feoh Posted August 27, 2014 Share Posted August 27, 2014 Hi all! I'm trying to get jzintv going under OSX, this is the error I get when trying to run the binary: cpatti@quark: ~/Dropbox/Emulators/jzintv-1.0-beta4 $ bin/jzintv [11:45:57] dyld: Library not loaded: @rpath/SDL.framework/Versions/A/SDL Referenced from: /Users/cpatti/Dropbox/Emulators/jzintv-1.0-beta4/bin/jzintv Reason: image not found [1] 53430 trace trap bin/jzintv FAIL: 133 I do have SDL installed via homebrew: cpatti@quark: ~/Dropbox/Emulators/jzintv-1.0-beta4 $ brew install sdl [11:51:01] Warning: sdl-1.2.15 already installed cpatti@quark: ~/Dropbox/Emulators/jzintv-1.0-beta4 $ brew link sdl [11:51:06] Warning: Already linked: /usr/local/Cellar/sdl/1.2.15 To relink: brew unlink sdl && brew link sdl cpatti@quark: ~/Dropbox/Emulators/jzintv-1.0-beta4 $ and this is what otool -L says about required dependencies for the jzintv binary: cpatti@quark: ~/Dropbox/Emulators/jzintv-1.0-beta4 $ otool -L bin/jzintv [11:45:53] bin/jzintv: @rpath/SDL.framework/Versions/A/SDL (compatibility version 1.0.0, current version 12.4.0) /System/Library/Frameworks/AppKit.framework/Versions/C/AppKit (compatibility version 45.0.0, current version 1138.47.0) /System/Library/Frameworks/Foundation.framework/Versions/C/Foundation (compatibility version 300.0.0, current version 833.25.0) /usr/lib/libobjc.A.dylib (compatibility version 1.0.0, current version 228.0.0) /usr/lib/libgcc_s.1.dylib (compatibility version 1.0.0, current version 1094.0.0) /usr/lib/libSystem.B.dylib (compatibility version 1.0.0, current version 159.1.0) /System/Library/Frameworks/CoreFoundation.framework/Versions/A/CoreFoundation (compatibility version 150.0.0, current version 635.21.0) /System/Library/Frameworks/ApplicationServices.framework/Versions/A/ApplicationServices (compatibility version 1.0.0, current version 41.0.0) Does anyone have any clues as to how to get past this? I'd love to play with intybasic and maybe some Intellivision assembly. Thanks in advance! Quote Link to comment Share on other sites More sharing options...
moonlight_mile Posted August 27, 2014 Share Posted August 27, 2014 (edited) I always had trouble getting the jzintv command line stuff to work. There is a front end for it out there. It works most of the time but hangs once the rom/bin is loaded. It is called GUIINTV. I found it on a forum. Edited August 27, 2014 by moonlight_mile Quote Link to comment Share on other sites More sharing options...
feoh Posted August 27, 2014 Author Share Posted August 27, 2014 I always had trouble getting the jzintv command line stuff to work. There is a front end for it out there. It works most of the time but hangs once the rom/bin is loaded. It is called GUIINTV. I found it on a forum. Thank you! You've indirectly fixed my problem I installed GUIntv, which helpfully told me I needed to go grab SDL.frameowrk and install it into ~/Library/Frameworks Voila! jzintv is working for me now. Huzzah Quote Link to comment Share on other sites More sharing options...
moonlight_mile Posted August 27, 2014 Share Posted August 27, 2014 Glad it worked out for you. Quote Link to comment Share on other sites More sharing options...
