+arcadeshopper Posted June 8, 2016 Share Posted June 8, 2016 I can put them on the keep when I get home Quote Link to comment Share on other sites More sharing options...
Omega-TI Posted June 8, 2016 Share Posted June 8, 2016 Really the RXB XB AMS TEST program? 10 ! THIS PROGRAM HAS BEEN 11 ! MODIFIED SO NO ASSEMBLY 12 ! IS USED. RXB COMMANDS... Neat program Rich... it works great, or course you already knew that. It's been a fun day, I've had the opportunity to play for most of it, well except for a trip to Staples to pick up a replacement printer... That 'Square Trade' warranty actually paid for itself. All in all an excellent day off! 1 Quote Link to comment Share on other sites More sharing options...
+arcadeshopper Posted June 8, 2016 Share Posted June 8, 2016 (edited) I can put them on the keep when I get home http://web2.thekeep.net/wp for info on how to logon (phone or telnet) File area is TIAMS I put AMSTEST4 and RXBAMS in tifiles format in there and that zip of AMStiopoly Greg Edited June 8, 2016 by arcadeshopper Quote Link to comment Share on other sites More sharing options...
Omega-TI Posted June 9, 2016 Share Posted June 9, 2016 Thanks to Rich, I have the answer to my question in message #49. I decided to post it here in case anyone else was curious as well. CALL AMSINIT CALL INIT SIZE Thanks again Rich! 3 Quote Link to comment Share on other sites More sharing options...
Omega-TI Posted June 15, 2016 Share Posted June 15, 2016 I have a question for you SAMS guru's out there... could something similar to this be modified to use a portion of the extra memory in the card as a RAM DISK? Quote Link to comment Share on other sites More sharing options...
+arcadeshopper Posted June 15, 2016 Share Posted June 15, 2016 I have a question for you SAMS guru's out there... could something similar to this be modified to use a portion of the extra memory in the card as a RAM DISK? should work fine in the SAMS just not any better than a regular 32k card .. 1 Quote Link to comment Share on other sites More sharing options...
Omega-TI Posted June 15, 2016 Share Posted June 15, 2016 should work fine in the SAMS just not any better than a regular 32k card .. Bummer. On a related topic, I was looking forward to seeing some action in the software side of things for this card, then another object came out rather quickly and.... well you know. I wonder how many out-of-the-box ideas & uses this thing is capable of? Quote Link to comment Share on other sites More sharing options...
+Schmitzi Posted January 21, 2017 Share Posted January 21, 2017 just an update AMS/SAMS-List TI-99-4A-HW-SW-SAMS-v1.03b.pdf 2 Quote Link to comment Share on other sites More sharing options...
+arcadeshopper Posted March 4, 2021 Share Posted March 4, 2021 http://quixotic.adamantyr.com/roa.htm 3 Quote Link to comment Share on other sites More sharing options...
+TheBF Posted March 4, 2021 Share Posted March 4, 2021 On 1/21/2017 at 5:25 AM, Schmitzi said: just an update AMS/SAMS-List TI-99-4A-HW-SW-SAMS-v1.03b.pdf 45.86 kB · 45 downloads For what it's worth... Camel99 Forth V2.66 has SAMS support including SAM pages as virtual memory residing in Low RAM. ED99 is a SAMS based editor. 5 1 Quote Link to comment Share on other sites More sharing options...
GDMike Posted March 5, 2021 Share Posted March 5, 2021 (edited) And turbo forth has support. Btw my SNP can't run without it. BUT SNE can. Edited March 5, 2021 by GDMike 2 Quote Link to comment Share on other sites More sharing options...
+jedimatt42 Posted March 5, 2021 Share Posted March 5, 2021 But wait, there's more... I've shared 2 cartridge programs that take advantage of SAMS. And https://github.com/jedimatt42/ti994a-32kmemtest (The path says 32k, but it does more) 4 Quote Link to comment Share on other sites More sharing options...
+retroclouds Posted March 5, 2021 Share Posted March 5, 2021 And don’t forget Stevie. It requires SAMS and the F18a 2 Quote Link to comment Share on other sites More sharing options...
+Ksarul Posted March 5, 2021 Share Posted March 5, 2021 1 hour ago, jedimatt42 said: But wait, there's more... https://github.com/jedimatt42/ti994a-32kmemtest (The path says 32k, but it does more) Yep, I've been using this to test the last few batches of SAMS cards I've built. It works like a charm--and will even detect and test one of my 4M cards. . . 2 1 Quote Link to comment Share on other sites More sharing options...
Asmusr Posted March 5, 2021 Share Posted March 5, 2021 The "Texcaster" is also using SAMS. 4 Quote Link to comment Share on other sites More sharing options...
MikeV Posted March 5, 2021 Share Posted March 5, 2021 On 1/21/2017 at 5:25 AM, Schmitzi said: just an update AMS/SAMS-List TI-99-4A-HW-SW-SAMS-v1.03b.pdf 45.86 kB · 52 downloads Thank you for the list. 1 Quote Link to comment Share on other sites More sharing options...
+Lee Stewart Posted March 5, 2021 Share Posted March 5, 2021 TurboForth supports 1 MiB SAMS. fbForth 2.0 supports up to 32 MiB SAMS. ...lee 5 1 Quote Link to comment Share on other sites More sharing options...
dgrissom Posted September 21, 2021 Share Posted September 21, 2021 On 5/25/2016 at 9:28 PM, arcadeshopper said: had to rename some files to all uppercase to make it work Reference AMSTIOPOLY (SAMS TI Monopoly). (Don't know if this is the best thread for this?) As others have stated, this works fine with Classic 99. (Reading my TIPI as drive T). Not so well on my real "iron".? I just received my first SAMs sidecar (Thanks Greg!). So far, most SAMs programs work fine. (Realms of Antiquity, TEXCASTER, RXB, etc.) However, no luck getting this one to work with my SAMs/TIPI sidecar setup. I've renamed all the files in the directory to UPPERCASE. Deleted extraneous files. I am running ABOOT using E/A 5. Mapped my TIPI.SAMS.AMSTIOPOLY folder to DSK1. I get an "I/O Error code 7". Is this a TIPI file incompatibility? (It wasn't specifically listed on jedimatt's GitHub.) BTW. This is a cool looking version of Monopoly! David G 1 Quote Link to comment Share on other sites More sharing options...
+Ksarul Posted September 21, 2021 Share Posted September 21, 2021 I can't answer for the sidecar version/TIPI combo, but I have played it using a regular disk controller and the PEB card (though not recently, so I should probably play it again just to be sure nothing has changed). 1 Quote Link to comment Share on other sites More sharing options...
+arcadeshopper Posted September 21, 2021 Share Posted September 21, 2021 I am playing it fine on my TI with peb sams and tipi.. So I assume it works fine with the sidecar as well. error 7 is file not found right? I ended up having trouble with the files in the zip because of their filenames (you had to make them uppercase) and also the files themselves, especially aemssys which proved to be difficult in making a good copy on my tipi drive.. something to do with the source file I think. try these AMSTIOPOLY.zip 4 Quote Link to comment Share on other sites More sharing options...
dgrissom Posted September 21, 2021 Share Posted September 21, 2021 54 minutes ago, arcadeshopper said: I am playing it fine on my TI with peb sams and tipi.. So I assume it works fine with the sidecar as well. error 7 is file not found right? I ended up having trouble with the files in the zip because of their filenames (you had to make them uppercase) and also the files themselves, especially aemssys which proved to be difficult in making a good copy on my tipi drive.. something to do with the source file I think. try these AMSTIOPOLY.zip 32.66 kB · 2 downloads It looks like I was missing ASHOE in my version. I remember seeing it in the original .zip. Most likely a user error during/after capitalizing the filenames and cleaning the extra files. Your copy did the trick! ? Looks good! DGrissom 5 Quote Link to comment Share on other sites More sharing options...
jrhodes Posted September 23, 2021 Share Posted September 23, 2021 On 9/21/2021 at 2:24 PM, arcadeshopper said: I am playing it fine on my TI with peb sams and tipi.. So I assume it works fine with the sidecar as well. error 7 is file not found right? I ended up having trouble with the files in the zip because of their filenames (you had to make them uppercase) and also the files themselves, especially aemssys which proved to be difficult in making a good copy on my tipi drive.. something to do with the source file I think. try these AMSTIOPOLY.zip 32.66 kB · 12 downloads This looks like a really good game! Is there a manual for it? How do i cancel a selection, say for selling a property or building, and go back to the main turn-menu? Quote Link to comment Share on other sites More sharing options...
+arcadeshopper Posted September 23, 2021 Share Posted September 23, 2021 33 minutes ago, jrhodes said: This looks like a really good game! Is there a manual for it? How do i cancel a selection, say for selling a property or building, and go back to the main turn-menu? https://pixelpedant.com/items/show/243 1 Quote Link to comment Share on other sites More sharing options...
jrhodes Posted September 24, 2021 Share Posted September 24, 2021 That manual is for a different game(ti99-opoly), as it talks about being able to save your game, and player name entry, both features that don't appear to be in the game you uploaded. The game you supplied in the zip file appears to be called tinopoly. I did figure out the answer i was looking for though: fctn+9(back) to cancel an action and return to the menu to pick something else to do this turn. Also, you can cycle through your properties owned with the arrow keys(e&x). 2 Quote Link to comment Share on other sites More sharing options...
dgrissom Posted September 24, 2021 Share Posted September 24, 2021 7 hours ago, jrhodes said: That manual is for a different game(ti99-opoly), as it talks about being able to save your game, and player name entry, both features that don't appear to be in the game you uploaded. The game you supplied in the zip file appears to be called tinopoly. I did figure out the answer i was looking for though: fctn+9(back) to cancel an action and return to the menu to pick something else to do this turn. Also, you can cycle through your properties owned with the arrow keys(e&x). Thanks for the update on the keystroke. I encountered the same thing during testing. This is actually a very good version (at least in my testing so far.) I would like (maybe I'll put this together) a pdf with full game instructions, a full board map as my memory is a bit sketchy, and game play tracking sheets for properties, etc. This game would be great for a small gaming party! 4 Quote Link to comment Share on other sites More sharing options...
