Uzumaki Posted June 10, 2014 Share Posted June 10, 2014 While cleaning my 128D that I got recently, I took a closer look and noticed the crack goes almost all the way around so it may not be an easy fix. There's only about 2mm space between both end of the crack and it probably won't survive if I reinsert into the 1571 shaft.I would like a replacement lever from a "spare part" 128D you may have laying around. I don't know if the stand alone 1571 or 1541-II will also fit. In USA, will pay PP gift, need just one. <--- like this but without the crack Quote Link to comment Share on other sites More sharing options...
+save2600 Posted June 10, 2014 Share Posted June 10, 2014 Not sure if they have any left, but (believe it or not - I bought one from them within the past few years) check out Sears: http://www.searspartsdirect.com/partsdirect/brands-products/Commodore-Parts/Disk-drive-Parts Quote Link to comment Share on other sites More sharing options...
Uzumaki Posted June 10, 2014 Author Share Posted June 10, 2014 Seems they have 2 different parts for 1541-II and none for 1571. I still need to see if those are interchangeable or not. Quote Link to comment Share on other sites More sharing options...
Uzumaki Posted June 14, 2014 Author Share Posted June 14, 2014 Checked it (since I found a 1541-II locally), it does not fit so I will need 1571 for sure. I did check that Sears link, they wanted $15 shipping at the cheapest. A broken disk drive is a lot cheaper!!! Quote Link to comment Share on other sites More sharing options...
S0nic Posted September 9, 2015 Share Posted September 9, 2015 hey i need this part too , where i can find it is it on 1571 same lever? Quote Link to comment Share on other sites More sharing options...
