STGraves Posted January 26, 2015 Share Posted January 26, 2015 Hello I've been creating a simple game for the atari 2600, and I want to add background music, I've done it and I have the code, but i cannot get it to play when i wnat it, what can i do? rem ********************************** rem *<STGraves world> * rem *<Mata a cuernotrayamon * rem *antes que el a ti.> * rem *<agpkkck@gmail.com> * rem *<www.stgravesof.zz.vc> * rem ********************************** rem Create the title screen opening playfield: .XX.XXX.XX..XXX...XX..X.X.XXX.XX X....X.X....X..X.X..X.X.X.X..X.. .X...X.X.XX.XXX..XXXX.X.X.XX..X. ..X..X.X..X.X.X..X..X.X.X.X....X XX...X..XX..X..X.X..X..X..XXX.XX ................................ ....X...X.XXXX.XXX..X...XXX..... ....X...X.X..X.X..X.X...X..X.... ....X...X.X..X.XX...X...X..X.... ....X.X.X.X..X.X.X..X...X..X.... ....XX.XX.XXXX.X..X.XXX.XXX..... end rem Loop the screen until the spacebar is pressed title COLUBK = $00 COLUPF = $0E drawscreen if joy0fire || joy1fire then goto skiptitle goto title rem This function displays after the title is skipped skiptitle rem Colors COLUPF = $40 COLUBK = $C0 COLUP0 = 222 COLUP1 = $40 rem Player location player0x = 50 : player0y = 50 player1x = 20 : player1y = 20 rem Score setting and color score = 0 : scorecolor = $F8 rem Missle size and location missile1height=6:missile1y=255 NUSIZ0 = 25 rem Create a variable to keep up with lives a = 5 rem Create the playfield playfield: ..XX..XX..XX..XX..XX..XX..XX..XX XX..XX..XX..XX..XX..XX..XX..XX.. ..XX..XX..XX..XX..XX..XX..XX..XX XX..XX..XX..XX..XX..XX..XX..XX.. ..XX..XX..XX..XX..XX..XX..XX..XX XX..XX..XX..XX..XX..XX..XX..XX.. ..XX..XX..XX..XX..XX..XX..XX..XX XX..XX..XX..XX..XX..XX..XX..XX.. ..XX..XX..XX..XX..XX..XX..XX..XX XX..XX..XX..XX..XX..XX..XX..XX.. ..XX..XX..XX..XX..XX..XX..XX..XX end rem This main function is what loops constantly main rem This is the animation function animate rem This frame variable slows down the animation v = v + 1 rem This code animates the sprites if v = 7 && w = 0 then ax if v = 7 && w = 1 then bx if v = 7 && w = 2 then cx if v = 7 && w = 3 then dx goto nextstep rem These four sprites are different stages of the animation ax v = 0 w = 1 player1: %00011000 %01111110 %01111110 %01111110 %00100100 %11000011 %01000010 %11000011 end goto nextstep bx v = 0 w = 2 player1: %00011000 %01111110 %01111110 %01111110 %00100100 %11000011 %01000010 %11000011 end goto nextstep cx v = 0 w = 3 player1: %00011000 %01111110 %01011010 %01111110 %00100100 %11000011 %01000010 %11000011 end goto nextstep dx v = 0 w = 0 player1: %00011000 %01111110 %01011010 %01111110 %00100100 %11000011 %01000010 %11000011 end goto nextstep rem Create acorn sprite nextstep player0: %01111110 %01000010 %01011010 %11000010 %01100111 %11111110 %01010101 %10010010 end rem check to see if a missile has already been fired checkfire if missile1y>100 then goto skip missile1y = missile1y - 2 : goto draw rem if a missile hasn't been fired, then fire missile skip if joy0fire then missile1y=player0y-2:missile1x=player0x+4 rem Draw output to screen draw drawscreen rem Fix player wraparound bug if player0x < 8 then player0x = 8 if player0x > 150 then player0x = 150 if player0y < 8 then player0y = 8 if player0y > 84 then player0y = 84 rem Have player 1 chase player 2 if player1y < player0y then player1y = player1y + 1 if player1y > player0y then player1y = player1y - 1 if player1x < player0x then player1x = player1x + 1 if player1x > player0x then player1x = player1x - 1 player1x = player1x : player1y = player1y rem Detect missile collision with squirrel if collision(missile1,player1) then score=score+1:player1x=rand/2:player1y=0:missile1y=255:goto pointsound rem Detect squirrel collision with the acorn if collision(player0,player1) then score=score-1:player1x=rand/2:player1y=0:missile1y=255:a=a-1:goto deadsound rem joystick movements if joy0up then player0y = player0y-1 : goto skipmove if joy0down then player0y = player0y+1 : goto skipmove if joy0left then player0x = player0x-1 : goto skipmove if joy0right then player0x = player0x +1 : goto skipmove rem refresh the screen skipmove goto main rem Play point sound pointsound AUDV0 = 5 : AUDC0 = 8 : AUDF0 = 10 p = p + 1 drawscreen if p < 2 then pointsound p = 0 AUDV0 = 0 : AUDC0 = 0 : AUDF0 = 0 goto main rem Play dead sound deadsound AUDV1 = 8 AUDC1 = 6 AUDF1 = 12 p = p + 1 drawscreen if p < 5 then deadsound p = 0 AUDV1 = 0 : AUDC1 = 0 : AUDF1 = 0 if a = 0 then goto deadscreen goto main rem Create the dead screen deadscreen playfield: .................X.............. ................XXX............. .................X.............. .........XXXXXXXXXXXXXXXXX...... ........XX...............XX..... ........XX.X.X..XX..X..X.XX..... ........XX.X.X.X..X.X..X.XX..... ........XX..X..X..X.X..X.XX..... ........XX..X...XX...XX..XX..... ........XX...............XX..... ........XX...............XX..... end rem Loop the screen until the spacebar is pressed dead COLUBK = $40 COLUPF = $9A drawscreen if joy0down || joy1down then goto opening goto dead rem Create deadscreen sound deadssound dim musicPointer=a dim musicTimer=b dim beatPointer=c dim beatTimer=d dim tempaudv=t rem VOLUME DOWN AND SET CHANNELS AUDV0=0 AUDC0=10 AUDV1=0 AUDC1=8 rem INITIALIZE POINTERS AND TIMERS musicPointer=$FF musicTimer=0 beatPointer=$FF beatTimer=0 startLoop rem TIME TO UPDATE NOTE? if musicTimer = 0 then gosub changeMusicNote musicTimer = musicTimer - 1 if beatTimer = 0 then gosub changeBeatNote beatTimer = beatTimer - 1 drawscreen goto startLoop changeMusicNote musicPointer = musicPointer + 1 AUDF0 = musicData[musicPointer] tempaudv = 8 if musicData[musicPointer] = $FF then tempaudv = 0 AUDV0 = tempaudv musicPointer = musicPointer + 1 musicTimer = musicData[musicPointer] rem value is (2 * #_OF_NOTES) - 1 if musicPointer > 31 then musicPointer = #-1 return changeBeatNote beatPointer = beatPointer + 1 AUDF1 = beatData[beatPointer] tempaudv = 8 if beatData[beatPointer] = $FF then tempaudv = 0 AUDV1 = tempaudv beatPointer = beatPointer + 1 beatTimer = beatData[beatPointer] rem value is (2 * #_OF_NOTES) - 1 if beatPointer > 23 then beatPointer = #-1 return data musicData 18,26,-1,10,18,20,-1,40,15,26,-1,10,15,20,-1,40 16,26,-1,10,16,20,-1,40,17,26,-1,10,17,20,-1,40 end data beatData 120,2,-1,22,40,2,-1,10,120,2,-1,22,120,2,-1,10,40,2,-1,4,120,2,-1,16 end Quote Link to comment Share on other sites More sharing options...
+Random Terrain Posted January 27, 2015 Share Posted January 27, 2015 There are a lot of little things wrong with that program. You might want to look over the whole thing, step by step. For example, you never jump to startLoop, so the code in that section never runs. The code there should be in the main loop anyway, without an extra drawscreen. You also don't seem to set AUDC0 and AUDC1 for that section, so you're not going to hear much of anything, even if the code runs. You might want to put your DIMs near the beginning of the program so they can be found more easily and make sure that they are all indented. Quote Link to comment Share on other sites More sharing options...
