Zenimus Posted January 11, 2014 Share Posted January 11, 2014 (edited) Hey guys, I need you! For some reason, my CV isn't reading input from controllers correctly. Everything worked fine very recently, but now, after setting it up for a play session, the controllers suddenly aren't responding correctly. The asterisk and many other keys don't respond. The problem is identical across all 3 controllers I've tried it with. I've hooked the system up in two different rooms, suspecting a possible voltage issue, but the effect is the same. Resetting doesn't fix it either. Have you seen this problem before? Edited January 11, 2014 by Zenimus Quote Link to comment Share on other sites More sharing options...
+5-11under Posted January 11, 2014 Share Posted January 11, 2014 Likely either the controller chip, or a loose/broken controller port pin. Quote Link to comment Share on other sites More sharing options...
Zenimus Posted January 11, 2014 Author Share Posted January 11, 2014 I looked inside the Player 1 controller port, and all 9 pins are there and look seemingly normal. Are there any physical signs I should look for? Quote Link to comment Share on other sites More sharing options...
