+OLD CS1 Posted June 3, 2015 Share Posted June 3, 2015 I am using a BwG card. Is there a way to get the drive spindle motor running for the 30 seconds necessary to run a proper cleaning kit? Quote Link to comment Share on other sites More sharing options...
+mizapf Posted June 3, 2015 Share Posted June 3, 2015 See http://home.arcor.de/system-ninety-nine-user-group/bwg/bwg_e.pdf page 14, near top of the page. You have to set CRU bit 1 to 1, i.e. LI R12,>1100 SBO 1 If you have a debugger like Bugout, you may have a chance to set CRU bits directly without writing an assembly program. Quote Link to comment Share on other sites More sharing options...
+OLD CS1 Posted June 3, 2015 Author Share Posted June 3, 2015 Can I do that with Easy Bug? Quote Link to comment Share on other sites More sharing options...
+InsaneMultitasker Posted June 3, 2015 Share Posted June 3, 2015 You can try this in Extended BASIC. Change the '10' in line 130 to a higher number to increase the number of attempts. I haven't tested this, so cross your fingers. Essentially, we're just telling the controller to open a file (to spin the drive) and when it errors out, XB traps the error and tries again. 100 ON ERROR 200 110 OPEN #1:"DSK1.NOFILEHERE",INPUT 120 X=X+1 130 IF X<10 THEN 100 140 END 200 RETURN 120 2 Quote Link to comment Share on other sites More sharing options...
Omega-TI Posted June 3, 2015 Share Posted June 3, 2015 I'm truly amazed... in 32+ years there has never been an E/A 5 program to perform that simple task? With all the disintegrating media out there it might be a popular program! Quote Link to comment Share on other sites More sharing options...
+mizapf Posted June 3, 2015 Share Posted June 3, 2015 @Tim: This was my idea shortly after I posted my suggestion. Just keep reading some file. I thought of opening the directory and reading the first record repeatedly, but this makes only sense when there is a valid disk inside, of course. @Omega: 32 years ago we did not have disintegrating media. One reason why there is no such program: See what I did? I looked up the CRU definition in the BwG spec. In other words, there is no common way of turning on the floppy motor (regardless whether every controller indeed uses bit 1) because in the DSR point of view, it is not our business to manipulate those lines. If you wanted to write such a tool you would have to know about all controllers that you want to support. Try this: Go into Extended BASIC CALL INIT CALL LOAD(-24576,2,12,17,0,29,1,4,224,131,196,4,91) CALL LOAD(-31804,160,0) Tell me. (First time I wrote a CALL LOAD program ) Quote Link to comment Share on other sites More sharing options...
Tursi Posted June 5, 2015 Share Posted June 5, 2015 (edited) Bah, just disregard the whole thing. I didn't notice the BWG part. The file access method from XB seems a lot simpler. Edited June 5, 2015 by Tursi Quote Link to comment Share on other sites More sharing options...
+OLD CS1 Posted June 5, 2015 Author Share Posted June 5, 2015 You can try this in Extended BASIC. Change the '10' in line 130 to a higher number to increase the number of attempts. I haven't tested this, so cross your fingers. Essentially, we're just telling the controller to open a file (to spin the drive) and when it errors out, XB traps the error and tries again. 100 ON ERROR 200 110 OPEN #1:"DSK1.NOFILEHERE",INPUT 120 X=X+1 130 IF X<10 THEN 100 140 END 200 RETURN 120 Bah, just disregard the whole thing. I didn't notice the BWG part. The file access method from XB seems a lot simpler. Does the head move during this? If so, what are your thoughts here: I think the problem with moving the head during is that these cleaning disks are at least a little abrasive, and moving the head has the potential to put abrasions across the normal motion of regular disks. As well, since the head essentially makes contact with and drags across the cleaning disk, moving the heads may put undue lateral stress on them and their supports. That is my hypothesis, in any case, and why I would be hesitant to try it. I welcome any comments on this thought. Quote Link to comment Share on other sites More sharing options...
Tursi Posted June 5, 2015 Share Posted June 5, 2015 Does the head move during this? If so, what are your thoughts here: Hmm... I don't know the answer to either of those, and I can't test. I thought on the TI the head would stay on track 0 after it moved there the first time. I'm also not sure about lateral pressure causing potential issues. I used to use those cleaners on the Apple 2, where the head did move, but it wasn't frequent. I used them even less often on my TI, maybe twice. The only part of that concern I personally wouldn't worry about is the abrasiveness, the ones I had were not harder than the wire. (But, who knows what they are like 30 years later, either ). I personally would probably just go for it, but I don't honestly know if the risks you cite are genuine. Quote Link to comment Share on other sites More sharing options...
+Schmitzi Posted September 12, 2015 Share Posted September 12, 2015 Hi, I´ve just found that proggy here in the Triton Spring´86er catalog: MENTOR Maybe somebody has this software ? It´s for spinning the diskdrive for the cleaning-disk.... 1 Quote Link to comment Share on other sites More sharing options...
