Intellfan Posted May 18, 2015 Share Posted May 18, 2015 Can I play this in the usa on 120 volt ? Quote Link to comment Share on other sites More sharing options...
+intvsteve Posted May 18, 2015 Share Posted May 18, 2015 Hmm.... I'll have to check in more detail. IIRC Japan runs 100V, and either 50 or 60 Hz, but the TV standard was NTSC. Not sure how the system would handle an extra 20V AC. 1 Quote Link to comment Share on other sites More sharing options...
Intellfan Posted May 18, 2015 Author Share Posted May 18, 2015 Hmm.... I'll have to check in more detail. IIRC Japan runs 100V, and either 50 or 60 Hz, but the TV standard was NTSC. Not sure how the system would handle an extra 20V AC.says 100 volts on bottom 50 or 60 hertz so not sure one thing i saw that wasdiffrent it say channel 1 or 2 not 3 or 4 Quote Link to comment Share on other sites More sharing options...
+intvsteve Posted May 18, 2015 Share Posted May 18, 2015 Ah, looks like in that case it won't work. Based on this. Some of the older TV tuner cards let you manually tweak these frequencies. That's how I do PAL testing. Old TV Terminator card on an old PC. And a transformer. 1 Quote Link to comment Share on other sites More sharing options...
Intellfan Posted May 18, 2015 Author Share Posted May 18, 2015 Bummer now I cant test Quote Link to comment Share on other sites More sharing options...
bradd1978 Posted May 18, 2015 Share Posted May 18, 2015 I have an Intellivision Bandai and it works just fine on my LCD. I'm in Canada ? it will run on 120V just fine For the RF signal though you need to set it to channel 95 or 96 if I remember correctly 1 Quote Link to comment Share on other sites More sharing options...
+intvsteve Posted May 18, 2015 Share Posted May 18, 2015 I have an Intellivision Bandai and it works just fine on my LCD. I'm in Canada it will run on 120V just fine For the RF signal though you need to set it to channel 95 or 96 if I remember correctly Looks like 1 -> 95 and 2 -> 96 according to this and this. Coolness! So as long as your TV supports those analog channels, sounds like you're set! 1 Quote Link to comment Share on other sites More sharing options...
+JasonlikesINTV Posted May 18, 2015 Share Posted May 18, 2015 Maybe a dumb question, but are the Bandai games any different? That is, will they play on a standard system? I have a few games and never tested them. I don't have the Bandai console, though. Quote Link to comment Share on other sites More sharing options...
pimpmaul69 Posted May 18, 2015 Share Posted May 18, 2015 Maybe a dumb question, but are the Bandai games any different? That is, will they play on a standard system? I have a few games and never tested them. I don't have the Bandai console, though.they should be no different. Japan is ntsc like the u.s. so its system is probably identical. Quote Link to comment Share on other sites More sharing options...
+JasonlikesINTV Posted May 18, 2015 Share Posted May 18, 2015 Ah, thanks for the info! Quote Link to comment Share on other sites More sharing options...
Intellfan Posted May 18, 2015 Author Share Posted May 18, 2015 Thanks for the info 95 and 96 it works i was about ready to tear into it . But tested and works great . If anyone is interested i am listing on ebay for 100 plus ship box is in bad shape has manual in OK shape and cord and tv switch Quote Link to comment Share on other sites More sharing options...
freewheel Posted May 18, 2015 Share Posted May 18, 2015 I'd be curious to see a pic of it. As for whether or not the games are the same - I'd say that due to the lack of a identified ROM variants, they almost certainly are the identical games. There just isn't that much undumped stuff out there anymore. Quote Link to comment Share on other sites More sharing options...
+JasonlikesINTV Posted May 18, 2015 Share Posted May 18, 2015 I'd be curious to see a pic of it. As for whether or not the games are the same - I'd say that due to the lack of a identified ROM variants, they almost certainly are the identical games. There just isn't that much undumped stuff out there anymore. eBay Auction -- Item Number: 261892648880 Quote Link to comment Share on other sites More sharing options...
