Bug Reports
CyranoJ
  • 1 month later...
.found a bug
Found in RaptorBASIC+ but believe it to be a Raptor issue. Similar to the first object in the list being inactive causing issues - if the last object in the list is set to inactive, the OP seems to get pwnd, causing masses of tearing in the top third of the screen and the 16kHz audio I have playing to sound garbled and as if it's being played massively time stretched.
Don't be scared STEP up to the plate and WIN
I became a Champion discovering bugs and over coming them, NOW it's ur turn
Anyone who doesn't know or ignores GGN's link... they are going to... going to think you... think you have gone and...
...just imagine how many shirts that might yield.
  • 4 weeks later...
Der Luchs has found another bug, due to the fact I modified the memorytrack code at the last minute to make it more flexible (originally it was hard coded to only load/save the highscore table)
Anyway, prior to calling raptor_MT_load or raptor_MT_save, make sure to set the following two longwords:
raptor_MT_save_length: Longword pointer to length of data to save (in bytes)
raptor_MT_start_address: Longword pointer to start of data to save
Edited by CyranoJ
Following the above, I've fixed the Memory Track example. Please find below:
EX-09b - MemoryTrack.zip
	jsr	RAPTOR_start_video		; start video processing
	tst.l	raptor_mt_present
	bmi	.no_mt
	move.l	raptor_highscores_hex,d1	; get the highscore
	move.l	#7,d4				; convert 8 digits
	lea	asc_high,a0			; store it here
	jsr     RAPTOR_HEXtoDEC			; call the conversion
	bra	.already_loaded
.no_mt:
	lea     raptor_highscores_hex,a0	; reset the highscore table (top 10)
	moveq	#9,d0				; 10 entries
.resettab:
	move.l	#1,(a0)+			; store 0 to the table
	dbra	d0,.resettab			; loop around
.already_loaded:
Note: It always was saving/loading to the MemoryTrack, but the main code reset the highscore table regardless (doh!) Anyway, this'll be changed in the next release, but the example is updated here in the meantime.
Enjoy.
  • 1 month later...
Whoops, bug-pocalypse!
RAPTOR_U235playsample - wasn't playing any sounds!
New RAPTOR.O and RAPTOR.INC attached here. Will update the main archive shortly.
RAPTOR-soundfix.zip
Note - this call takes an extra param in D2 which is Frequency<<16
	moveq	#0,d0		; play sample 0 (player shot)
	moveq	#4,d1		; on channel 4 (music is 0-3)
	move.l	#8000<<16,d2    ; frequency
	jsr	RAPTOR_U235playsample	; send command to U235
Thanks to Der Luchs for finding this.
RAPTOR-soundfix.zip
  • 1 year later...
