thegamezmaster Posted December 11, 2014 Share Posted December 11, 2014 Sorry if this has been asked before but do I have to use a Atari a/v cable only to get a composite a/v signal from the computer? Meaning can any other a/v cables be used or does it need to be an Atari computer A/v cable? If so where's the best place to get one? Thanks for any help! Quote Link to comment Share on other sites More sharing options...
thegamezmaster Posted December 11, 2014 Author Share Posted December 11, 2014 To clarify the problem is the channel 2-3 switch. Sometimes it works other times 3 is black and white and I have to move the switch to get color. Are these replaceable or how to fix. Can anyone help? Thanks! Quote Link to comment Share on other sites More sharing options...
Paul Westphal Posted December 11, 2014 Share Posted December 11, 2014 Throw some solder on the switch where it connects to the motherboard. If you can't solder, stuff a small piece of tin foil in there with a very small toothpick. If that doesn't work, get a new switch from best electronics. Quote Link to comment Share on other sites More sharing options...
russg Posted December 11, 2014 Share Posted December 11, 2014 To clarify the problem is the channel 2-3 switch. Sometimes it works other times 3 is black and white and I have to move the switch to get color. Are these replaceable or how to fix. Can anyone help? Thanks! if you're using the 2-3 switch, you're doing RF, not composite. Any RCA to RCA cable will do. The composite port is a round, five pin port. If you have a 600XL, you don't have a composite port. There are Atari RF cables with a little box that makes it 75ohm, which is the correct impedance for RF. I don't think there's much worse picture with a plain RCA to RCA cable, I could be wrong. Quote Link to comment Share on other sites More sharing options...
thegamezmaster Posted December 11, 2014 Author Share Posted December 11, 2014 Thanks for all the replies! Quote Link to comment Share on other sites More sharing options...
thegamezmaster Posted December 12, 2014 Author Share Posted December 12, 2014 Tried resoldering the switch no difference. Anyone know how much a replacement is? Quote Link to comment Share on other sites More sharing options...
_The Doctor__ Posted December 12, 2014 Share Posted December 12, 2014 Contact cleaner cleared a few of them up for me, make sure the switch is pointed down towards the floor... insert wand/stick spray slide re-insert spray slide, aim for the contacts not the plastic ... spray slide re-insert 1 Quote Link to comment Share on other sites More sharing options...
thegamezmaster Posted December 12, 2014 Author Share Posted December 12, 2014 Contact cleaner cleared a few of them up for me, make sure the switch is pointed down towards the floor... insert wand/stick spray slide re-insert spray slide, aim for the contacts not the plastic ... spray slide re-insert So should I take the switch out or disassemble? Not quite sure. Quote Link to comment Share on other sites More sharing options...
thegamezmaster Posted December 12, 2014 Author Share Posted December 12, 2014 (edited) Contact cleaner cleared a few of them up for me, make sure the switch is pointed down towards the floor... insert wand/stick spray slide re-insert spray slide, aim for the contacts not the plastic ... spray slide re-insert Sorry but not quite sure about your directions as how to do this. Do you do this with the switch still on the pcb? Do you disassemble it? Not sure where to insert the spray tube. Any help would be greatly appreciated with this! Edited December 12, 2014 by thegamezmaster Quote Link to comment Share on other sites More sharing options...
+bob1200xl Posted December 12, 2014 Share Posted December 12, 2014 I just work the switch back and forth a few dozen times. This wipes the contacts pretty well. Bob Quote Link to comment Share on other sites More sharing options...
thegamezmaster Posted December 12, 2014 Author Share Posted December 12, 2014 I just work the switch back and forth a few dozen times. This wipes the contacts pretty well. Bob Thanks, I'll try that! Quote Link to comment Share on other sites More sharing options...
_The Doctor__ Posted December 12, 2014 Share Posted December 12, 2014 You don't need to take it apart, having the switch facing down to the floor keeps the gloppy crap from runnin all ove the main board, examine it closely find the best spot to get the liquid into the switch, flush it with spray... sometimes the grease/lube hardens in these switches and won't just swipe away, that is why I use the contact spray. Quote Link to comment Share on other sites More sharing options...
thegamezmaster Posted December 12, 2014 Author Share Posted December 12, 2014 You don't need to take it apart, having the switch facing down to the floor keeps the gloppy crap from runnin all ove the main board, examine it closely find the best spot to get the liquid into the switch, flush it with spray... sometimes the grease/lube hardens in these switches and won't just swipe away, that is why I use the contact spray. Thanks for clearing that up for me! Quote Link to comment Share on other sites More sharing options...
