McWill LCD VGA out clean install option
cowdog360
I've done two Lynx II's now with the Mcwill LCD. In short, if you don't have it, stop drinking starbucks for a while and send him your spare cash and get it done, it's that good!
On my personal Lynx, I ended up installing the VGA port where the brightness knob goes. It turned out okay, but I'm not a wonderful case cutter, and I'm a little picky. plus, there's not a lot of room to get things in there and the case seems a little tougher to shut.
So for the next one, I had an idea after I saw a little 6-pin PCB header socket in my electronics junk box. I thought, "boy, that looks like it might just be a close fit where the factory contrast knob went. It turns out, it is almost a perfect fit. The height is perfect, but it's about 1mm too wide. You you just have to make a teeeny cut on the lynx case, or on the pin socket.
After that, you'll have to build an adapter cable to have a 6-pin PCB header on one end to VGA on the other.
Here's what I did:
Get pin header, solder up 6 wires.
Hot glue to insulate and make it rigid:
Heatshrink it:
Solder up the VGA connector:
Put a shield on the VGA connector:
Short little adapter cable ready.
And finally, install that socket into the lynx. this is a test fit.
I'll post the final results shortly, but it is super clean and is great if you rarely plan on using the VGA out, but still want the option.
Heh, I did the same thing! I was extremely apprehensive about cutting my Lynx and after digging through my parts bin I found that the pic connectors were the almost-perfect size. I filed the sides of the connector that went in my Lynx and it truly is a snug fit. Plus, it holds the connector to the case without having to use glue or anything.
The heat-shrink looks nice and tidy. I need to resolder my cable and make the connection more robust, though. I've already broken a couple solder joints from casual use. I also marked my cable "TOP" so I didn't accidentally put the cable in upside-down.
Pics here: http://atariage.com/forums/topic/233632-lynx-lcd-replacementvga-out-by-mcwill/?p=3206961
Wow, I like the way you installed the socket better by making the notches instead of the glue. I'll adjust my method for the next one! I think if you reinforce your solder joints with hot glue or epoxy and heat shrink it should be a lot stronger.
Nice work, we should combine the two threads!
