russg Posted March 18, 2014 Share Posted March 18, 2014 It is a wire fork, on a handle..... Quote Link to comment Share on other sites More sharing options...
+orpheuswaking Posted March 18, 2014 Share Posted March 18, 2014 Marshmellow holder? 1 Quote Link to comment Share on other sites More sharing options...
Rex Dart Posted March 18, 2014 Share Posted March 18, 2014 No doubt about it. It's drugs. Quote Link to comment Share on other sites More sharing options...
Hyperboy Posted March 18, 2014 Share Posted March 18, 2014 I think its a taint calibrating rod. 1 Quote Link to comment Share on other sites More sharing options...
+Stephen Posted March 19, 2014 Share Posted March 19, 2014 I think its a taint calibrating rod. In that case, what's the safety pin for? Quote Link to comment Share on other sites More sharing options...
Bumzyman Posted March 19, 2014 Share Posted March 19, 2014 It is for delicately lifting a component off a board when your desoldering it. It's made out of thin wires to prevent you from being able to apply too much lifting force. Quote Link to comment Share on other sites More sharing options...
Bumzyman Posted March 19, 2014 Share Posted March 19, 2014 In that case, what's the safety pin for? That's to pin it closed if you rip it open 2 Quote Link to comment Share on other sites More sharing options...
russg Posted March 19, 2014 Author Share Posted March 19, 2014 (edited) In that case, what's the safety pin for? The hemostat and safety pin are for poking a hole when cleaning a solder hole, and I don't know why I put that in the picture. I should have put a penny in the picture for scale. If it is a 'taint' calibrating rod, I don't know if it 'tis or 'tisn't but if it is a 't'aint I don't know. A couple small marshmellows would fit on it, but the handle is too short for a gas stove burner. I do suppose the small device for lifting a pcb component might be true. Edited March 19, 2014 by russg Quote Link to comment Share on other sites More sharing options...
+remowilliams Posted March 19, 2014 Share Posted March 19, 2014 It's an IC popper for SMD removal. EDIT: Ninja'd 1 Quote Link to comment Share on other sites More sharing options...
russg Posted March 19, 2014 Author Share Posted March 19, 2014 It's an IC popper for SMD removal. EDIT: Ninja'd Acronymns..... SMD 'Small micro device'? I've been Ninja'd. Quote Link to comment Share on other sites More sharing options...
Hyperboy Posted March 19, 2014 Share Posted March 19, 2014 Surface Mount Device Quote Link to comment Share on other sites More sharing options...
COBRAIP Posted March 21, 2014 Share Posted March 21, 2014 Sorry you guys are all wrong. This is a Hot Dog roster. Yepper you just put your hotdog on the end of it and put it over the fire. You can roast either one or two depending how you plug them in. Quote Link to comment Share on other sites More sharing options...
russg Posted March 21, 2014 Author Share Posted March 21, 2014 Sorry you guys are all wrong. This is a Hot Dog roster. Yepper you just put your hotdog on the end of it and put it over the fire. You can roast either one or two depending how you plug them in. That clears that up. Quote Link to comment Share on other sites More sharing options...
