Intellfan Posted June 5, 2015 Share Posted June 5, 2015 does tapatalk work with AtariAge anymore? Quote Link to comment Share on other sites More sharing options...
+DZ-Jay Posted June 5, 2015 Share Posted June 5, 2015 No. There was a bug in the forum plug-in that causes posts to be duplicated, and last I heard, Albert disabled the plug-in until it got resolved. @Albert, is this still the case? I miss my Tapatalk. 1 Quote Link to comment Share on other sites More sharing options...
Albert Posted June 5, 2015 Share Posted June 5, 2015 Yes, Tapatalk is broken with the current version of the forum software. To have any hope of fixing it, I need to update the forum software to the current version and then install the current version of the Tapatalk plugin. I tried to upgrade the forum software last Friday, but it spectacularly failed. I will spend some time this weekend setting up a mirror of the site (that's mostly done already), duplicating the upgrade failure, and creating a support ticket so Invision can figure out why the upgrade is failing. Once I have a solution and have successfully upgraded the test site, I will then once again attempt to do the same thing on the live site. After the forum has been successfully upgraded, I will then install and test the Tapatalk plugin to see if it functions properly. I imagine it will work well enough to allow me to keep it enabled. Here's a thread about Tapatalk in the Web Site Comments forum: http://atariage.com/forums/topic/232941-tapatalk-not-working/ ..Al 2 Quote Link to comment Share on other sites More sharing options...
