ACML Posted August 2, 2014 Share Posted August 2, 2014 I tried the ENTER "D1:filename.bas", but I get an error 137. How do you merge a saved program from disk into the one in memory? Quote Link to comment Share on other sites More sharing options...
Mathy Posted August 2, 2014 Share Posted August 2, 2014 Hello ACML You can only use "ENTER" to load a file, if the file was saved to disk using "LIST". Sincerely Mathy Quote Link to comment Share on other sites More sharing options...
+David_P Posted August 2, 2014 Share Posted August 2, 2014 If both files were SAVED, load one, LIST it to disk, then clear memory (NEW). LOAD the other file, then ENTER the second one. However, any duplicate file numbers will overwrite each other - this is not a good thing. Quote Link to comment Share on other sites More sharing options...
ACML Posted August 3, 2014 Author Share Posted August 3, 2014 Thanks all. I remember now. ENTER will not work with tokenized saved BAS programs. I listed to D1: and it worked !! Quote Link to comment Share on other sites More sharing options...
atarixle Posted August 5, 2014 Share Posted August 5, 2014 (edited) in code it means it had to look like this: 10 ? "Hello, World!" LIST "D:FILE1.BAS" NEW 20 GOTO 10 LIST "D:FILE2.BAS" NEW ENTER "D:FILE1.BAS" ENTER "D:FILE2.BAS" LIST 10 ? "Hello, World!" 20 GOTO 10 Edited August 5, 2014 by atarixle Quote Link to comment Share on other sites More sharing options...
