w1k Posted August 6, 2014 Share Posted August 6, 2014 new release: know someone whats new? http://drac030.krap.pl/en-si-pliki.php Quote Link to comment Share on other sites More sharing options...
flashjazzcat Posted August 6, 2014 Share Posted August 6, 2014 know someone whats new? You will if you read SI.HST in the ARC file: it's the changelog. Quote Link to comment Share on other sites More sharing options...
+bob1200xl Posted August 6, 2014 Share Posted August 6, 2014 Anybody have this as a plain .ATR or a .ZIP? Bob Quote Link to comment Share on other sites More sharing options...
flashjazzcat Posted August 6, 2014 Share Posted August 6, 2014 Anybody have this as a plain .ATR or a .ZIP? SI224.atr SI224.zip I don't have Stuffit on this laptop, so I just unARCed it with SDX in the emulator. 1 Quote Link to comment Share on other sites More sharing options...
Shawn Jefferson Posted August 7, 2014 Share Posted August 7, 2014 Version 2.24 ------------ - tuned delay loops in GTIA test. - missile movement in collision test made 2x faster.› - one superfluous instruction removed - added U1MB, Incognito, IDEa APT and IDE+ to recognized PBI ROMs. - removed initial fiddling with CON: drivers, the program will now simply accept the "current" state of them as default. - mono/stereo Pokey test adjusted for accelerator boards + bugfix. - added detection routine for Evie. 1 Quote Link to comment Share on other sites More sharing options...
+bob1200xl Posted August 7, 2014 Share Posted August 7, 2014 Thanks, FJC! Bob Quote Link to comment Share on other sites More sharing options...
Caterpiggle Posted August 7, 2014 Share Posted August 7, 2014 Boot error on SI224.atr ? Corruption disk image ? Quote Link to comment Share on other sites More sharing options...
flashjazzcat Posted August 7, 2014 Share Posted August 7, 2014 Boot error on SI224.atr ? Corruption disk image ? It's not supposed to be bootable. Quote Link to comment Share on other sites More sharing options...
Caterpiggle Posted August 7, 2014 Share Posted August 7, 2014 Okay, will boot up DOS 4.5 ... Quote Link to comment Share on other sites More sharing options...
+bob1200xl Posted August 8, 2014 Share Posted August 8, 2014 It's in SpartaDOS format. Copy it to a DOS 2.0 disk or some such. Bob Quote Link to comment Share on other sites More sharing options...
Caterpiggle Posted August 8, 2014 Share Posted August 8, 2014 What version should I use SparatDOS format from Sparat OS ? Quote Link to comment Share on other sites More sharing options...
+bob1200xl Posted August 8, 2014 Share Posted August 8, 2014 I used SDX. The .ATR is in double density, but I just file copied it to a DOS 2.0 SD disk with SDX. Then, you can run it from any DOS. SD 3.x should work just as well. You can also run it from the original .ATR using SDX or SD 3.x. Is this what you are asking? Bob Quote Link to comment Share on other sites More sharing options...
