bogax Posted September 14, 2014 Share Posted September 14, 2014 (edited) A minikernel that displays two sqinty little 4 digit hexadecimal numbers (3 x 5 font) The numbers are in score with aux1 as the fourth byte/most significant byte Uses all the temp registers except temp7 all the score pointers and all the aux variables (but only aux1 needs to be persitent) Takes about 380 bytes It's not quite perfected I haven't managed to get the horizontal postioning to work so there's a bit of a gap in the middle of each of the four digits. I doubt it's much of any real use but it could be used to display memory addresses and such (or decimal numbers) fire will scroll the digits I've only tried it in Stella don't know if it would work on the real hardware. Ok, with SpiceWare's help I've fixed the gap I'd say 'now it's perfect' except I had to kludge it so much to get the timing right. The code is not as pretty and there's more asm (I was trying to keep that to an absolute minimum) Besides, I prefer the extra color clock gap between the bytes for hex. hex_minikernel_4.bas hex_minikernel_4.bin hex_minikernel_4_2.bas hex_minikernel_4_2.bin Edited September 14, 2014 by bogax 2 Quote Link to comment Share on other sites More sharing options...
+SpiceWare Posted September 14, 2014 Share Posted September 14, 2014 Looks fine on real hardware. There's 2 problems with your horizontal alignment. First problem is HMOVE is getting hit at the wrong time. I used Stella and did a trap on HMOVE to see when HMOVE was hit: You hit HMOVE at cycle 63. It needs to be hit at the start of a scanline, right after WSYNC. If you don't then the values in HMP0 and HMP1 will not give you the expected adjustment. The second problem is the HMPx values go in the upper nybble (the left hex digit), you have them in the lower nybble(the right hex digit) of the byte. I'm not familiar with doing a minikernel, but I took a look at your code and think if you change this: WSYNC = $00 GRP0 = $00 : GRP1 = $00 REFP0 = $00 : REFP1 = $00 NUSIZ0 = $02 : NUSIZ1 = $02 callmacro delay VDELP0 = $00 : VDELP1 = $00 : RESP1 = $00 : RESP0 = $00 HMP1 = $0B : HMP0 = $08 COLUP0 = $06 : COLUP1 = $06 : HMOVE = $06 p3lhi = lthi : p2lhi = lthi WSYNC = $00 to this: WSYNC = $00 GRP0 = $00 : GRP1 = $00 REFP0 = $00 : REFP1 = $00 NUSIZ0 = $02 : NUSIZ1 = $02 callmacro delay VDELP0 = $00 : VDELP1 = $00 : RESP1 = $00 : RESP0 = $00 HMP1 = $xx : HMP0 = $xx COLUP0 = $06 : COLUP1 = $06 p3lhi = lthi : p2lhi = lthi WSYNC = $00 : HMOVE = $00 your problems will be fixed. I put $xx for the HMPx values as you'll have to experiment with the values to see what's right. I use these constants in my assembly code when I'm updating the HMPx registers: HMOVE_L7 = $70 HMOVE_L6 = $60 HMOVE_L5 = $50 HMOVE_L4 = $40 HMOVE_L3 = $30 HMOVE_L2 = $20 HMOVE_L1 = $10 HMOVE_0 = $00 HMOVE_R1 = $F0 HMOVE_R2 = $E0 HMOVE_R3 = $D0 HMOVE_R4 = $C0 HMOVE_R5 = $B0 HMOVE_R6 = $A0 HMOVE_R7 = $90 HMOVE_R8 = $80 From here it looks like you can use those if you put <spaces>const in front of them: const HMOVE_L7 = $70 const HMOVE_L6 = $60 const HMOVE_L5 = $50 const HMOVE_L4 = $40 const HMOVE_L3 = $30 const HMOVE_L2 = $20 const HMOVE_L1 = $10 const HMOVE_0 = $00 const HMOVE_R1 = $F0 const HMOVE_R2 = $E0 const HMOVE_R3 = $D0 const HMOVE_R4 = $C0 const HMOVE_R5 = $B0 const HMOVE_R6 = $A0 const HMOVE_R7 = $90 const HMOVE_R8 = $80 To use them you'd do something like this: HMP1 = HMOVE_0 : HMP0 = HMOVE_R1 2 Quote Link to comment Share on other sites More sharing options...
Cybearg Posted September 15, 2014 Share Posted September 15, 2014 Sweet, thanks! Can we get some sample screenshots in the OP? Quote Link to comment Share on other sites More sharing options...
+Gemintronic Posted September 15, 2014 Share Posted September 15, 2014 This is 'bout it 'bout it! Straightaway I'm thinking of changing those numerals into words for an RPG menu! Hmmmn.. one of the nice things about the standard score_graphics.asm is that, if needs be, it's easy to edit the score directly from the source. Is there a way the data tables could use a style like this? .byte %01111110 .byte %01111110 .byte %01100110 .byte %01100110 .byte %01100110 .byte %01100110 .byte %01111110 .byte %01111110 Quote Link to comment Share on other sites More sharing options...
bogax Posted September 17, 2014 Author Share Posted September 17, 2014 This is 'bout it 'bout it! Straightaway I'm thinking of changing those numerals into words for an RPG menu! Hmmmn.. one of the nice things about the standard score_graphics.asm is that, if needs be, it's easy to edit the score directly from the source. Is there a way the data tables could use a style like this? .byte %01111110 .byte %01111110 .byte %01100110 .byte %01100110 .byte %01100110 .byte %01100110 .byte %01111110 .byte %01111110 Like lots (most?) problems in programming it's going to come down to trading off speed for memory. (and I was trying to fit as much as possible into bB with a minimum of asm) In this case speed is paramount so you're going to be throwing lots of memory at it. If you want the displayed text to be changeable that means RAM. So it's going to depend on exactly what you want and how many resources you want to devote to it. For the program as it stands the gap is built in. And it's limited to 16 characters. To change either would mean major restructuring and more memory (though not necessarily more RAM particularly if you don't need it to be so arbitrary/changeable, you probably won't be scrolling through long strings of text, but you could probably select among several fixed strings) What it boils down to is you could do a lot better than this but if you can live with the gap and 16 characters there's no reason you can't change the font to something else. (and it would probably not be to much trouble or use to much RAM to make the font selectable but the font uses 160 bytes) What exactly do you want? As for using binary just change the font tables hxr, hxl to binary instead of hex. Quote Link to comment Share on other sites More sharing options...
+Gemintronic Posted September 17, 2014 Share Posted September 17, 2014 Maybe I mis-read (as usual). I thought the font was stored here: data hxr $07, $02, $06, $07, $01, $07, $03, $07, $07, $07, $02, $06, $03, $06, $07, $07 $05, $06, $01, $01, $03, $04, $04, $01, $05, $05, $05, $05, $04, $05, $04, $04 $05, $02, $02, $07, $05, $06, $07, $02, $07, $07, $07, $06, $04, $05, $06, $06 $05, $02, $04, $01, $07, $01, $05, $04, $05, $01, $05, $05, $04, $05, $04, $04 $07, $07, $07, $07, $01, $06, $07, $04, $07, $06, $05, $06, $03, $06, $07, $04end asm if (<*) > (<(*+$50)) repeat ($100-<*) .byte 0 repend endifend data hxl $70, $20, $60, $70, $10, $70, $30, $70, $70, $70, $20, $60, $30, $60, $70, $70 $50, $60, $10, $10, $30, $40, $40, $10, $50, $50, $50, $50, $40, $50, $40, $40 $50, $20, $20, $70, $50, $60, $70, $20, $70, $70, $70, $60, $40, $50, $60, $60 $50, $20, $40, $10, $70, $10, $50, $40, $50, $10, $50, $50, $40, $50, $40, $40 $70, $70, $70, $70, $10, $60, $70, $40, $70, $60, $50, $60, $30, $60, $70, $40end I was hoping to edit that font 0-F to instead have 16 letters of my choosing. Static of course. Wouldn't want to change them on the fly. So, instead of data hxl $70, $20, blah it would look like data hxl %11100000, %00100000, blah That's assuming you stored the font in those data statements. That's a big assumption on my part. Quote Link to comment Share on other sites More sharing options...
bogax Posted September 17, 2014 Author Share Posted September 17, 2014 (edited) Maybe I mis-read (as usual). I thought the font was stored here: data hxr $07, $02, $06, $07, $01, $07, $03, $07, $07, $07, $02, $06, $03, $06, $07, $07 $05, $06, $01, $01, $03, $04, $04, $01, $05, $05, $05, $05, $04, $05, $04, $04 $05, $02, $02, $07, $05, $06, $07, $02, $07, $07, $07, $06, $04, $05, $06, $06 $05, $02, $04, $01, $07, $01, $05, $04, $05, $01, $05, $05, $04, $05, $04, $04 $07, $07, $07, $07, $01, $06, $07, $04, $07, $06, $05, $06, $03, $06, $07, $04 end asm if (<*) > (<(*+$50)) repeat ($100-<*) .byte 0 repend endif end data hxl $70, $20, $60, $70, $10, $70, $30, $70, $70, $70, $20, $60, $30, $60, $70, $70 $50, $60, $10, $10, $30, $40, $40, $10, $50, $50, $50, $50, $40, $50, $40, $40 $50, $20, $20, $70, $50, $60, $70, $20, $70, $70, $70, $60, $40, $50, $60, $60 $50, $20, $40, $10, $70, $10, $50, $40, $50, $10, $50, $50, $40, $50, $40, $40 $70, $70, $70, $70, $10, $60, $70, $40, $70, $60, $50, $60, $30, $60, $70, $40 end I was hoping to edit that font 0-F to instead have 16 letters of my choosing. Static of course. Wouldn't want to change them on the fly. So, instead of data hxl $70, $20, blah it would look like data hxl %11100000, %00100000, blah That's assuming you stored the font in those data statements. That's a big assumption on my part. Ah, I see, they are arranged like that sort of each column is a character binary_font_tables.txt Edited September 17, 2014 by bogax 1 Quote Link to comment Share on other sites More sharing options...
+Gemintronic Posted September 17, 2014 Share Posted September 17, 2014 I really appreciate that! I could even see this being used as a password entry screen kinda deal. Thanks bogax! Quote Link to comment Share on other sites More sharing options...
bogax Posted September 17, 2014 Author Share Posted September 17, 2014 Ah, I see, they are arranged like that sort of each column is a character This is easier to see just use search and replace to change the underscores to 0 and the hash marks to 1 hashmk_font_tables.txt 1 Quote Link to comment Share on other sites More sharing options...
+SpiceWare Posted September 17, 2014 Share Posted September 17, 2014 This is easier to see just use search and replace to change the underscores to 0 and the hash marks to 1 I use jEdit when I'm coding and recently added a new rule to my assembly-6502 mode file that does special syntax coloration on binary numbers. It makes it super easy to see the graphics in the binary values: A while back I did a bB mode file, if anybody's using it I'll see about updating it with the new binary coloration rule. Quote Link to comment Share on other sites More sharing options...
iesposta Posted September 18, 2014 Share Posted September 18, 2014 I use jEdit ... A while back I did a bB mode file, if anybody's using it I'll see about updating it with the new binary coloration rule. Please do! I tried a bit adding this and couldn't make it work. Quote Link to comment Share on other sites More sharing options...
+SpiceWare Posted September 18, 2014 Share Posted September 18, 2014 Please do! I tried a bit adding this and couldn't make it work. Done. Since the mode file's from 2006 I'm going to review the bB commands before I post the update as I know some new ones have been added. As an example, when I set that up only PLAYER0: thru PLAYER5: were supported (and it looks like I accidentally listed those twice!) while now it can go thru PLAYER9: Quote Link to comment Share on other sites More sharing options...
iesposta Posted September 27, 2014 Share Posted September 27, 2014 Done. Screen Shot 2014-09-18 at 10.54.34 AM.png ... Where is the XML file? Quote Link to comment Share on other sites More sharing options...
+SpiceWare Posted September 27, 2014 Share Posted September 27, 2014 (edited) Where is the XML file? 1) there are way more bB commands to review than I was expecting. 2) Last weekend I got sidetracked trying to figure out how to get some of the colorization rules to be case-sensitive. The 6507 opcodes can be anything, LDA is just as good as lda, but the TIA registers like GRP0 and COLUP0 must be all caps. Basically I wanted to make it so that GRP0 would get colorized but not grp0. Didn't have any luck, as far as I can tell the case-senstive setting is global, meaning all or nothing. 3) new computer - I'm still migrating my programs and data over, don't even have jEdit installed on it yet. I did get StarCraft 2 migrated over and damn, does it look sweet! My 2008 MacBook Pro had to have all the settings at minimum, when SC2 realized it was on new hardware it changed them all to the max. 4) iOS training courses - I bought the iOS 8 course when I saw it on a preorder special for $79 back on the 8th. It included the iOS 7 course for free as the iOS 8 course wasn't out yet (being a preorder and all). Today they offered up their game course for free if you tweeted about it - so yeah, I ended up with $1497 in courses for $79 + a Tweet! I'm about 25% done with the iOS 7 course, haven't started the other two yet. I plan to get jEdit installed this weekend and will back out the failed case-sensitive attempt. I've decided to skip the bB command review, and just rely on feedback for missing commands from actual bB coders like yourself, so I can get it posted quicker. Edited September 27, 2014 by SpiceWare Quote Link to comment Share on other sites More sharing options...
iesposta Posted September 27, 2014 Share Posted September 27, 2014 Thanks for the detailed explanation! iPhone maybe you just forgot to attach a file. Wrong! Quote Link to comment Share on other sites More sharing options...
+SpiceWare Posted September 27, 2014 Share Posted September 27, 2014 Actually I should have swapped #3 and #4. The slow performance of my MacBook Pro while taking the online course (with Xcode and the iOS simulator running at the same time) was big part of why the Mac Pro was purchased. Quote Link to comment Share on other sites More sharing options...
+SpiceWare Posted September 27, 2014 Share Posted September 27, 2014 Where is the XML file? Blog entry is now up. Quote Link to comment Share on other sites More sharing options...
