Atarifever Posted February 21, 2015 Share Posted February 21, 2015 Hey. My sister gave me a 2600 her and her boyfriend found a couple years ago. It's a 4 switch woodgrain one. I kept it around now for a couple years and, to be honest, have not used it. When I go to play 2600, it's always through my 7800, and I have a couple of those. Anyway, there's a great local used game place that gives great money for old systems, and I'm going to sell it to them. However, the adapter has been missing apparently for years, and the guy who used to own it always used a universal 300ma adapter for it. The settings are for 4.5V, 6V, 7.5V, and 9V. When I test it out it works alright, but I'm getting some strange behaviour (is it called gray-out behaviour?). It doesn't completely shut down, but sometimes it resets or goes a little dark. It was set to 9V when I got it, and that's what they always used when they were kids. Is this an appropriate setting or adapter? Thanks. Quote Link to comment Share on other sites More sharing options...
+RichG1972 Posted February 21, 2015 Share Posted February 21, 2015 In the attached picture you will find what you need and here is the link where to get it: http://www.best-electronics-ca.com/2600_Tech_Tips.htm This is the part you need and they sell it: Atari US 2600 Power supply CO16353 / CA014034 $9.95 I would not recommend a Universal adapter because heaven forbid the switch on it accidentally gets bumped then the whole unit is fried, I did it once is how I know which is why when I found this place they are the sole people I deal with for anything Atari related in replacement parts Quote Link to comment Share on other sites More sharing options...
alex_79 Posted February 21, 2015 Share Posted February 21, 2015 However, the adapter has been missing apparently for years, and the guy who used to own it always used a universal 300ma adapter for it. The settings are for 4.5V, 6V, 7.5V, and 9V. When I test it out it works alright, but I'm getting some strange behaviour (is it called gray-out behaviour?). It doesn't completely shut down, but sometimes it resets or goes a little dark. It was set to 9V when I got it, and that's what they always used when they were kids. Is this an appropriate setting or adapter?9V dc is the correct setting, but 300 mA is a bit low for a 2600, it should be at least 500ma. The voltage might also vary a bit (I use a 7.5V regulated voltage with my 2600, so the 7805 power regulator runs cooler), but it's very important that the polarity is correct (center tip positive in this case), else you will damage the console. The problems you experience might also due to some aging components inside the console, like the power regulator or a capacitor. I would not recommend a Universal adapter because heaven forbid the switch on it accidentally gets bumped then the whole unit is fried On the universal power adapters I have, the voltage selection is made through a rotary switch that needs a screwdriver or another flat tool to operate, so it's unlikely to change the setting by accident. You can stick a piece of tape over the switch just to be sure. There are also fixed voltage power supply which will avoid the problem. Personally, I prefer a modern replacement over a part that, while original, has been in storage for 30 years and might have leaking caps or other damage due to time. Quote Link to comment Share on other sites More sharing options...
+SpiceWare Posted February 21, 2015 Share Posted February 21, 2015 (edited) I posted photos that might be helpful in a couple replies of this topic. The first reply shows how to decipher the output of a stock adapter (though in that case, not for the 2600). The second reply shows for the 2600. Edited February 21, 2015 by SpiceWare Quote Link to comment Share on other sites More sharing options...
