+CyranoJ Posted February 18, 2015 Share Posted February 18, 2015 (edited) Last one for a while. Don't want to burn out! Please, NO MORE requests, here, via email, or via PM. I will try and fix up the remaining unfinished games. 1-7 on the number pad to select weapons. Tap fire for shot, hold fire for weapon activation. The music came from here: http://4ksongspk.com/download/cybernoid-2-amiga-songspk.html - The musician is unknown, happy to credit if we find a name. Cyber2.rom Edited February 18, 2015 by CyranoJ 8 Quote Link to comment Share on other sites More sharing options...
omf Posted February 18, 2015 Share Posted February 18, 2015 Nice i enjoyed the cybernoid game series on the spectrum Quote Link to comment Share on other sites More sharing options...
doctorclu Posted February 18, 2015 Share Posted February 18, 2015 Thank you! (Didn't realize there was a sequel to this game). Quote Link to comment Share on other sites More sharing options...
Rick Dangerous Posted February 18, 2015 Share Posted February 18, 2015 Felyx!! This one needs the treatment Quote Link to comment Share on other sites More sharing options...
+CyranoJ Posted February 18, 2015 Author Share Posted February 18, 2015 Felyx!! This one needs the treatment It's a ROM. Good luck getting it onto a CD Quote Link to comment Share on other sites More sharing options...
ovalbugmann Posted February 19, 2015 Share Posted February 19, 2015 Nice! This is a good game. Quote Link to comment Share on other sites More sharing options...
+CyranoJ Posted February 19, 2015 Author Share Posted February 19, 2015 47 downloads. Seems a few people like the 'crappy 16 bit games' on the Jaguar, even if they'll never admit it 7 Quote Link to comment Share on other sites More sharing options...
Daniele Posted February 22, 2015 Share Posted February 22, 2015 It's a ROM. Good luck getting it onto a CD cyranoj files rom 4mb can not be converted with jiffi in cd? Quote Link to comment Share on other sites More sharing options...
Felyx Posted February 22, 2015 Share Posted February 22, 2015 (edited) Luck would be nice but magical wand highly appreciated Jiffi is a wonderful tool from Reboot but what it does is: - by passing the need for encription - loading what is on the CD on the 1Mo RAM of the Jaguar. Because of the second point, the use of Jiffi is limited to files up to 1Mo (others people: crush my head if i am wrong ) So roms can't be burned on CD-R by using Jiffi because of the too big size for the Jag RAM. Anothter reason would be that rom is not a file format Jiffi can convert into burnable .cdi files. To play thoses Rom there are 2 solutions: - loading the rom into a Skunkboard - playing the rom with an emulator such as Virtual Jaguar. The solution would be to create a "real" Jaguar CD ie without using Jiffi: the game is loading the files from the CD when needed so in that case 4Mo are not a problem anymore not even 650Mo...but it is more complicated (some would probably say "ass paining" or something like that ) Edited February 22, 2015 by Felyx Quote Link to comment Share on other sites More sharing options...
omf Posted February 22, 2015 Share Posted February 22, 2015 - loading what is on the CD on the 1Mo RAM of the Jaguar. Because of the second point, the use of Jiffi is limited to files up to 1Mo (others people: crush my head if i am wrong) the Jaguar has 2 meg of ram onboard To play thoses Rom there are 2 solutions: - loading the rom into a Skunkboard - playing the rom with an emulator such as Virtual Jaguar. there are 3 options +1 - burn eproms and solder them to a blank board or use a socketed board Quote Link to comment Share on other sites More sharing options...
Felyx Posted February 22, 2015 Share Posted February 22, 2015 True but that solution is like climbing the Everest from the northern face: it requires to have a rom flasher, to create or buy the PCB, to buy the chips (which are not very cheap ) and an empty cartridge shell. Nothing impossible and probably the smarter solution but I am afraid it doesn't worth compare to get a Skunkboard. Quote Link to comment Share on other sites More sharing options...
ggn Posted February 22, 2015 Share Posted February 22, 2015 (edited) Jiffi is a wonderful tool from Reboot but what it does is: - by passing the need for encription - loading what is on the CD on the 1Mo RAM of the Jaguar. Because of the second point, the use of Jiffi is limited to files up to 1Mo (others people: crush my head if i am wrong ) Quote the manual: File size limits enforced: a binary loaded to RAM (such as COFF or BJL) can't be bigger than 2080768 bytes and a ROM can't be bigger than 6MB. (actually in his latest experiments CJ was able to use the full 2mb RAM without any problems, but well, let's just play it safe and use only the upper 2080768 bytes) Edited February 22, 2015 by ggn 2 Quote Link to comment Share on other sites More sharing options...
omf Posted February 22, 2015 Share Posted February 22, 2015 True but that solution is like climbing the Everest from the northern face: it requires to have a rom flasher, to create or buy the PCB, to buy the chips (which are not very cheap ) and an empty cartridge shell. Nothing impossible and probably the smarter solution but I am afraid it doesn't worth compare to get a Skunkboard. everyone keeps saying the chips cos an arm and a leg, this is simply not true http://www.buyicnow.com/it.php?i=75 http://www.buyicnow.com/it.php?i=77 and if you want a flash alternative, these are direct replacements for 160's, obviously they are more as they are flash based and easily reprogrammed http://www.ebay.co.uk/itm/4pcs-MX29F1615PC-10-DIP-42-MX29F1615-ic-/321536057368?pt=LH_DefaultDomain_0&hash=item4add0ae018 1 Quote Link to comment Share on other sites More sharing options...
sh3-rg Posted February 22, 2015 Share Posted February 22, 2015 everyone keeps saying the chips cos an arm and a leg, this is simply not true http://www.buyicnow.com/it.php?i=75 http://www.buyicnow.com/it.php?i=77 Shhhh... you don't want your select VIP customers knowing that, keep it mysterious and kerching the living daylights out of them :0) 3 Quote Link to comment Share on other sites More sharing options...
rayik Posted February 22, 2015 Share Posted February 22, 2015 (edited) everyone keeps saying the chips cos an arm and a leg, this is simply not true http://www.buyicnow.com/it.php?i=75 http://www.buyicnow.com/it.php?i=77 and if you want a flash alternative, these are direct replacements for 160's, obviously they are more as they are flash based and easily reprogrammed http://www.ebay.co.uk/itm/4pcs-MX29F1615PC-10-DIP-42-MX29F1615-ic-/321536057368?pt=LH_DefaultDomain_0&hash=item4add0ae018 800 can be used for 160 also. An offer of $94 for quantity of 2 (50 pieces) will be accepted in this listing (In answer to the unasked question - for my use only) Edited February 22, 2015 by rayik 1 Quote Link to comment Share on other sites More sharing options...
sh3-rg Posted February 22, 2015 Share Posted February 22, 2015 (edited) In answer to the unasked question - for my use only) I don't think there's anyone left who cares to ask that question, I wouldn't give it a second thought. I think those kids wised up and realised it wasn't 1993 anymore and there's nothing special case about the open platform Jaguar. Pitchforks are for decorative use only now. Edited February 22, 2015 by sh3-rg 1 Quote Link to comment Share on other sites More sharing options...
omf Posted February 22, 2015 Share Posted February 22, 2015 800 can be used for 160 also. An offer of $94 for quantity of 2 (50 pieces) will be accepted in this listing (In answer to the unasked question - for my use only) 160's are for 4 meg games, 800's are for 2 meg games Quote Link to comment Share on other sites More sharing options...
+CyranoJ Posted February 22, 2015 Author Share Posted February 22, 2015 160's are for 4 meg games, 800's are for 2 meg games So that's where the max cash grab is. Right, I'll make sure all the roms are at least 2.01Mb from now on. 1 Quote Link to comment Share on other sites More sharing options...
Daniele Posted February 22, 2015 Share Posted February 22, 2015 So that's where the max cash grab is. Right, I'll make sure all the roms are at least 2.01Mb from now on. I have both the jagCD that skunkboard but 'more nice to have the CD with cover Quote Link to comment Share on other sites More sharing options...
rayik Posted February 23, 2015 Share Posted February 23, 2015 160's are for 4 meg games, 800's are for 2 meg gamesThank you omf. I figured out the header encryption, how to encrypt roms (using either univ.bin, tursi's fastboot.bin or jagcrypt with privated.key and publicd.key), how to convert .cof and memory loadable images to cart roms, flags for 8 bit v 16 bit rooms and load address in the header, but OMG mixed up 160 and 800 eeproms. While I had 31 successes, I had many failures. Now I know why. Been making 4Mb games today. The 93c86 was a very good purchase ? I don't think there's anyone left who cares to ask that question, I wouldn't give it a second thought. I think those kids wised up and realised it wasn't 1993 anymore and there's nothing special case about the open platform Jaguar. Pitchforks are for decorative use only now.Good to know. Most of the older posts I saw on AA that asked about eeproms was answered with hate and derision. Reading those made me not ask for help. Figuring things out through trial and error rather than look at a guide is a good way to learn something. I already own most Jag games. This was a challenge whch I enjoyed figuing out. 5 Quote Link to comment Share on other sites More sharing options...
+remowilliams Posted February 23, 2015 Share Posted February 23, 2015 I think those kids wised up and realised it wasn't 1993 anymore and there's nothing special case about the open platform Jaguar. No, they're just repeatedly packing themselves into worthless incremental iterations of increasingly pointless forums. 4 Quote Link to comment Share on other sites More sharing options...
doctorclu Posted February 24, 2015 Share Posted February 24, 2015 47 downloads. Seems a few people like the 'crappy 16 bit games' on the Jaguar, even if they'll never admit it If I had to set up an ST just to play it, well, maybe not. (Especially since I don't have an ST) But since the Jaguar is set up, and it's now a Jaguar game, sure I'll play it. Quote Link to comment Share on other sites More sharing options...
+save2600 Posted February 24, 2015 Share Posted February 24, 2015 I stopped downloading these after Rick Dangerous. Between certain games not having sound and/or borked controls, simply can't keep up with all the conversions! Very cool to see, but would be nice if they were all compiled (finished conversions only) on a single thread. Felyx's artwork is amazing too. Very, very cool combination of stuff going on here for the Jag to be sure. Quote Link to comment Share on other sites More sharing options...
+CyranoJ Posted February 24, 2015 Author Share Posted February 24, 2015 I stopped downloading these after Rick Dangerous. Between certain games not having sound and/or borked controls, simply can't keep up with all the conversions! Very cool to see, but would be nice if they were all compiled (finished conversions only) on a single thread. Felyx's artwork is amazing too. Very, very cool combination of stuff going on here for the Jag to be sure. Errr.. http://dbug.kicks-ass.net/ST2JAG/ST2JAG.php 3 Quote Link to comment Share on other sites More sharing options...
+save2600 Posted February 24, 2015 Share Posted February 24, 2015 Errr.. http://dbug.kicks-ass.net/ST2JAG/ST2JAG.php DOH! …close enough. And how. Love you man! Quote Link to comment Share on other sites More sharing options...
