pacgreg Posted January 4, 2015 Share Posted January 4, 2015 I've set my mind on using the first 2 sprites to make my player character in this game not thinking of the consequences. How bad do you guys think the flicker is and is there a way to lessen it? I really like how it looks with two colors per line, and the horizontal flying sprite requires it to look even halfway decent, is removing Player1 the only way to fix it? Superman.bas.bin Quote Link to comment Share on other sites More sharing options...
+Random Terrain Posted January 4, 2015 Share Posted January 4, 2015 One way to do that is to accept the single color limitation. Quote Link to comment Share on other sites More sharing options...
iesposta Posted January 4, 2015 Share Posted January 4, 2015 Short answer to Is removing player 1 the only way to fix it?. Yes. Long answer: I love flicker, but unfortunately in this case it doesn't work well as it causes the big guy to become transparent when the flicker starts. In the DPC+ basic kernel you could use player 1's missile as a 2nd behind player 0 color, but it has to be a line or a square or a rectangle and will turn player 1's colors when horizontally across from player1, but it won't cause flicker but would turn Superman's cape/shorts green or purple. The ball can also be a line, square or rectangle and is the color of the Playfield. If you had a red Playfield and don't draw any Playfield the ball would be red. That leaves you with black or only a colored background. Quote Link to comment Share on other sites More sharing options...
pacgreg Posted January 5, 2015 Author Share Posted January 5, 2015 (edited) Thanks for the feedback, I guess I have to remake the sprites tp work with one player, might still use the ball to make the chest symbol since most of the playfield is close to the same color, but I think now the capes going to go. Edited January 5, 2015 by pacgreg Quote Link to comment Share on other sites More sharing options...
pacgreg Posted January 5, 2015 Author Share Posted January 5, 2015 Actually I think I want to convert the whole game to the standard kernel as I've never actually made a game in it, only DPC+, is it possible to use playercolors and no_blank_lines together? Quote Link to comment Share on other sites More sharing options...
+Random Terrain Posted January 5, 2015 Share Posted January 5, 2015 Is it possible to use playercolors and no_blank_lines together? Have you checked out the chart? randomterrain.com/atari-2600-memories-batari-basic-commands.html#kernelopchart Looks like you can only have one multicolored sprite. Quote Link to comment Share on other sites More sharing options...
