tacrec Posted June 11, 2015 Share Posted June 11, 2015 Can it export wav and imv at the same time? It would be nice to somehow have sound with the sports games. If I had both files, I can combine them. Quote Link to comment Share on other sites More sharing options...
freewheel Posted June 12, 2015 Share Posted June 12, 2015 I'm actually curious about this, too. I assume there's a way to spit the output into a video file, ie: for Youtube and such. I haven't bothered looking into it as I assumed it was rather trivial, but it seems to come up as a question on a regular basis. Quote Link to comment Share on other sites More sharing options...
intvnut Posted June 13, 2015 Share Posted June 13, 2015 I don't have a way within jzIntv. And I haven't really had the bandwidth lately to work on anything Intellivision. I believe some folks have used generic recorder apps to record jzIntv's output, and that apparently works pretty well. I'd love to grab the audio into the MVI file, and add a mvitompg or similar. I just haven't had the time or energy. I've clocked over 25K lines of code in the last year on my day job project, plus a fair bit of code on LTO Flash!. Only so many bits can flow from these fingers. :-) 1 Quote Link to comment Share on other sites More sharing options...
tacrec Posted June 13, 2015 Author Share Posted June 13, 2015 (edited) You can't push the key to export imv and then push the key to export sound? Would it export the individual files at the same time? Edited June 13, 2015 by tacrec Quote Link to comment Share on other sites More sharing options...
intvnut Posted June 13, 2015 Share Posted June 13, 2015 You can't push the key to export imv and then push the key to export sound? Would it export the individual files at the same time? There's no way to synchronize them, unfortunately. Also, right now, I don't have a key to export sound, only a command-line flag. It was mainly added as a debug tool when I was tweaking the audio code. Quote Link to comment Share on other sites More sharing options...
Kiwi Posted June 13, 2015 Share Posted June 13, 2015 Does bandicam record sounds? I usually use Hypercam 2 by Hyperionics to record desktop. You'll have to enable sound recording before hitting record. Quote Link to comment Share on other sites More sharing options...
tacrec Posted June 15, 2015 Author Share Posted June 15, 2015 So I was able to capture both sound and video at the same time, but due to the converting of the video, the audio is not in sync. What is the default frame rate (fps) of jzintv? Quote Link to comment Share on other sites More sharing options...
intvnut Posted June 15, 2015 Share Posted June 15, 2015 So I was able to capture both sound and video at the same time, but due to the converting of the video, the audio is not in sync. What is the default frame rate (fps) of jzintv? 60 FPS Quote Link to comment Share on other sites More sharing options...
