Atirez Posted July 25, 2014 Share Posted July 25, 2014 (edited) Hi all, I am somewhat new to all of this. However I am having a few issues getting some things to work as expected. Basically if I define: char buffer[960] = {1}; I expect that all the elements of the array will be initialised as 1 in this global variable. However printing the contents on screen: char *screen; screen = (char*)0x3028; // character scren memory start address *screen = buffer[0]; It displays a black background at position zero on screen, this is on an aquarius, zero = black, 1 = red. It doesnt seem that the arrays or indeed any global variables are being initialised :/. Perhaps I am doing something wrong in compilation? I am building each file as a .rel (relocatable object) and linking them myself with: sdcc -mz80 --no-std-crt0 --compile-only -o out/ source/notmain.c sdld -m -u -f link.lk The link.lk contains: -mjwx -i out\final\hello.ihx -b _CODE = 0xe000 -b _DATA = 0xf000 -k C:\RETRO\COMPILERS\SDCC\bin\..\lib\z80 -l z80 out\notmain.rel -e Finally I noticed in the .rst file that the data initialisation code is being produced it just doens't seem be getting run... F3C2 70 __xinit__screen_map: F3C2 01 71 .db #0x01 ; 1 F3C3 00 72 .db 0x00 ... Edited July 25, 2014 by Atirez Quote Link to comment Share on other sites More sharing options...
GroovyBee Posted July 26, 2014 Share Posted July 26, 2014 I'm not familiar with the Aquarius or your compiler but crt0 is responsible for copying the "DATA" section from ROM to RAM as well as clearing the "BSS" section. Both of these steps are needed before main is called otherwise your "C" code won't work as expected. From your previous example you weren't doing either of those actions in your start-up code. A brief look at the Aquarius memory map shows that $F000 is game cart ROM so you don't want the DATA section there. The DATA section contains initialised "C" variables in RAM. As a temporary workaround you can change your :- char buffer[960] = {1}; to const char buffer[960] = {1}; And that will place it in ROM. Quote Link to comment Share on other sites More sharing options...
