bugbiter Posted September 22, 2014 Author Share Posted September 22, 2014 I already tried several patterns with mediocre success. Instead of a 'dit dit.. dit dit..' sound I now get 'dit dit dit', But I want the fast 'dididididit' as when normally loading data. There seems to be no resource as to what pattern exacltly Dos 2.5 for example hard formats the sector order. The strotmann document explains a lot but claims the sectors are numbered 1-18 in a straight circle (including sector 19 which is not used) but I am sure it must be kinda half-turn interleaved just comparing spin frequency and beeping rate. Does anyone know more about the interleave layout? I think it's key for mastering this issue. Quote Link to comment Share on other sites More sharing options...
Rybags Posted September 22, 2014 Share Posted September 22, 2014 Dos doesn't specify the interleave. In the vast majority of drives it's in a fixed order, and nothing you can do to get it to format differently other than something like a Happy board or modified firmware. I still think you're way better off using a buffer, and if you start doing compression stuff you'll need that and more anyway and your IO speed problem will also potentially get worse. Quote Link to comment Share on other sites More sharing options...
1050 Posted September 23, 2014 Share Posted September 23, 2014 __________________________CUSTOM FORMATCommand: f($66)AUX 1: --not used--AUX 2: --not used--Notes: This command formats a disk in single/double/enhanced density modes AND allows the user to specify the sector ordering. The computer sends a data frame of 128 bytes to the drive. The first 12 bytes are the configuration bytes, and the next 18-26 bytes are the sector numbers in order. The STANDARD sequences are as follows: Single density 17,15,13,11,9,7,5,3,1,18,16,14,12,10,8,6,4,2. Double density 18,17,16,15,14,13,12,11,10,9,8,7,6,5,4,3,2,1. Enhanced density 1,3,5,7,9,11,13,15,17,19,21,23,25,2,4,6,8,10,12,14,16,18,20,22,24,26. The standard ULTRASPEED sector skews are: Single density 4,8,12,16,1,5,9,13,17,2,6,10,14,18,3,7,11,15 Double density 1,14,9,4,17,12,7,2,15,10,5,18,13,8,3,16,11,6 Enhanced density 4,8,12,16,20,24,1,5,9,13,17,21,25,2,6,10,14,18,22,26,3,7,11,15,19,23. Text version of SpartaDOS Construction Set manual. You want info, this is chock full of it. http://atariage.com/forums/topic/226714-spartados-32d-manual-or-help/?do=findComment&comment=3014356 Quote Link to comment Share on other sites More sharing options...
Rybags Posted September 23, 2014 Share Posted September 23, 2014 Really, I see absolutely no sense in pissing about with custom formats. It won't make it much faster, you'll gain much more by doing layout and I/O optimisations in the program and pic format. Plus, it'll make no difference in emulation and probably run worse on stock drives. Quote Link to comment Share on other sites More sharing options...
Heaven/TQA Posted September 23, 2014 Share Posted September 23, 2014 don't see the point either... except for academic researches... memory layout reorganisation plus using packer would make more sense... Quote Link to comment Share on other sites More sharing options...
flashjazzcat Posted September 23, 2014 Share Posted September 23, 2014 Yep: Sledgehammer and nut spring to mind. Quote Link to comment Share on other sites More sharing options...
bugbiter Posted September 23, 2014 Author Share Posted September 23, 2014 (edited) OK, well. I'll rearrange the Picture data so it can be loaded into memory in one go. I dont think I can get it faster than this. I only have to pause once to slip one pic into the RAM under the ROM. And I won't be using any buffer at all, I'll make a custom boot disk, using SIO calls (jsr diskinv), pointing the buffer address directly to target memory. (Ain't that called burst mode?) Edited September 23, 2014 by bugbiter 1 Quote Link to comment Share on other sites More sharing options...
ricortes Posted September 23, 2014 Share Posted September 23, 2014 One of the things I haven't seen mentioned yet is custom sector layouts are hardware specific with respect to speed. If you use the USD ultra speed layout it will actually be slower on a stock 1050 or 810. IIRC: diskinv only works for 128 byte sectors. A custom boot disk is a fine choice since you can have the widest hardware compatibility with that format. Quote Link to comment Share on other sites More sharing options...
