ianoid Posted September 25, 2014 Share Posted September 25, 2014 Specifically, what hardware do you use regularly for your Apple II'n? I have going: Enhanced //e with 80 column/128K Apple Color Monitor Apple Mouse Card 2x Disk ]['s with Apple's Disk Interface card Phasor sound card by AE CFFA3000 with disk select switch and 4gb CF card with the entire Asimov archive. Took a while to unzip much of it. Wico joystick port replicator with Apple II Wico joystick Planning to mess with an EDD+ soon, but not sure if that will be for my regular setup as I'm afraid discerning copy protection on original disks may dislike it as a pass-through card. Of course it should be good for copying those disks. And also planning on putting in an AE transwarp, although I'm also wondering if that will be ok with the CFFA and for regular gaming- don't want super speed messing things up. 1 Quote Link to comment https://forums.atariage.com/topic/230113-what-rig-you-runnin/ Share on other sites More sharing options...
Arbee Posted September 25, 2014 Share Posted September 25, 2014 (edited) I honestly do the majority of my Apple II stuff in MESS - daily-driving your own work is a good way to stay ahead of bugs That said, my real Apple II rig: - IIgs ROM 03 in a "Woz" case, 4 MB RAM expansion, AppleColor RGB monitor - AE upgraded power supply - 7 MHz ZipGS - 1 Apple 3.5 Drive, 1 Apple 3.5" SuperDrive (and controller card), 1 AE 1600k 3.5" drive, 1 UniDisk 5.25 - CFFA3000 - Sonic Blaster stereo/sampling card - Off-brand serial port MIDI interface I also have a Video Overlay Card and a RamFAST Rev. D which I'm not currently using. Edited September 25, 2014 by Arbee Quote Link to comment https://forums.atariage.com/topic/230113-what-rig-you-runnin/#findComment-3079604 Share on other sites More sharing options...
+FujiSkunk Posted September 25, 2014 Share Posted September 25, 2014 My "regular" machine at this point is an Apple IIc, no frills. In storage have a couple of IIe's with a nice assortment of upgrade cards, including the Applied Engineering RamWorks III memory upgrade and the power supply to match. I also have a IIGS tucked into a corner. I logged a lot of hours on a IIe in high school and college, though I'm afraid they don't get much use nowadays. I'll never give them up, though. Quote Link to comment https://forums.atariage.com/topic/230113-what-rig-you-runnin/#findComment-3079651 Share on other sites More sharing options...
The Usotsuki Posted September 26, 2014 Share Posted September 26, 2014 I got a //e Platinum here, but don't use it much as 3 of the keycaps were destroyed. Most of the time I use AppleWin. Quote Link to comment https://forums.atariage.com/topic/230113-what-rig-you-runnin/#findComment-3079785 Share on other sites More sharing options...
20ohm20 Posted September 29, 2014 Share Posted September 29, 2014 Currently: Non-enhanced //e Amdek 300A amber monochrome monitor MemoryMaster //e (80 columns + 128K RAM) Grappler+ (parallel port card) Apple Super Serial Card (used mostly with ADTPro and rarely with a Hayes Smartmodem 1200) Apple disk interface card Apple Disk ][ floppy drive x2 Apple Imagewriter dot matrix printer Apple joystick (the one with gray buttons, I think it's actually called a "Joystick //e") Quote Link to comment https://forums.atariage.com/topic/230113-what-rig-you-runnin/#findComment-3081914 Share on other sites More sharing options...
Osgeld Posted September 30, 2014 Share Posted September 30, 2014 IIc, virtual serial host and a 13 inch HDTV Quote Link to comment https://forums.atariage.com/topic/230113-what-rig-you-runnin/#findComment-3082470 Share on other sites More sharing options...
Keatah Posted September 30, 2014 Share Posted September 30, 2014 I had (still have) all my Apple II rigs from back in the day. A II+ and and //e. Periodically I'll power them up from time to time for a Sunday drive. But today, mostly, it's AppleWin for convenience and testing and all that. My original Apple II+ rig which I still have today: Apple II+ 48K base RAM LowerCase chip Videx Keyboard Enhancer II (with type ahead buffer!) Videx Function Strip kit for the Enhancer II Switchable shift-key jumper mod Switchable vsync-wire mod Internal speaker - external speaker audio jack switch Joyport joystick extension cable switchable analog or digital sticks T.G. Products Joystick (2-button, 2-axis) T.G. Products Paddle set Koala Pad (cheap analog graphics tablet, but ohh so cool!) Sup'R'mod RF Modulator Kensington System Saver 16K Microsoft RamCard (Language Card) Grappler+ parallel printer interface Practical Peripherals MicroBuffer external parallel printer buffer 64K Epson MX-80 F/T dot matrix printer w/GrafTrax III roms Hayes MicroModem II w/MicroCoupler 110/300 baud Videx VideoTerm 80 column card Microsoft Softcard Z80 First Class Peripherals Sider SASI 10MB HDD Disk II controller with 2 Disk II drives Applied Engineering TimeMaster II H.O. clock card Panasonic cassette recorder Juliette hi-fi stereo receiver + 8-track tape player Sony KV1222R television set Various cables and other bits of hardware to help bring it all together. The above was/is pretty much my day-to-day configuration for the longest time. Sometimes I'd swap in and out various bits of hardware on an as-needed basis such as: Apple-Cat II modem (Bell Standard 202 half duplex 1200) -212 Expansion card (Bell Standard 212 full duplex 1200 baud) -Slot Saver power supply tap cable -Firmware chip -DTMF Dual Tone Multi-Frequency Decoder chip -Handheld telephone headset -Expansion module connector panel -Introl X-10 BSR connector -RS-232 connector Mountain Computer Expansion Chassis (needs mod for //e) Mountain Music System + Alpha Syntauri keyboard Gibson Light Pen system ComputerEyes digitizer Apple Silentype printer Apple Super Serial Card Mountain ROM+ card Videx UltraTerm Mountain RomWriter EDD+ card Corvus Constellation 5MB and 11MB HDD + VCR backup Video Overlay card //e Diagnostics card and rom kit CFFA3000 Apple Graphics Tablet Disk II diagnostics card A.E. Z80 Plus Transwarp II accelerator card 3.6MHz Wildcard II Mockingboard + 2x speech chips MicroSCI 64K/80Column card Apple Numerical Keypad //e Enhancement kit (65c02 + MouseText character set + updated ROM) A.E. Ramworks III card + RGB kit IEEE-488 GPIB instrument interface Apple Mouse card with single-button mouse Disk II exerciser card CFFA 1st version from the early dot-com era. Assortment of ZipChips and RocketChips Amdek 300 color monitor Commodore 1084S monitor Modified Disk II drive with 7-segment red LED track/sector indicator My own custom A/D and D/A cards from the laser laboratory I also have 2 custom ultra-super-prototype rare-beyond-rare cards. I made them. heh heh.. These cards were unique in that that they didn't do a whole lot except provide some relay controls, A/D, D/A and input/output functionality, bus access, that sort of thing. The real value was in all the make-believe and science experiment stuff I got into. This was truly the best of times. I'm sure there are other more minor things and add-ons that I'm forgetting at the moment. Anyways, when I upgraded to my //e all of this hardware came along and I still have it all. When I got interested in the //e I immediately discovered it had built-in lower case capability and working shift-keys. Also a combination 64K/80Column card gave 80-column text and a total of 128K system memory. I was simply blown away! And I remember pestering my parents for money to get the //e and my "selling point" was that the keyboard was so much nicer and that I could work more efficiently and write better software. I made some big stink about having direct access to the "[" and "]" and "_" keys instead of having to type CHR$ codes. It was a technical thing which sounded impressive to them no doubt. And the following were no longer needed in a //e rig: Microsoft 16K RamCard Videx LowerCase chip Videx VideoTerm 80 column card Videx Keyboard Enhancer II (not //e compatible) Videx Function Strip kit (not compatible) Shift-key wire mod Vsync wire mod (not compatible) With the //e's Aux Slot you could connect up a RamWorks card with a total of 6MB and RGB card, but I didn't go that route till much later. I was happy with the common 128K for a long time. Add-in hardware that is //e specific: MicroSCI 64K/80Column card //e Enhancement kit (65c02 + MouseText character set + updated ROM) Ramworks III card + RGB kit Apple Mouse card with single-button mouse Apple Numerical Keypad Along the way, but with considerably less fanfare, I acquired a //C, //C+, ///, ///+, Platinum //e, and finally a IIgs. With all the trimmings and upgrades of course. Z-Ram, Transwarp GS, Phasor, GS-Ram.. All that stuff. For the /// systems it would be a Monitor ///, Profile 5MB, some external drives.. You get the idea. Mostly my contemporary working system is very simple: Platinum //e 64K/80Column card 2 drives and a controller card Super Serial Card + cable 2-button, 2-axis joystick Any VDT/CRT/LCD monitor that happens to be available Software I keep at the ready in a little brown cardboard box: Ciderpress Apple Commander AppleWin emulator ADTpro The standard Windows File Explorer built into your PC Apple Dos 3.3 System Master (August 1980) Apple IIe DOS 3.3 System Master 1983 Copy II Plus 5.5 Copy II Plus 8.4 Copy II Plus 9.1 ProDos 1.1.1 basic & startup disk ProDos 1.1.1 user’s disk ProDos 8 v2.0.3 system disk 4.0 ProDos 8 v.2.0.3 basic v1.5 David-Dos installation disk Diversi-Dos installation v4.1-C Manuals I keep handy: Apple II Reference Manual Apple //e Reference Manual The Dos Manual The Applesoft Tutorial The DOS Programmer's Manual Understanding the Apple II and //e ProDOS User's Manual Applesoft Basic Programming Reference Manual Beagle Bros. Chart - Apple Colors & ASCII Values Beagle Bros. Chart - Peeks, Pokes, and Pointers Beagle Bros. Chart - Apple Commands With just those few pieces of hardware, software, and documentation you are completely prepared for loads of fun and can experience a huge range of Apple software from day one up to now. What? No CFFA3000 in there? Why of course I have one.. And I highly recommend it! But it isn't in my contemporary system because I'm stubbornly old school and somehow, unapologetically, unabashedly, I prefer using the SSC and ADTPro to get my data to and from the system. Especially when I'm on a nostalgia trip. I just think it's great that this hardware is fully functional, today, 35+ years after it was made. I don't have to worry about having an internet connection, no updates, no patches, no hassles. And I'm completely confident it will last another 50 years, or more! Quote Link to comment https://forums.atariage.com/topic/230113-what-rig-you-runnin/#findComment-3082571 Share on other sites More sharing options...
Charlie_ Posted September 30, 2014 Share Posted September 30, 2014 Never was an Apple II user. Only picked up a few IIc computers over the last couple years. I really liked the IIc, small, built in disk drive and composite out. It got me interested enough to get a IIgs. I like the IIgs a lot. I have a 3.5 disk drive and a 5.25 disk drive. RGB monitor. Also a 4mb SIMM card inside for ram. I don't have the IIgs keyboard or mouse. What I have is from a later Mac. I'd like to get the proper KB and mouse one day, but when sold alone they seem to go for a lot of money. I would also like another 3.5 disk drive. I check ebay ever now and then, but never see one priced well. Quote Link to comment https://forums.atariage.com/topic/230113-what-rig-you-runnin/#findComment-3082749 Share on other sites More sharing options...
Blackbag Posted October 2, 2014 Share Posted October 2, 2014 In my home office I have a IIc with 3.5" disk drive and connected to a VGA input on one of my monitor's via Nishida's VGA adapter. I've claimed a small corner in my basement storage area and have the rest of my Apple II set ups-- currently, a ROM1 IIgs with CFFA3 and zip chip and a platinum IIe with CFFA3 and 8mhz zip chip. I have a second IIe that I've been tinkering with-- It's my frankenstein rig. Whatever hardware seems interesting goes into here for testing/coding/playing. So far, I've been messing with the EDD4+ card, the AppleCat modem, and mocking board, wildcard and A2pi. When not in hardware, I'm playing around in Virtual II for the Mac or Applewin on the PC. Quote Link to comment https://forums.atariage.com/topic/230113-what-rig-you-runnin/#findComment-3084265 Share on other sites More sharing options...
potatohead Posted October 3, 2014 Share Posted October 3, 2014 I'm running a //e enhanced (my favorite one), with disk drive, joystick, super serial, CFFA. Two displays connected at the same time, one high resolution composite amber, the other an 80's era color TV that I've tweaked nicely. I keep flirting with a GS. One of these days. One day, I'll get a sound and mouse card. If I'm coding or learning small things, testing, etc... I do it on the real machine. It's just fun. If it's something more significant, I use emulation. Been doing some assembly lately, and I really like the Apple native machine environment. Quote Link to comment https://forums.atariage.com/topic/230113-what-rig-you-runnin/#findComment-3084918 Share on other sites More sharing options...
Keatah Posted October 3, 2014 Share Posted October 3, 2014 Been doing some assembly lately, and I really like the Apple native machine environment. Most everyone I knew back in the day, gamer, cracker, user, budding neophyte.. They were all fascinated by the native monitor, whether they understood it or not. The Apple II user interface (for its time) was simple enough, and challenging enough. You could grow with it. Quote Link to comment https://forums.atariage.com/topic/230113-what-rig-you-runnin/#findComment-3084943 Share on other sites More sharing options...
Hatta Posted October 3, 2014 Share Posted October 3, 2014 Pretty basic here. No pun intended. IIgs&CFFA3000. Would like to have a mockingboard or clone at some point. Not using it for apps, so I doubt I'll ever get an accelerator. Quote Link to comment https://forums.atariage.com/topic/230113-what-rig-you-runnin/#findComment-3085000 Share on other sites More sharing options...
Keatah Posted October 3, 2014 Share Posted October 3, 2014 I thought I'd simplify my previous post. Most of my current activities involving the Apple II are done with AppleWin emulator and Ciderpress on a Windows XP machine. I'd guess over 95%. I do this for speed and convenience and portability when out and about. And to save wear and tear on my original hardware. Software: AppleWin emulator Ciderpress Apple Commander ADTpro comm-0-comm The standard Windows File Explorer built into PC Apple Dos 3.3 System Master (August 1980) Apple IIe DOS 3.3 System Master 1983 Copy II Plus 5.5 Copy II Plus 8.4 Copy II Plus 9.1 ProDos 1.1.1 basic & startup disk ProDos 1.1.1 user’s disk ProDos 8 v2.0.3 system disk 4.0 ProDos 8 v2.0.3 basic v1.5 David-Dos installation disk Diversi-Dos installation v4.1-C Hyper-DOS ProTerm 2.1 Novation Com-Ware 5.0 The Einstein Compiler Beagle Bros. Compact Lisa 2.5D S-C Assembler II v4.0 Blank DOS 3.3 formatted image Blank ProDOS formatted image 5MB ProDOS 8 v2.0.3 formatted HDD image A folder containing a changing selection of games and other stuff. Documentation: Apple II Reference Manual Apple //e Reference Manual The Dos Manual The Applesoft Tutorial The DOS Programmer's Manual Understanding the Apple II and //e ProDOS User's Manual Beneath Apple DOS Beneath Apple ProDOS Applesoft Basic Programming Reference Manual Beagle Bros. Chart - Apple Colors & ASCII Values Beagle Bros. Chart - Peeks, Pokes, and Pointers Beagle Bros. Chart - Apple Commands Assembly Language Programming for The Apple II Hayes Micromodem II and Apple-Cat II manuals That's the basics! Of course I can pull out my original stuff at any time and play with the real thing. And when I do, it typically consists of all the above, real original disks with original printed documentation and the following hardware: Enhanced Apple //e 64K/80Column card 2 standard drives and a controller card Super Serial Card + cable Paddles Koala pad 2-button, 2-axis joystick Hayes Micromodem II Complete Apple-Cat II setup Sider 10MB HDD TimeMaster II H.O. clock Grappler+ card and Epson MX-80 F/T Graftrax III printer Any VDT/CRT/LCD monitor that happens to be available, or Old Betsy. Quote Link to comment https://forums.atariage.com/topic/230113-what-rig-you-runnin/#findComment-3085134 Share on other sites More sharing options...
BurritoBeans Posted October 16, 2014 Share Posted October 16, 2014 I have a nice little Apple II+ setup next to my PC. Apple II+ -Microtek BAM-16 -Videx VideoTerm 80 Column Card -Hayes MicroModem II -Disk II Interface Card -Grappler card 2x Disk II Drives Monitor /// Epson MX-100III Paddles Joystick 3 Quote Link to comment https://forums.atariage.com/topic/230113-what-rig-you-runnin/#findComment-3093472 Share on other sites More sharing options...
MarkO Posted October 17, 2014 Share Posted October 17, 2014 I have been an Apple ][ used since JAN-1982, and an Owner since NOV-1983. I have an Apple ][, an Apple ][+, ( non-working ), Eight or So Apple ][e's or Apple //e's plus Two Enhanced Apple //e Motherboards and Two Apple ][gs, a ROM-00 that is flaky, and the board replaced with a ROM-01, and a ROM-03 that won't boot, Battery Damage to the Board, I have another ROM-01 Board to install in it... Here are my Apple ][e's I have setup and normally use. One is pretty much dedicated to testing unknown Hardware.. It is called The "Smoke" Test Machine. I have a bunch of Peripherals, including around 10 Super Serial Cards, Three AE RAMWORKS III cards, one with a Color Link card, and One RAMWORKS II card, plus Six or so Apple 64K 80 Column cards, Disk Controller Cards, a couple Apple Parallel Printer Cards ( not yet tested ) , Jameco 64K 80 Column cards ( not yet tested ), and a Teknika MA-RGB7 Card. Late last year, I bought Two CFFA3000 Run 3 cards, with the external selectors. More of my Apple ][ stuff and Classic Computer Desk is here. I also have a few specialty cards, like a TRIAC Card and a John Bell A+D/D+A Card ( not yet tested ) that uses the ADC0817CCN chipNS_ADC0816CCN.pdf. In addition, I have some Vernier Boxes that will work with any computer with a 2400bps RS-232 Port. I also use AppleWin on Windows for quick testing and when I am away from my Apple ]['s. I have Disks and Paper Documentation I need to Duplicate and Scan, and get uploaded to the Various Apple ][ sites, because I haven't found some of them out there in the Wild.. MarkO Quote Link to comment https://forums.atariage.com/topic/230113-what-rig-you-runnin/#findComment-3093809 Share on other sites More sharing options...
Tempest Posted October 17, 2014 Share Posted October 17, 2014 Let's see: Enhanced //e with 80 column/128K Apple Color Monitor Duo Drive (5.25") Mockingboard Uther Ethernet card Mach III Joystick Quote Link to comment https://forums.atariage.com/topic/230113-what-rig-you-runnin/#findComment-3093968 Share on other sites More sharing options...
SSG Posted February 15, 2015 Share Posted February 15, 2015 I have a: Apple 2+ 64k Apple Language Card Micro-SCI Dual Drive Card 2 Micro-SCI 5.25in Drives Super Joy - I Joystick There is also some thing inside on the side of the case labeled "Chanel 33 Mod" Here is a video I made awhile back. https://www.youtube.com/watch?v=DO26CLTsqQI I still have no clue what it is! Quote Link to comment https://forums.atariage.com/topic/230113-what-rig-you-runnin/#findComment-3178278 Share on other sites More sharing options...
potatohead Posted February 16, 2015 Share Posted February 16, 2015 (edited) That is an RF modulator set for the UHF bands, not the VHF TV bands. In short, you use it just like the channel 3 or 4 type modulators that are common, only tune channel 33! Back in the day, this was a great choice as there were few signals in that range. Clean, clear, easy RF. These days, there are signals, but that little modulator has a nice, strong output. I recall it being pretty damn good for a modulator, and it was built for the Apple ][ funky video and generally performs well compared to other modulators. Composite TV input was not common when the Apple ][ series hit the market, though it was very common for the business type monochrome monitors. You can get an RCA cable and plug one end into the connector you showed us, the other can go into an Atari VCS style "Game Box" for use with a TV that has the cable type connector, or the older two screws type. Edited February 16, 2015 by potatohead Quote Link to comment https://forums.atariage.com/topic/230113-what-rig-you-runnin/#findComment-3178441 Share on other sites More sharing options...
Muzz73 Posted February 17, 2015 Share Posted February 17, 2015 I used to have various ][+, //e and //gs systems over the years, but my favorite was: Enhanced //e Ramworks II w/256K Two Disk ][ drives Grappler ][+ parallel card Apple Super Serial card Apple Hi-Speed SCSI card I was always on the lookout for that elusive Mockingboard or Phasor, but never ended up with one. Now, I have an iLamp that just runs Virtual ][ all the time. My current setup is: iMac G4 (800MHz) w/768MB RAM, OS 10.4 (Tiger) and a 32GB solid state drive running as an: Enhanced //e w/256K RAM Two Disk ][ drives Mockingboard (stereo) Not perfect, but it'll do for now... 1 Quote Link to comment https://forums.atariage.com/topic/230113-what-rig-you-runnin/#findComment-3179622 Share on other sites More sharing options...
BassGuitari Posted February 20, 2015 Share Posted February 20, 2015 I've got a few different Apple rigs:1.) Apple IIe, Monitor II, DuoDisk2.) Apple IIe, Zenith Data Systems monitor, Disk II (x2)3.) Apple IIe Platinum, ColorMonitor IIe, 5.25" Floppy Drive (the later beige model)4.) Apple IIc, Monitor IIcI dunno about the cards in the IIe systems, though. Haven't been under the hood in a while. I know the Disk II/Zenith system is the most "tricked out"; it's got a Super Serial card, a 64K/80 Col. card, a printer card, and obviously a disk controller card, and maybe some other random crap. The others are a little more bare-bones.I'd love to get a II+ though. I don't need three IIes. 1 Quote Link to comment https://forums.atariage.com/topic/230113-what-rig-you-runnin/#findComment-3182216 Share on other sites More sharing options...
MarkO Posted February 22, 2015 Share Posted February 22, 2015 (edited) I used to have various ][+, //e and //gs systems over the years, but my favorite was: Enhanced //e Ramworks II w/256K Two Disk ][ drives Grappler ][+ parallel card Apple Super Serial card Apple Hi-Speed SCSI card I was always on the lookout for that elusive Mockingboard or Phasor, but never ended up with one. << SNIP >> I agree with that system... My original Apple ][e, had 64K and the 1K 80 Column Card, and One Disk ][, but I bought a Second Drive, a RAMWORKS III that came with 256K , and I filled out to 1 MB, a Practical Peripherals Serial/Parallel Microbuffer with 64K, a Super Serial Card and the 65C02 Enhancement Kit, which never got installed. I bought other cards too, AE Z80 card, Mouse and Card, Echo ][ Card.. That was all Back-in-the-Day... A couple years ago, I got an Echo +, which has the AY-3-8913 chips like the Mockingboard, but doesn't seem software compatible with it.. This last year I got a Mockingboard, and was referred to a person that has software for the Echo +... I need to make the Echo + disks and test Echo + part of it. I know the Echo ][ part works, since my disks for my Echo ][ work with it. MarkO Edited February 22, 2015 by MarkO 1 Quote Link to comment https://forums.atariage.com/topic/230113-what-rig-you-runnin/#findComment-3183193 Share on other sites More sharing options...
Nebulon Posted March 23, 2015 Share Posted March 23, 2015 - Apple IIe - Dual Disk II - Apple Monitor III (also have Color IIe, but prefer green display) - Realistic Analog stick - RAM/80 column card - Parallel card - Cooling fan (which I never use) There was other stuff, but I sold what I wasn't using. Quote Link to comment https://forums.atariage.com/topic/230113-what-rig-you-runnin/#findComment-3204378 Share on other sites More sharing options...
Baldrick Posted April 16, 2015 Share Posted April 16, 2015 (edited) Rig #1: Plain Vanilla IIc+ with two Apple 5.25" drives on a Commodore 1701 monitor - my daily driver Rig #2: - Case-less homebuilt "II+" clone based on a Unitron bare board and hand soldered (we were all pirates back then) - External apple compatible keyboard - several 16K language cards - several Disk II controllers, both apple and clone - six Disk IIs and three really sweet Chinon half height silent drives (I have a disk drive fetish - besides I used to run a GBBS based BBS back then) - several 80-column cards (two short Videx clones and one long Videx compatible) - Canadian made EPROM burner card (have three) - SSC - Parallel cards (two plus one below) - AE time II card with a parallel card with reprogrammed ROM to trick ProDOS into thinking it had a compatible clock - Wildcard copy card - VTech UDC universal drive controller (with dual DB-19 connectors) - SSM internal modem (not much use for that thing nowadays) - CH Products joystick and original black paddles - Commodore 1701 monitor (I know its a Commodore, but they were the best of their day made by JVC if I recall) Edited April 16, 2015 by Baldrick Quote Link to comment https://forums.atariage.com/topic/230113-what-rig-you-runnin/#findComment-3219837 Share on other sites More sharing options...
flanauf Posted April 17, 2015 Share Posted April 17, 2015 Wish i had money and space to spare, but here its: -Apple II GS , 4MB expansion, unisdisk adapter from Nishida -Apple IIc , plus one External drive Only other extar its two Atari to Apple II adapters . made locallly called AppleJoy. That and a whole lotta of love f course! Quote Link to comment https://forums.atariage.com/topic/230113-what-rig-you-runnin/#findComment-3220280 Share on other sites More sharing options...
