IBP Posted April 3, 2003 Share Posted April 3, 2003 Last night I found a rom on the internet for dragon stomper - I have the original, I was just interested in trying the MAKEWAV utility. Anyway, it didn't work. That is, the conversion from bin to wav seemed to go alright, but the supercharger didn't register anything when I tried it. This is the first time I've tried the supercharger so it might not be working, I am going to try some of the tapes tomorrow. I wondered whether the wav was too fast for the supercharger to correctly register the bits. Anyone any ideas? Quote Link to comment Share on other sites More sharing options...
tkarner Posted April 3, 2003 Share Posted April 3, 2003 Instead of MakeWAV I use a different utility. I think it's called PlayBIN. It does the BIN to WAV conversion in realtime. So instead of storing WAVs on your hard disk at 2 megs each, you just store the 2 or 4k BINs. Once it's setup you just double click on a BIN filename and it plays it as a WAV. Never had a problem with doing it this way. PlayBIN also has a few options you can play with, including playback speed. That might solve the problem. To be safe I always playback at the slow speed (because who really cares if the load takes 6 seconds instead of 3?). You might also want to play with your soundcard's output volume. The Supercharger is sensitive to that. Tom Quote Link to comment Share on other sites More sharing options...
