bageljt Posted February 27, 2015 Share Posted February 27, 2015 Hi- I have an Intv System III. I get black screen when I turn on console with cartridge in it. I plugged in the IMI-2 test cartridge. When I hit reset after that, I see the letter J repeated a bunch of times. Looking at the Intellivision Service Console, there is a J error described which says to replace U6, which is a solid state device. Any ideas on that? Thanks, -Jeff Quote Link to comment Share on other sites More sharing options...
HunterZero Posted February 27, 2015 Share Posted February 27, 2015 You've tried hitting reset immediately after you turn on the console with a game in? You almost always need to do this. Back out the cartridge a touch? Clean the port and check for bent connection pins? U6 is the sound chip. It also handles hand controller inputs. It is a GI AY-3-8914 and is unfortunately one of the ICs that commonly goes bad. Swapping this chip with known working is the obvious choice if you have a spare. Reseating and cleaning legs is another option. You could try turning on the console with one or both controllers disconnected. Black screen could be power. Check the voltages at the 5 pin ribbon connector and check the ribbon for continuity. - J Quote Link to comment Share on other sites More sharing options...
