Shadow of the Colossus VCS
ultima
  • 3 weeks later...
  • 3 months later...
  • 2 weeks later...
  • 5 weeks later...
Working for the last week or so on a inventory controller. Also tried coding a Super Chip version but the playfield was taking too much time to draw so it got scrapped for now. The inventory works and is in a test program which you can check out here. The bow is not quite ready yet, sword and agro work but no animation has been added yet
To change inventory object hold fire button for a few seconds and a missile will (magically) appear above the score press left or right to select object then press fire again to activate that item.
post-36052-0-11686300-1447027793_thumb.pnginventory test.bin
I'm not sure if it was the best way to code it but it works and the source might help someone making an RPG or Adventure game.
***Here's an edited version with RT's suggestion
inventory revised.bininventory test revised.bas
Edited by ultima
I glanced at your code and it looks like you might be constantly redoing the playfield data for the whole playfield instead of doing it just one time. Once the playfield is on the screen, you don't have to put playfield data on the screen again until you need to change it.
So instead of something like this:
__Main_Loop
   gosub __PF01
   drawscreen
   goto __Main_Loop
__PF01
   playfield:
   .X.XXXXXXXXXXXXXXXXXXXXXXXXX.X..
   .X.X.XXXXXX.XXXXXXX.XXXXXX.X.X..
   .X.X.XX.XX...XXXXX...XX.XX.X.X..
   .X.X.X...X...XXXXX...X...X.X.X..
   .X.X.X...X...X...X...X...X.X.X..
   ..XXX.XXXXXXXXXXXXXXXXXXX.XXX...
   XXXX.XXXXXXXXXXXXXXXXXXXXX.XXXX.
end
   return
You'd do something like this instead:
   gosub __PF01
__Main_Loop
   drawscreen
   goto __Main_Loop
__PF01
   playfield:
end
   return
  • 1 month later...
  • 2 weeks later...
  • 4 weeks later...
Here is my latest copy while I get cracking on this colossus. As a work in progress (insert large yawn here) it lacks music (though some is written already) and sound fx. no winning condition yet, cant die, collision bugs(dang I forgot to buy Raid) and nothing is polished.
hold fire button down for 4 seconds to activate inventory
reset switch restarts game (not during intro movies)
post-36052-0-75293900-1454800186_thumb.pngpost-36052-0-56656000-1454800210_thumb.pngpost-36052-0-84544800-1454800233_thumb.pngpost-36052-0-57262300-1454800260_thumb.pngpost-36052-0-02647200-1454800282_thumb.pngpost-36052-0-31017900-1454800305_thumb.png
SOTC alpha build XII.bin
Hope to have the first colossus battle done this weekend (we shall see)
  • 5 months later...
Late post but did manage to kill the 16th colossus Malus. Unfortunately till my bB gets up and running again I can't update the collision detection so it's still the "rub the wall and get sucked in" style. Also the score graphics are from sword of iffrit.
