Marius Posted May 7, 2015 Share Posted May 7, 2015 Hi all, and especially FJC, Last night (encouraged by my own enthusiastic words about the U1MB and SIDE2 combination in the IDE+ thread) I fired up my U1MB 800xl with SIDE2. It still works great, and you are right about the portability of apt CF cards. Now I simply detached the CF card from my IDE+ and I inserted in my SIDE2 and I simply continued working. I absolutely absolutely absolutely LOVE that. But now my question. Since this setup can run ATR files from the FAT32 loader, I was wondering: is there a way to mount an ATR in SDX like I can do with IDE+ 2.0? I found the ATRMNT on the CAR: in SDX, but on every ATR file it reports: Error mounting disk image. Am I doing something wrong, or is ATRMNT not for SIDE2? Is it possible in this setup? If yes, can the ATR files be on a SDFS 512bytes/sector partition? And if yes... can I mount more ATR's and swap them using the SIDE2 button? Let me know... This is getting really interesting. I didn't expect this to be cool, but I was WRONG! 1 Quote Link to comment Share on other sites More sharing options...
flashjazzcat Posted May 7, 2015 Share Posted May 7, 2015 ATRMNT for IDE Plus is completely incompatible with SIDE. I wrote my own tools to mount ATRs from the SDX command line under Utimate/SIDE. You'll find them on the APT toolkit disk and on some of the custom SDX builds on my website. There's also MATR, which has a nice UI, and the SIDE loader itself, of course. Lots of ways to mount ATRs. Quote Link to comment Share on other sites More sharing options...
drac030 Posted May 7, 2015 Share Posted May 7, 2015 There is no such thing as "ATRMNT" for IDE+. The tool is called ATRM, and it should not be on the CAR:, unless you put it there, and it of course should not be on the CAR: build for SIDE, since, as FJC said, the methods of mounting are not compatible between these two solutions. Quote Link to comment Share on other sites More sharing options...
flashjazzcat Posted May 7, 2015 Share Posted May 7, 2015 There is no such thing as "ATRMNT" for IDE+. The tool is called ATRM, and it should not be on the CAR:, unless you put it there, and it of course should not be on the CAR: build for SIDE, since, as FJC said, the methods of mounting are not compatible between these two solutions. Quite right. I responded to this thread on the phone at first and for some reason assumed ProWizard was referring to ATRM. ATRMNT is indeed a utility I wrote (rather longer ago than I can remember, it seems) for SDX which mounts an ATR on Ultimate/SIDE via the command line. I think the problem is that the OP is attempting to mount an ATR without first installing the FATFS.SYS driver, which anyway requires a FAT16 partition and not a FAT32 partition. ATRMNT works via the SDX filesystem until it makes an SIO call to the Ultimate PBI BIOS (in order to actuate the mount), so FATFS.SYS and a FAT16 partition is required. The other confusingly named tool MATR operates directly with FAT16/32 partitions, and requires no file system driver. It's all described in the manual on my website, which is fortunate given the inaccuracy of my memory. Quote Link to comment Share on other sites More sharing options...
Marius Posted May 7, 2015 Author Share Posted May 7, 2015 I know about ATRM. I use it a lot with IDE+ I would like to have such a tool for side2/u1mb without the need of fat 16 partition. Would that be an option or not? Quote Link to comment Share on other sites More sharing options...
flashjazzcat Posted May 8, 2015 Share Posted May 8, 2015 Just use the MATR tool: that requires no driver. Doesn't IDE Plus require ATRs to be contained in a volume readable by DOS? If so, a file system driver would seem a prerequisite, just as with ATRMNT. Quote Link to comment Share on other sites More sharing options...
