snicklin Posted June 14, 2014 Share Posted June 14, 2014 ... I'll stick my neck out (and probably end up having it chopped off) and say that this is a hope for tonight.... Best of luck England. InsideItalysGoal.xex 1 Quote Link to comment Share on other sites More sharing options...
Yautja Posted June 14, 2014 Share Posted June 14, 2014 Speaking of the World Cup, fellow atarians: which Atari football soccer games do you consider the best and the worst? - Y - Quote Link to comment Share on other sites More sharing options...
snicklin Posted June 15, 2014 Author Share Posted June 15, 2014 Forgot to mention that the picture needed to occur more times than it did in the England net. Will learn for the Uruguay game. As for the best football games for the Atari 8 bit, personally I like the first one. "Soccer" from Thorn EMI. It had one or two problems with not picking up the ball when you are close to it, but other than that, it's one of the best games. "Fantastic Soccer" from Zeppelin was not so fantastic in my opinion. And my "Kick Off" cassette would never load, so it was immediately no good without me playing it. 1 Quote Link to comment Share on other sites More sharing options...
RodCastler Posted June 15, 2014 Share Posted June 15, 2014 (edited) I remember spending lots of hours and endless fun playing Pele's soccer for the 2600 with my neighbors. An entire team was made out of 30 pixels or so, what a game. Edited June 15, 2014 by RodCastler 1 Quote Link to comment Share on other sites More sharing options...
Mclaneinc Posted June 15, 2014 Share Posted June 15, 2014 There IS only one football game and sadly it never happened on the Atari.. Sensible Soccer.........Pure class... Quote Link to comment Share on other sites More sharing options...
Wrathchild Posted June 15, 2014 Share Posted June 15, 2014 I recall being seriously shocked when the Kick Off tape had loaded for me, it bore little resemblance to the original - horizontal and not vertical! Pele soccer on the 2600 beats most A8 efforts 1 Quote Link to comment Share on other sites More sharing options...
snicklin Posted June 15, 2014 Author Share Posted June 15, 2014 I just watched Pele Soccer on Youtube and the triangular formations made me laugh. I've always thought that a vertical version of Thorn EMI's "Soccer", with better handling could be quite like Sensible Soccer. Quote Link to comment Share on other sites More sharing options...
+CharlieChaplin Posted June 15, 2014 Share Posted June 15, 2014 Goooaaallll !! And if your team did not score enough, here is a goal for you... Goal.XEX / GOAL.ATR: requires 576k RAM to load, OlivierP (PAL) palette, tip animator 2xB goal_576k.zip Quote Link to comment Share on other sites More sharing options...
devwebcl Posted June 15, 2014 Share Posted June 15, 2014 Thor Emi Soccer 1 Quote Link to comment Share on other sites More sharing options...
devwebcl Posted June 15, 2014 Share Posted June 15, 2014 (edited) There IS only one football game and sadly it never happened on the Atari.. Sensible Soccer.........Pure class... It exists for ST: http://www.atarimania.com/game-atari-st-sensible-soccer_11184.html and Jaguar. btw, which version is best for you ? first version ? 96-97 ? Edited June 15, 2014 by devwebcl Quote Link to comment Share on other sites More sharing options...
Mclaneinc Posted June 15, 2014 Share Posted June 15, 2014 I have to say I love all the versions, played it on many systems but always return to its home, the Amiga... Half yard line lobbed goals were always great but they made the keepers a lot tougher in later versions.. Quote Link to comment Share on other sites More sharing options...
Yautja Posted June 15, 2014 Share Posted June 15, 2014 I tried it using Atari800WinPLus... how to enable the tip animator in this emulator? Goooaaallll !! And if your team did not score enough, here is a goal for you... Goal.XEX / GOAL.ATR: requires 576k RAM to load, OlivierP (PAL) palette, tip animator 2xB Quote Link to comment Share on other sites More sharing options...
devwebcl Posted June 15, 2014 Share Posted June 15, 2014 I tried it using Atari800WinPLus... how to enable the tip animator in this emulator? Which version are you using ? 4.0 ? it has 576kb option under "memory size". Quote Link to comment Share on other sites More sharing options...
+CharlieChaplin Posted June 15, 2014 Share Posted June 15, 2014 (edited) Well, the animation is just a XEX-file or ATR-image (with XEX-file on it). Thus, use the pull-down menu "Atari" and set a) machine type to XL/XE (requires AtariXL.ROM in the emulator), b) memory size to 576k or 1088k RAM, c) video system to PAL and d) options = Basic off, speed 100% (while loading you may set it to full speed). In the pull-down menu "Display" set the palette to OlivierP.ACT (if you have that palette available) and resolution to 672x480 (windowed) or 1024x768. The *.XEX file or *.ATR image should work then. If you choose the ATR image and 100% Atari speed, loading will take quite a long time. Errmm, its not possible to enable something like tip animator in the emulator, the note "tip animator 2xB" was just to inform you that I used this tip animator version to create the animation (okay, the note was incomplete)... Edited June 15, 2014 by CharlieChaplin Quote Link to comment Share on other sites More sharing options...
Yautja Posted June 16, 2014 Share Posted June 16, 2014 Ran fine with the XEX file. Nice job, BTW. Errmm, its not possible to enable something like tip animator in the emulator, the note "tip animator 2xB" was just to inform you that I used this tip animator version to create the animation (okay, the note was incomplete)... Quote Link to comment Share on other sites More sharing options...
+CharlieChaplin Posted June 18, 2014 Share Posted June 18, 2014 Well, I was bored a bit, so I created a new version of the GOAL animation. While the old version had approx. 80x50 pixels (visible) resolution and required 576k RAM to load, the new version has approx. 100x70 pixels (visible) resolution and requires only 320k RAM to load. How did I achieve a higher (visible) resolution with lower RAM requirements ? Well, I simply did cut down the framerate, which you do not notice on the A8. GOAL_laoo_320k.XEX: Goal animation with Laoo palette, requires 320k RAM to load, has 54 frames; latest tip-animator 2xB was used (allthough it still shows the old date), XEX file is not packed GOAL_olip_320k.XEX: the same GOAL animation with OlivierP palette, requires 320k RAM to load, has 54 frames; latest tip-animator 2xB was used (which still shows the old date), XEX-file is not packed GOAL.ATR: the OlivierP file-version on a bootable ATR-image for use with real Ataris and real or emulated floppy drives; the 300k file was packed with Exomizer to fit on a 180k diskette/image All versions are available in the zip file... goal_320k.zip 1 Quote Link to comment Share on other sites More sharing options...
