RXB Posted March 19 Share Posted March 19 1 minute ago, lucien2 said: The .gpl files are supposed to be the converted source files, ready to be assembled. Maybe the script is not working well with the RXB 2024 source files. Could you send the DV80 source files of RXB 2024C so I can try myself? Sure it is mostly finished. The DV80 files are in RXB GPL GROM The DOS TEXT files are in RXB GPL SOURCE TEXT RXB 2024C.zip 2 Quote Link to comment Share on other sites More sharing options...
lucien2 Posted March 19 Share Posted March 19 OK: source files converted. "srxb7" is the only file that has an error: "GETSPACE" is not defined. Unfortunately, all your nice formatting is lost during the conversion process. rxb 2024C xdt.zip 1 1 Quote Link to comment Share on other sites More sharing options...
RXB Posted March 19 Share Posted March 19 4 minutes ago, lucien2 said: OK: source files converted. "srxb7" is the only file that has an error: "GETSPACE" is not defined. Unfortunately, all your nice formatting is lost during the conversion process. rxb 2024C xdt.zip 213.67 kB · 0 downloads Yea here is the PREDEFINED SYMBOLS for Ryte Data GPL Assembler. ******************************************************************************** PREDEFINED SYMBOLS ******************************************************************************** Symbol Table #4 (Def,alpha) 0034 ACCTON 835C ARG 0032 ATN 0036 BADTON 003B BITREV 0012 CFI 0014 CNS 002C COS 0010 CSN 8372 DATSTK 0001 DIVZER 0003 ERRIOV 0006 ERRLOG 0005 ERRNIP 0002 ERRSNN 0004 ERRSQR 0028 EXP 834A FAC 0006 FADD 000A FCOMP 0009 FDIV 0008 FMUL 836C FPERAD 0007 FSUB 0038 GETSPACE 0022 INT 0010 LINK 0018 LOCASE 002A LOG 8370 MEMSIZ 003D NAMLNK 8300 PAD 0024 PWR 0012 RETURN 000B SADD 000F SCOMP 000E SDIV 8375 SGN 002E SIN 000D SMUL 8400 SOUND 0026 SQR 000C SSUB 837C STATUS 0016 STCASE 8373 SUBSTK 0030 TAN 0007 TRIGER 004A UPCASE 836E VSPTR 0001 WRNOV 837F XPT 837E YPT Can you imagine if that is the standard in C or other languages with no format settings. It would be impossible to debug or to even write the language. So I am going to have to stick with notepad and txt files as at least it is readable. Thanks for your help. Quote Link to comment Share on other sites More sharing options...
ralphb Posted March 20 Author Share Posted March 20 21 hours ago, RXB said: Does not fix srxb6.txt that crashes at END and I guess ralph is working on that one. Are you talking about assembling srxb6.txt and the error message about the END statement? That's because of a missing ; before the first * in line 1938. xga99 only recognizes * comments if the asterisk is in the first row, like with E/A. 1 Quote Link to comment Share on other sites More sharing options...
RXB Posted March 20 Share Posted March 20 (edited) 1 hour ago, ralphb said: Are you talking about assembling srxb6.txt and the error message about the END statement? That's because of a missing ; before the first * in line 1938. xga99 only recognizes * comments if the asterisk is in the first row, like with E/A. Hmm Ryte Data GPL Assembler did not care if the it was first one as * asterisk is the comment character just like ! or REM is for XB. Exactly the same as the original TI GPL Assembler for the 990 and the GPL Code for XB version 110 and TI GPL Manual and GPL Device Service Manual. Rather oddball is ; semicolon being used as comment symbol for GPL Source, that must come from something like Python or C or another language. I really like your GPL Assembler except for the strange changes like 2 spaces after a command or using a ; is just so weird since I have been writing GPL for over 35 years now. Can you think of a EA or GPL command that would begin with *something? Commands like CLR *R8 or CLR *>8300 so why would it matter if the second character is a * as it would not be valid as any command and only a comment! Edited March 20 by RXB missing text Quote Link to comment Share on other sites More sharing options...
Gary from OPA Posted March 20 Share Posted March 20 17 minutes ago, RXB said: Hmm Ryte Data GPL Assembler did not care if the it was first one as * asterisk is the comment character just like ! or REM is for XB. Exactly the same as the original TI GPL Assembler for the 990 and the GPL Code for XB version 110 and TI GPL Manual and GPL Device Service Manual. Rather oddball is ; semicolon being used as comment symbol for GPL Source, that must come from something like Python or C or another language. I really like your GPL Assembler except for the strange changes like 2 spaces after a command or using a ; is just so weird since I have been writing GPL for over 35 years now. Can you think of a EA or GPL command that would begin with *something? Commands like CLR *R8 or CLR *>8300 so why would it matter if the second character is a * as it would not be valid as any command and only a comment! too much white space before the * *********************************************************** * CPU PROGRAM FOR >8300 SCATCH PAD SUBROUTINE EXECUTE * *********************************************************** * AORG >8300 * CPUPGM DATA >8302 * CPUPGM DATA >8302 First address. * DATA >0420 * BLWP @>834A Switch contex * DATA >834A * FAC not used * DATA >04E0 * CLR @>837C Clear for GPL * DATA >837C * * DATA >045B * RT Return to GPL. * * END * *********************************************************** * CALL EXE(address[,...]) BL @address * *********************************************************** so its trying to figure out what the * is doing, it has to be the first character or there has to be command in front to be assembled. a indented * doesn't work. i been looking at this recently myself, as I have my SOB source code and my Pop-Cart source code, and I will to be able to assembled it both on my PC and also on real hardware using the same source files, so its a real pain in the ass since its not 100% the same. -- for now, I might stay just using my real ti99 setup, since i got it working again, all tho need to fix bugs on it as well it seems. oh'well. us GPL programmers are rare. 2 Quote Link to comment Share on other sites More sharing options...
RXB Posted March 20 Share Posted March 20 (edited) Yea you would think sticking to the the original TI standards for GPL would be pretty set in stone as TI invented GPL! Oh and the EA format too! Edited March 20 by RXB comment added Quote Link to comment Share on other sites More sharing options...
ralphb Posted March 20 Author Share Posted March 20 58 minutes ago, RXB said: Yea you would think sticking to the the original TI standards for GPL would be pretty set in stone as TI invented GPL! Oh and the EA format too! The problem with asterisk = beginning of comment is that * is also multiplication, so some sort of disambiguation has to be done. I'll try to make it more standards compliant. The thing with the spaces is my own doing, since I like to sprinkle in some spaces to make everything more readable (IMHO). My assembler also has a strict mode that uses the original parsing of E/A so that any space in the operand field introduces the comment field. For some reason, though, I never implemented the strict mode for xga99. I'll try to add it, though. 3 3 Quote Link to comment Share on other sites More sharing options...
RXB Posted March 22 Share Posted March 22 On 3/20/2024 at 11:31 AM, ralphb said: The problem with asterisk = beginning of comment is that * is also multiplication, so some sort of disambiguation has to be done. I'll try to make it more standards compliant. The thing with the spaces is my own doing, since I like to sprinkle in some spaces to make everything more readable (IMHO). My assembler also has a strict mode that uses the original parsing of E/A so that any space in the operand field introduces the comment field. For some reason, though, I never implemented the strict mode for xga99. I'll try to add it, though. So is the format thing fixed or am I forced to use this secondary tool to use your GPL Assembly? I am very impressed with the insane speed and very effective result of your version of GPL Assembly. But the Tool from Lucien2 makes my GPL code almost impossible to read and edit. Any progress is making it more standardized? Quote Link to comment Share on other sites More sharing options...
RXB Posted March 22 Share Posted March 22 OK now I have another problem the xga99 Assembly creates Binary files but they are not the same size as the files that the Ryte Data GPL Assembler Object files in size? In my Source Code I have AORG >1FE0 which should be jumping forward to >5FE0 from that location forward and seems to be ignore by the Binary code generated by XGA99? Which explains why the size is just wrong. Also why every time I try to make the RXB module it shows huge gaps in wrong locations and just wrong? Should I assemble RXB in one huge Source file? Can someone explain what is going on? Quote Link to comment Share on other sites More sharing options...
ralphb Posted March 23 Author Share Posted March 23 12 hours ago, RXB said: OK now I have another problem the xga99 Assembly creates Binary files but they are not the same size as the files that the Ryte Data GPL Assembler Object files in size? In my Source Code I have AORG >1FE0 which should be jumping forward to >5FE0 from that location forward and seems to be ignore by the Binary code generated by XGA99? Which explains why the size is just wrong. Also why every time I try to make the RXB module it shows huge gaps in wrong locations and just wrong? Should I assemble RXB in one huge Source file? Can someone explain what is going on? xga99 has two directives to specify where the code should be places: GROM and AORG. GROM <n> is for the GROM and <n> can be a number 0-7 or address >0000, >2000, ..., >e000. AORG is the the offset relative to that GROM, You only need GROM once per GROM, and then can use AORG to jump around. Maybe you need to adjust these, but you don't have to stick everything into one file. Also note that xga99 produces binaries (which you can use in Classic99 directly), not object code, so the sizes should be different. 13 hours ago, RXB said: Any progress is making it more standardized? Unfortunately, I'm very busy this weekend, but I hope to make the changes by the end of Easter. 2 1 Quote Link to comment Share on other sites More sharing options...
RXB Posted March 23 Share Posted March 23 7 hours ago, ralphb said: xga99 has two directives to specify where the code should be places: GROM and AORG. GROM <n> is for the GROM and <n> can be a number 0-7 or address >0000, >2000, ..., >e000. AORG is the the offset relative to that GROM, You only need GROM once per GROM, and then can use AORG to jump around. Maybe you need to adjust these, but you don't have to stick everything into one file. Also note that xga99 produces binaries (which you can use in Classic99 directly), not object code, so the sizes should be different. Unfortunately, I'm very busy this weekend, but I hope to make the changes by the end of Easter. Thanks for reply Ralph In making RXB using GPL most of my code was patching GPL so it was tons on AORG commands in GPL Assembler so address could remain the same for XB GPL and ROMs. Over time I have really reduced that number but many are still there for XB ROM routines mostly, or for tables that would be really hard to move. I did have one huge file at one time but the GPL Assembler would crash as way to many in symbol tables so I had to break it up for separate GROMs. I will be on ZOOM today at 11 AM and will show the problems I am having. Rich Quote Link to comment Share on other sites More sharing options...
ralphb Posted March 30 Author Share Posted March 30 (edited) On 3/23/2024 at 5:45 PM, RXB said: ... Hello Rich, I've added the strict syntax option, and also the extra symbols you listed (some were already included). Could you please try the attached version of xga99.py? To assemble your srxb*.txt files, you'll need to supply the -s (for strict syntax) and -R (for Ryte Data symbols) options: xga99.py -s -R srxbN.txt where N is the GROM number. Using -s and -R, you should not have to modify your sources, and you won't need Lucien's tool either. If everything is OK, I'll release a new version. In my call with Rich, I realized that Windows is trying to be clever now by interpreting the #! line at the start of each tool source file. This unfortunately means that I know have to release a special Windows version. EDIT: To clarify, please replace the the xga99.py file in your C:\xdt99\xdt99 directory with the attached xga99.py. xga99.py Edited March 30 by ralphb 6 1 Quote Link to comment Share on other sites More sharing options...
Gary from OPA Posted March 30 Share Posted March 30 1 hour ago, ralphb said: Hello Rich, I've added the strict syntax option, and also the extra symbols you listed (some were already included). Could you please try the attached version of xga99.py? To assemble your srxb*.txt files, you'll need to supply the -s (for strict syntax) and -R (for Ryte Data symbols) options: xga99.py -s -R srxbN.txt where N is the GROM number. Using -s and -R, you should not have to modify your sources, and you won't need Lucien's tool either. If everything is OK, I'll release a new version. In my call with Rich, I realized that Windows is trying to be clever now by interpreting the #! line at the start of each tool source file. This unfortunately means that I know have to release a special Windows version. EDIT: To clarify, please replace the the xga99.py file in your C:\xdt99\xdt99 directory with the attached xga99.py. xga99.py 80.22 kB · 2 downloads Can't wait to try this myself on my pop-cart and sob GPL files as the are huge and were an issue as well when assembling. I will update this thread after the easter weekend with my own results. Many thanks for working with @RXB to make this happen. 4 Quote Link to comment Share on other sites More sharing options...
RXB Posted April 2 Share Posted April 2 On 3/30/2024 at 9:46 AM, ralphb said: Hello Rich, I've added the strict syntax option, and also the extra symbols you listed (some were already included). Could you please try the attached version of xga99.py? To assemble your srxb*.txt files, you'll need to supply the -s (for strict syntax) and -R (for Ryte Data symbols) options: xga99.py -s -R srxbN.txt where N is the GROM number. Using -s and -R, you should not have to modify your sources, and you won't need Lucien's tool either. If everything is OK, I'll release a new version. In my call with Rich, I realized that Windows is trying to be clever now by interpreting the #! line at the start of each tool source file. This unfortunately means that I know have to release a special Windows version. EDIT: To clarify, please replace the the xga99.py file in your C:\xdt99\xdt99 directory with the attached xga99.py. xga99.py 80.22 kB · 3 downloads Ok thanks it works great!!!!! Here is the result and works wonderful! Rich RXB GPL Source Text.zip 6 1 Quote Link to comment Share on other sites More sharing options...
ralphb Posted April 3 Author Share Posted April 3 17 hours ago, RXB said: Ok thanks it works great!!!!! Here is the result and works wonderful! Rich RXB GPL Source Text.zip 587.57 kB · 4 downloads Very glad to hear that, Rich! And it was a fairly small change to make it work for you. 3 1 Quote Link to comment Share on other sites More sharing options...
ralphb Posted April 3 Author Share Posted April 3 I've just published a new release with the latest changes. Windows users should download the new archive xdt99-X.Y.Z-Windows.zip on the Release page. As Rich and I discovered in our Zoom call, Windows suddenly starts to interpret the #! line at the start of the file, but doesn't know what env is. 3 2 Quote Link to comment Share on other sites More sharing options...
Asmusr Posted April 3 Share Posted April 3 (edited) 3 hours ago, ralphb said: Windows suddenly starts to interpret the #! line at the start of the file Sorry, which file are we talking about, and when does it start to interpret it? Edit: I understand what we're talking about now, but it works fine for me in Windows 10. Edited April 3 by Asmusr 2 Quote Link to comment Share on other sites More sharing options...
ralphb Posted April 4 Author Share Posted April 4 12 hours ago, Asmusr said: Sorry, which file are we talking about, and when does it start to interpret it? Edit: I understand what we're talking about now, but it works fine for me in Windows 10. I'm talking about the main programs xas99.py, xga99.py and so on, which have this hash-bang-line at the top of the file to tell Linux (and I think macOS) how they are executed. Two weeks ago I was helping Rich with the installation of xdt99, and was very surprised when none of the tools could be started. A new window opened and immediately closed again. Only when we removed the first line was it working. Not sure what Rich is using, but I think it was also Windows 10. 🤷♂️ 1 Quote Link to comment Share on other sites More sharing options...
RXB Posted April 4 Share Posted April 4 27 minutes ago, ralphb said: I'm talking about the main programs xas99.py, xga99.py and so on, which have this hash-bang-line at the top of the file to tell Linux (and I think macOS) how they are executed. Two weeks ago I was helping Rich with the installation of xdt99, and was very surprised when none of the tools could be started. A new window opened and immediately closed again. Only when we removed the first line was it working. Not sure what Rich is using, but I think it was also Windows 10. 🤷♂️ Yea using Windows 10 PRO, AMD 12 core 3900 4ghz CPU, 32Gig RAM, ASUS 570 ROG motherboard, 2TB Rocket M2 Drive C, 1TB Rocket M2 Dive D, 8 TB WD HD, 10 TB WD HD, NVidia Super 2070 Video card. Quote Link to comment Share on other sites More sharing options...
