cx2k Posted January 26, 2014 Share Posted January 26, 2014 (edited) So I picked up this 810 drive on ebay mainly because it was cheap and because it had 2 switches on it that I suspected might be a Happy or Archiver. While I know 1050's pretty well, I really don't have much experience with 810 drives. I took it apart and found the upgrades/mods shown below. The 810 side board has two chips that are completely epoxied over and a switch on the rear of the board that goes from R118 to R117 (Not the best pic, I know). The data seperator daughter board has epoxy on several of the chips which must have had super glue put on top because they were stuck to the shield. There are no added wires to the daughterboard which also has a © 1982 label from SSM Inc. The shield has a label which says "your personal code is 1109" and it was also epoxied shut on the tabs. Finally, there is a switch which goes to a potentiometer and then across R103 on the motherboard (which I believe would probably be some other type of mod, maybe for drive speed). Anyway, here's the pics. Any help would be appreciated. Thanks, John Edited January 26, 2014 by cx2k Quote Link to comment Share on other sites More sharing options...
Albert Posted January 26, 2014 Share Posted January 26, 2014 Nice to see you are still around. Quote Link to comment Share on other sites More sharing options...
cx2k Posted January 30, 2014 Author Share Posted January 30, 2014 Thanks Albert. Still always lurking. Guess I'll bump this. Anybody have any info on this? Thanks, John Quote Link to comment Share on other sites More sharing options...
_The Doctor__ Posted January 30, 2014 Share Posted January 30, 2014 (edited) I guess we can speculate... This is the same company involved in DOS. They helped make a ton of Apple stuff and may have also been involved in the developement of the 815. So could it be the double density multi i/o board that vaporized? A custom disk duplication/protection creator? Edited January 30, 2014 by _The Doctor__ Quote Link to comment Share on other sites More sharing options...
sup8pdct Posted January 30, 2014 Share Posted January 30, 2014 My 1st thought was ARCHIVER, but i thought that they where a 4K chip which requires some mods to the side board. But maybe not. I cannot think of a reason to epoxy the 6507, unless it is special???? James Quote Link to comment Share on other sites More sharing options...
+Larry Posted January 30, 2014 Share Posted January 30, 2014 Have you considered posting this at an Apple II forum since SSM was mainly known an an Apple developer? It's a long shot, but ... Have you tried to boot from the drive, flipping the switches? Several folks tried to convert the 810 for DD, but I don't think that any were very successful. -Larry Quote Link to comment Share on other sites More sharing options...
_The Doctor__ Posted January 31, 2014 Share Posted January 31, 2014 (edited) I would re-install it with know good mech. Try and run it. switch in one position.. boot. switch in other position boot. Try loading variations of mach dos and see what the response is. Edited January 31, 2014 by _The Doctor__ Quote Link to comment Share on other sites More sharing options...
BillC Posted January 31, 2014 Share Posted January 31, 2014 Have you considered posting this at an Apple II forum since SSM was mainly known an an Apple developer? It's a long shot, but ... Have you tried to boot from the drive, flipping the switches? Several folks tried to convert the 810 for DD, but I don't think that any were very successful. -Larry I haven't seen one, but some FAQs list the following: 810 Turbo (810T) by Neanderthal Computer Things (NCT) -- double-density, track buffering, speed comparable to Happy 810 Warp Speed Quote Link to comment Share on other sites More sharing options...
