Kyle22 Posted February 5, 2017 Author Share Posted February 5, 2017 I did this, and it works fine with everything I tried, except of course software written using illegal opcodes, same as the 65802. The unusual part is that while it works, I discovered one side effect. Incognito almost if not always forgets its settings, but the clock is always correct. I have replaced the Lithium cell, and no change. It's no biggie because I put the 65802 back in. I just wanted everyone to know. Quote Link to comment Share on other sites More sharing options...
JamesD Posted February 5, 2017 Share Posted February 5, 2017 (edited) ... John Harris made some instructional posts a few years back when the company he was associated with did a 65C816 system. I think the memory move he posted was only 21 bytes vs. the ~40ish for a standard 6502. I know just using the 65C02 instruction set allows you to write ~5% tighter code. Overall the lower current, reduced code size and resultant faster execution just for adding a jumper and $10 processor seems like a real win. I think B&C has/had some of the old style boards for people that want to revert their 800 back to 6502B/65C816 for ~$15. ... This is the macro I used for my 64/80 column graphics text screen scroll. It's slower than an unrolled loop copying 16 bits at a time.. This is for the CA65 assembler. ;********************************************* ;* 65816 support ;********************************************* .if Use65816 = 1 .P816 ;Memory Move Negative. Move from hi to lo address. ;Memory is moved at the rate of seven clock cycles per byte. ; MVN increments the X and Y registers, and decrements A ; The non-maskable interrupt (NMIEN) must be disabled on the Atari unless ; you have your own interrupt handler to deal with 65816 code ;********************************************* .macro MOVEMEMN SourceAddress,DestAddress,BytesToMove,SourceBank,DestBank SEI clc xce ; native mode rep #$31 ; set A, X, and Y to 16 bit, clear carry .A16 ; Tell assembler Accumulator is 16 bit .I16 ; Tell assembler Index registers are 16 bit LDX #SourceAddress ; The source address for the memory move LDY #DestAddress ; The destination address for the memory move LDA #BytesToMove-1 ; The number of bytes we want to move + 1 because MVN needs it MVN SourceBank,DestBank ; RAM banks, should be 00,00 on 64K system ; sep #$31 ; set A, X, and Y to 8 bits, set carry xce ; emulated mode .A8 ; Tell assembler Accumulator is 8 bit .I8 ; Tell assembler Index registers are 8 bit CLI .endmacro .endif I also had to disable the Atari non-maskable interrupt before entering 16 bit mode. LDA #0 ; turn off ATARI non maskable display interrupts for 65816 STA NMIEN Edited February 5, 2017 by JamesD 1 Quote Link to comment Share on other sites More sharing options...
