20 = %00000000 : var24 = %00000000 return otherbank However, I could have up to 99 rooms, potentially. I don't think it would be very efficient to do 99 if... then... statements. Whenever you enter a new room, the room variable will update, and then it will need to tell me what w{0-3} is, so this routine can run to update the walls. Edit: On a side note, I might be able to combine the open and close variables into one line with an else... Edited December 20, 2013 by RetroFiends Quote Link to comment Share on other sites More sharing options...
