ElectricLab Posted March 5, 2016 Share Posted March 5, 2016 (edited) Vorticon, I have three of these and have never flashed or updated their settings. It's probably a good idea to do so, but I thought I'd mention that you probably don't have to. I think the UDS device can work on 10.0.0.n, but if not, an alternative would be to create an additional 192.168.1.n network internally for it. If you have an old unused router/wifi box with ethernet ports, you could set it up to create another subnet in your house with its WAN address on the 10.0.0.n network and on its LAN side, have a 192.168.1.x network with DHCP, where you could connect the UDS. I skimmed the manual and I don't see that it MUST be on 192.n.n.n so perhaps it has been set to a fixed address and no DHCP in its former life. I'd do the factory reset and see if that allows it to get an IP address on your 10.0.0.n network. To confirm that it does, I'd NMAP your internal network before (see previous post) then plug in the Lantronix, wait 30 seconds, then NMAP again and look for a new host. Or - if there's a screen on your router that shows your DHCP clients/leases, you could find it there too. Edited March 5, 2016 by ElectricLab Quote Link to comment Share on other sites More sharing options...
+Schmitzi Posted March 5, 2016 Share Posted March 5, 2016 (edited) You can enter the monitor mode via serial cable. Do the same as decribed before, and at the point of "xxx" type "xx2". Then you should be in monitor mode, and now enter the command "NC" to get into the network-config menu. (if xx2 does not works try xx1, but it IS xx2 IIRC) Edited March 5, 2016 by schmitzi Quote Link to comment Share on other sites More sharing options...
+Schmitzi Posted March 5, 2016 Share Posted March 5, 2016 PS I have opened a brand new USD-10 now, and copied the CD. it is crap only oon it, really. So, there´s no .HEX-file. I have uploaded the CD as a ZIP to the toxic server (but forget about I go on the search for the .HEX now Quote Link to comment Share on other sites More sharing options...
+Schmitzi Posted March 5, 2016 Share Posted March 5, 2016 ...with this reset button, maybe there is on of this "tricks", pressing it for 15 seconds or so? No .HEX-file found, and no infos... maybe just rename the ltx5805.rom to ltx5805.HEX ? uuuuuah if yes Quote Link to comment Share on other sites More sharing options...
+Schmitzi Posted March 5, 2016 Share Posted March 5, 2016 . ♫ tataaa ♫♪ somebody needs a hex-file ? LTX5805-HEX.zip (There was a Rom-2-Hex-tool on the lantronix-server. worx. ) Quote Link to comment Share on other sites More sharing options...
+InsaneMultitasker Posted March 5, 2016 Share Posted March 5, 2016 Then, if re-powered up again, just watch your DHCP-Server for the new IP-address. (Or just directly try to change the IP-config, once you are in the serial setup-menu with HyperTerm ) My UDS periodically loses its assigned IP and reverts to DHCP. When this happens I log into my router, look at the connected devices, find the UDS entry, note the IP, then telnet into it with port 9999 It beats having to guess which address it was given. A program that scanned the local subnet would probably do the trick, too. 1 Quote Link to comment Share on other sites More sharing options...
+Schmitzi Posted March 5, 2016 Share Posted March 5, 2016 . Oh, my 2 productives ones never have lost anything. Do you use the actual firmware ? (5.8.0.5) Quote Link to comment Share on other sites More sharing options...
+Schmitzi Posted March 5, 2016 Share Posted March 5, 2016 ...as you know the mac address from your UDS, you also could look with arp -a for the ip address. Or make a small Batch like this, this directly shows the IP on screen: ARP -A | find "00-99-4a-f1-2c-c1"pause Quote Link to comment Share on other sites More sharing options...
Omega-TI Posted March 5, 2016 Author Share Posted March 5, 2016 There is an easier way. In fact this program will be mentioned in my updated version of gettig your TI on the Internet. No need to log into your router, once you download and install this, you'll always be just ONE CLICK AWAY from knowing everything on your your network. You'll even be alerted if any unauthorized users gain access. http://www.nirsoft.net/utils/wireless_network_watcher.html Quote Link to comment Share on other sites More sharing options...
+Schmitzi Posted March 5, 2016 Share Posted March 5, 2016 yes, but only works if the UDS is connected via WLAN. And you need a windows machine too, running this "WatchDog"..... I think the Batch is the easiest way, no need to install or config or run anything Only have to check once for the UDS´ MAC ah, I know NirSoft for this NK2edit. Very good tool for Outlook Quote Link to comment Share on other sites More sharing options...
Shift838 Posted March 5, 2016 Share Posted March 5, 2016 I have been unable to get my UDS-10 to show up in the device list with the Lantronix device installer. Any hints? Not knowing its IP address, I can't even access it via telnet... have you tried to hook it up to a serial port direct and holding down lower case 'x' while it powers up. once it powers up it should go into the setup via the serial port. Quote Link to comment Share on other sites More sharing options...
Shift838 Posted March 5, 2016 Share Posted March 5, 2016 The firmware file on the ftp site is a binary file. To flash the firmaware using the serial connection, I need the .HEX file (ASCII) which I can't seem to find. EDIT: I converted the binary file to ASCII HEX. Unfortunately, the UDS-10 monitor hangs when I enter the DL (download) command. I'm out of ideas at this point... It should not be that hard to set this up. this is the latest firmware out for the UDS10. I updated mine with this. Firmware_ltx5805.rom Quote Link to comment Share on other sites More sharing options...
+Vorticon Posted March 6, 2016 Share Posted March 6, 2016 have you tried to hook it up to a serial port direct and holding down lower case 'x' while it powers up. once it powers up it should go into the setup via the serial port. Yes, but the configuration menu I get is completely different from what it's supposed to be with no DHCP option and a fixed network base of 192.168, so I'm suspecting the units I have have special firmware installed. I broke down and bought another UDS-10 on Ebay which hopefully will have the standard firmware. Anybody wants my 2 current UDS-10's? Just pay for shipping Quote Link to comment Share on other sites More sharing options...
+Vorticon Posted March 6, 2016 Share Posted March 6, 2016 this is the latest firmware out for the UDS10. I updated mine with this. That's the one I have as well. My units hang when I issue the DL command though... Quote Link to comment Share on other sites More sharing options...
+Vorticon Posted March 6, 2016 Share Posted March 6, 2016 Vorticon, I have three of these and have never flashed or updated their settings. It's probably a good idea to do so, but I thought I'd mention that you probably don't have to. I think the UDS device can work on 10.0.0.n, but if not, an alternative would be to create an additional 192.168.1.n network internally for it. If you have an old unused router/wifi box with ethernet ports, you could set it up to create another subnet in your house with its WAN address on the 10.0.0.n network and on its LAN side, have a 192.168.1.x network with DHCP, where you could connect the UDS. I skimmed the manual and I don't see that it MUST be on 192.n.n.n so perhaps it has been set to a fixed address and no DHCP in its former life. I'd do the factory reset and see if that allows it to get an IP address on your 10.0.0.n network. To confirm that it does, I'd NMAP your internal network before (see previous post) then plug in the Lantronix, wait 30 seconds, then NMAP again and look for a new host. Or - if there's a screen on your router that shows your DHCP clients/leases, you could find it there too. I did think about doing that, but as a last resort. We'll see if my upcoming UDS-10 works out. Quote Link to comment Share on other sites More sharing options...
+Schmitzi Posted March 6, 2016 Share Posted March 6, 2016 Did you see my .HEX-File here ? Quote Link to comment Share on other sites More sharing options...
+Vorticon Posted March 6, 2016 Share Posted March 6, 2016 Did you see my .HEX-File here ? I did (thanks!) but I can't even send the file to the UDS-10 because it keeps on hanging with the DL command. 1 Quote Link to comment Share on other sites More sharing options...
budz2355 Posted March 7, 2016 Share Posted March 7, 2016 (edited) Okay dumb question time: I see the link for Disk Image file on Stuart's website. Normally when I download a .zip then I open ti99dir and convert the v9t9 files to TI files (and transfer blah blah) and done! ...However, when I extract the zip file it gives me a file Internet Browser V9.tidsk What do I do to this file to get it over to the TI? I know how to do the transfer using my PC and TIMXT, but do I need to convert the file or rename it or anything with ti99dir or..? EDIT: I can't spell extract (extra) Edited March 7, 2016 by budz2355 Quote Link to comment Share on other sites More sharing options...
+jedimatt42 Posted March 7, 2016 Share Posted March 7, 2016 I'm away from TI software right now, but I would assume you step into the .tidsk file in ti99dir like other .ark or .dsk image files. Then copy the contents to whatever you like. You might just need to rename the .tidsk to .dsk first. -M@ 1 Quote Link to comment Share on other sites More sharing options...
+Vorticon Posted March 7, 2016 Share Posted March 7, 2016 Also note that the disk image is DSDD. If you are planning on moving the disk image to a real TI disk, make sure that your disk controller can support that. The standard TI controller can only handle up to DSSD. Quote Link to comment Share on other sites More sharing options...
budz2355 Posted March 7, 2016 Share Posted March 7, 2016 My plan is to transfer the files to DSK5 which is my horizon ramdisk. I have a standard ti disk controller. Will this be a problem ? Quote Link to comment Share on other sites More sharing options...
+Vorticon Posted March 8, 2016 Share Posted March 8, 2016 My plan is to transfer the files to DSK5 which is my horizon ramdisk. I have a standard ti disk controller. Will this be a problem ? No because the ramdisk does not need the TI disk controller. It should be fine. Quote Link to comment Share on other sites More sharing options...
Stuart Posted March 8, 2016 Share Posted March 8, 2016 No because the ramdisk does not need the TI disk controller. It should be fine. However, the browser looks for the favourites files on a disk called 'BROWSER'. You probably won't be able to use the favourites file unless you name your ramdisk like this. (If I put the files on a DSSD-sized virtual disk, anyone know if that will still transfer and work on a NanoPEB?) Stuart. Quote Link to comment Share on other sites More sharing options...
+Vorticon Posted March 9, 2016 Share Posted March 9, 2016 I got my replacement UDS-10 and this one was a cinch to access and configure. It had DHCP already setup and it showed up in my list of connected devices on my home network. I accessed it via telnet and entered all the configuration options per Stuart's instruction on the web site. I won't have time to play with it though till tomorrow night, but hopefully it will work as advertised I sent my original UDS-10's to another TIer to see if he can get them configured. 3 Quote Link to comment Share on other sites More sharing options...
Omega-TI Posted March 9, 2016 Author Share Posted March 9, 2016 However, the browser looks for the favourites files on a disk called 'BROWSER'. You probably won't be able to use the favourites file unless you name your ramdisk like this. (If I put the files on a DSSD-sized virtual disk, anyone know if that will still transfer and work on a NanoPEB?) Stuart. Stuart, I've not used my Nano it quite a while, so I'm unsure, but if you use TI99Dir to make a new 1600 sector virtual disk and COPY the files to the new image, you'll have no problems at all. Quote Link to comment Share on other sites More sharing options...
