dougdlux Posted April 19, 2015 Share Posted April 19, 2015 So I have come in search of an answer. Recently I scoured my aunts basement in search of trinkets and things due to her years of hoarding. Yardsale coming up and I wanted first dibs. So I came across a Sega Genesis that I used to play with my cousin 2 decades ago (time flies). Originally it was a single N64 game that caught my eye (no console, sadface), also a single SNES cart. Short story, I managed to snag the Genesis with around 14 games and an NES with 5 games. The NES works great after I replaced the 72 pin strip. It had a game sitting in it pushed down for what I guess is at least 10 years. But the Genesis isn't so lucky and it's so sad, I want to play Taz Escape from Mars, and Toy Story, and of course SONIC!! Ok, so. The console starts fine. Every cart works perfectly. So now I have the console on and I start a game. All is well. I play for 10 seconds and now the back button doesn't work? Or any random action button stops responding. If I push a button while the game is loading this also prevents that button from working. I have 3 controllers. 1 of which is completely dead. And the other 2 do the same thing. You start playing and its fine and then buttons become unresponsive. Is this a console problem? Controller problem? And can this be fixed? Please tell me it can. I'll be awfully sad if it's not a possible fix. Quote Link to comment Share on other sites More sharing options...
Nutsy Doodleheimer Posted April 19, 2015 Share Posted April 19, 2015 Did you check the controller port? Could be a bad pin. Quote Link to comment Share on other sites More sharing options...
dougdlux Posted April 19, 2015 Author Share Posted April 19, 2015 The pins all look in surprisingly good shape. Quote Link to comment Share on other sites More sharing options...
Gredler Posted April 21, 2015 Share Posted April 21, 2015 sounds to me that something spilled into the controller, and the contacts on the buttons are not clean enough to consistently make contact. Before jumping to any conclusions, I'd recommend a complete clean on the controller (board and membranes) Quote Link to comment Share on other sites More sharing options...
R.Bear Posted April 24, 2015 Share Posted April 24, 2015 (edited) I'd replace the controller. I've got a few Mega Drive/Genesis controllers which are going bad like that which I need to repair. Its usually residue build-up on the contacts on the controller board. Some Genesis controllers are just buit very badly as well, there are a few variations of the controllers internally. There is one that is known to be terrible. Edited April 24, 2015 by R.Bear Quote Link to comment Share on other sites More sharing options...
Jeremy Popp Posted April 24, 2015 Share Posted April 24, 2015 I rarely find a bad Genesis controller. Aside from taking it apart and cleaning everything with rubbing alcohol, you could also plug the controller in and out a dozen or so times. Occasionally you'll find dirt, residue and corrosion on the pins and connectors. I would imagine it's something simple since your problem is intermittent. If you truly think they are dead, I'll send you 1 working controller in exchange for your 3 bad ones. Of course if the Genesis is the problem, then that won't do any good. Quote Link to comment Share on other sites More sharing options...
Bruce Tomlin Posted April 25, 2015 Share Posted April 25, 2015 Try another controller first. If that doesn't work, you may have a bad controller port. I once found a Genesis 2 where half the connector pins (controllers, video, AND power) had cold solder joints. If you looked closely enough you could see a ring-shaped crack around the pin. So I just whipped out the soldering iron and reheated every one of the pins. Quote Link to comment Share on other sites More sharing options...
dougdlux Posted April 25, 2015 Author Share Posted April 25, 2015 OK. So I have taken into consideration the said tips. I went ahead and ebayed a pair of terribly cheap knockoffs. Don't hate me. lol. I only went with them because they were so cheap. If either of them work I will know if it's controllers or not. If it is the controllers, Jeremy I will gladely trade 3 for 1. If it's not the controllers I will need a new solder tip (something smaller, what I have is a giant tip) and I will try to reheat the pin bases. I will let you know when I have the controllers and/or tried reheating! Quote Link to comment Share on other sites More sharing options...
dougdlux Posted April 25, 2015 Author Share Posted April 25, 2015 (edited) Sorry, double posted. Edited April 25, 2015 by dougdlux Quote Link to comment Share on other sites More sharing options...
