sparkdrummer Posted May 27, 2015 Share Posted May 27, 2015 Can I use one of my myarc hfdc just as a disk controller with no hard drive attached? Seems to me I remember having to add a switch or something to be able to do this? Quote Link to comment Share on other sites More sharing options...
Gazoo Posted May 27, 2015 Share Posted May 27, 2015 Can I use one of my myarc hfdc just as a disk controller with no hard drive attached? Seems to me I remember having to add a switch or something to be able to do this? ftp://ftp.whtech.com/Geneve/schematics/HFDC_hard_drive_bypass.txt 3 Quote Link to comment Share on other sites More sharing options...
sparkdrummer Posted May 27, 2015 Author Share Posted May 27, 2015 Thanks oh great and powerful Gazoo! Quote Link to comment Share on other sites More sharing options...
+mizapf Posted May 27, 2015 Share Posted May 27, 2015 Where is U21? I can only find M21 on the schematics. (Beside the fact that someone should redraw those schematics ...) Quote Link to comment Share on other sites More sharing options...
sparkdrummer Posted May 27, 2015 Author Share Posted May 27, 2015 I actually did an image search on google with ti-99/4a hfdc and found an image that was large enough for my tired old eyes to see. It's on the left side. Quote Link to comment Share on other sites More sharing options...
Gazoo Posted May 27, 2015 Share Posted May 27, 2015 It's near the large set of dip switches as I recall. Gazoo Quote Link to comment Share on other sites More sharing options...
+mizapf Posted May 27, 2015 Share Posted May 27, 2015 Oh, I did not even remember that I once put a photograph on ninerpedia: http://www.ninerpedia.org/index.php/Floppy_Disk_and_Hard_Disk_Controller_Cards U21 is one of the two CRU read interface chips; the schematics hints at a ground connection on that pin. That is, if pin 1 is grounded this should have an effect when reading that CRU bit (e.g. by TB 3), but it has no effect on the other circuits on the controller. So this seems to me like an undocumented feature in the DSR. Interesting - maybe I should add that switch to the MESS emulation as well. 1 Quote Link to comment Share on other sites More sharing options...
+InsaneMultitasker Posted May 27, 2015 Share Posted May 27, 2015 Oh, I did not even remember that I once put a photograph on ninerpedia: http://www.ninerpedia.org/index.php/Floppy_Disk_and_Hard_Disk_Controller_Cards U21 is one of the two CRU read interface chips; the schematics hints at a ground connection on that pin. That is, if pin 1 is grounded this should have an effect when reading that CRU bit (e.g. by TB 3), but it has no effect on the other circuits on the controller. So this seems to me like an undocumented feature in the DSR. Interesting - maybe I should add that switch to the MESS emulation as well. Here is the corresponding EPROM Code from SECTORIOx. You can reduce the delay by modifying the loop counter or eliminate the test altogether with the hardware mod. WATDR1 EQU 3 IF "1" THEN WAIT FOR READY, IF "0" THEN DON'T WAIT * NOW TEST TO SEE IF THE DRIVE IS READY ONLY DO THIS FOR DRIVE 1 C @VOLUME,@H0001 JNE DRVRDY ABS @WAITD1 JNE DRVRDY SETO @WAITD1 MAKE IT NON ZERO TB WATDR1 TEST IF WE SHOULD WAIT FOR DRIVE 1 TO BE READY JNE DRVRDY IF 1 THEN WAIT, IF 0 THEN GO ON LI R5,75 WTRDY BL @SETDRV USES R0 AND R2 MUST BE SET BL @READR9 USES R0 TEST READY SLA R0,3 JNC WTRDY2 THE DRIVE SAID IT WAS NOT READY BL @READR9 SLA R0,3 TEST READY JOC DRVRDY READY TWICE IN A ROW WTRDY2 MOVB @CBH01,@CMDREG BL @WTCD10 WTRDY1 DEC R0 JNE WTRDY1 DEC R5 JNE WTRDY 1 Quote Link to comment Share on other sites More sharing options...
Dexter Posted May 28, 2015 Share Posted May 28, 2015 Again the HFCD. It seems very popular. Are there any other mod’s for that controller? (besides those two on whtech?) Does it take any “old” PC 5.25” and/or 3.5”, DD or HD drive, or does work best with a particular drive? I’m not sure where to look for that kind of information. 1 Quote Link to comment Share on other sites More sharing options...
atrax27407 Posted May 28, 2015 Share Posted May 28, 2015 You can make it act ONLY as a hard drive controller with a modified EPROM. Quote Link to comment Share on other sites More sharing options...
+Schmitzi Posted May 28, 2015 Share Posted May 28, 2015 ah, OK. But is there any advantage to disable the floppy-controller (as it supports 80tracks...) ? What could be the reason for HDD-use only ? Act as 2nd HDD-controller ? Quote Link to comment Share on other sites More sharing options...
+mizapf Posted May 28, 2015 Share Posted May 28, 2015 You can make it act ONLY as a hard drive controller with a modified EPROM. From the HFDC manual, page 7: Note – by adding a floppy controller in addition to the HFDC, you can control up to 8 floppy drives. With two controllers the HFDC controls drives 5 through 8. Set up the physical drives that will be used as drives 5 through 8 as if they are drives 1 through 4, cabling them to the HFDC. The HFDC will address them as if they were the higher numbers. If I understood that correctly, it says you can use a separate disk controller for your floppy drives, and only hard drives with the HFDC. One reason could be that some people experienced stability issues with the HFDC and their floppies, or they simply wanted to continue using the disk controller they got used to. 2 Quote Link to comment Share on other sites More sharing options...
sparkdrummer Posted May 28, 2015 Author Share Posted May 28, 2015 ^^^^^^^^ that is correct, I have done it when I had one of my gennys set up. A corcomp controller was used for drives 1-4 and I had 2 80 track drives hooked up to my hfdc. I don't remember any issues. Ralph. 1 Quote Link to comment Share on other sites More sharing options...
atrax27407 Posted May 28, 2015 Share Posted May 28, 2015 I have a BWG Disk Controller for DSK1-3 and RAMdisks from DSK4-D. When I was using a HFDC, it was used as a Hard Disk controller ONLY - it will support two in R/W mode and a third read-only. The EPROM is a direct substitution for the original and just eliminates floppy drive access (courtesy: The Great Gazoo). 1 Quote Link to comment Share on other sites More sharing options...
