RSS Bot Posted June 19, 2015 Share Posted June 19, 2015 After looking around for quite some time i found that shelves did not exist for a console setup that I wanted. The wall is shaped like so: C ***************************************** B ** A ** ** ********************** For the past week I have designed shelves that will work and fit to individual consoles Section A will hold 12 of the smaller consoles. B will contain the switch boxes for the consoles C will have room for 24 larger consoles. This is the list of consoles and av best outputs without modding.(correct me if i'm wrong) On the far right side are the consoles i currently own and do not Gray=not compatible Green=best output yellow=other outputs red=no av output I believe the largest is the Atari 5200(again,correct me if i'm wrong) Attached thumbnail(s) http://atariage.com/forums/blog/609/entry-12098-a-setup-change/ Link to comment Share on other sites More sharing options...
