Sir Guntz Posted May 26, 2014 Share Posted May 26, 2014 So I picked up a seemingly off brand joystick, probably a clone of the original Apple brand joystick as it looks similar. It has holds and dials for adjusting the joystick's spring and natural center, but whenever I plug it into the Apple //e, it thinks the joystick's center is off to the right. No matter what I do, I cannot get the center to be where it should be. This joystick has no manual wheels for adjusting the pots. I even opened it to look inside. Is there anything I can do? Quote Link to comment Share on other sites More sharing options...
Osgeld Posted May 27, 2014 Share Posted May 27, 2014 does your computer react normally with other joysticks, I have the same issue and its a bad 558 timer which is not that easy to find (although I did for less than a couple bucks, just have not replaced it) Quote Link to comment Share on other sites More sharing options...
Sir Guntz Posted May 29, 2014 Author Share Posted May 29, 2014 Yes, the computer works fine with another joystick, though it connects to an internal connector. The new joystick I got, I plugged into a 9 pin port on the back. Quote Link to comment Share on other sites More sharing options...
ianoid Posted May 29, 2014 Share Posted May 29, 2014 Pictures Quote Link to comment Share on other sites More sharing options...
