Mr SQL Posted August 2, 2015 Share Posted August 2, 2015 Yes I agree, but I'll have to do some research on setting up a better test. Perhaps something like the test I posted but a version that loads and copies only to DRAM? I'm not sure on the Tandy but would I need to lower RAMTOP (or the ECB equivalent) and then do reads and writes to the DRAM above this for a baseline? Of course the Basic prg would still be in slower DRAM. Yogi If you're writing to the cart ROM area, I think you can do this at double speed with the 65495 poke even though you've got RAM there instead of ROM; the bottom 32K of CoCo RAM can be overclocked as well with poke 65497,0 and poke 65496,0 to turn it back off. These pokes double both ROM and RAM access, but SAM cannot keep up and the 6847 will display the Matrix for whatever duration you are over clocked. Quote Link to comment Share on other sites More sharing options...
JamesD Posted August 2, 2015 Share Posted August 2, 2015 Yes I agree, but I'll have to do some research on setting up a better test. Perhaps something like the test I posted but a version that loads and copies only to DRAM? I'm not sure on the Tandy but would I need to lower RAMTOP (or the ECB equivalent) and then do reads and writes to the DRAM above this for a baseline? Of course the Basic prg would still be in slower DRAM. Yogi I'm wondering how much patching the BASIC ROM to move the Direct Page to this RAM would speed up execution over the standard double speed POKE. You can disable internal address decoding so BASIC could be copied to RAM and patched. Quote Link to comment Share on other sites More sharing options...
Van Posted August 3, 2015 Author Share Posted August 3, 2015 Hi MrSQL If you're writing to the cart ROM area, I think you can do this at double speed with the 65495 poke even though you've got RAM there instead of ROM; the bottom 32K of CoCo RAM can be overclocked as well with poke 65497,0 and poke 65496,0 to turn it back off. These pokes double both ROM and RAM access, but SAM cannot keep up and the 6847 will display the Matrix for whatever duration you are over clocked. Well so far haven't had any issues accessing this extended SRAM in the split speed mode. Just trying to pin down the speed advantages. @ JamesD I'm wondering how much patching the BASIC ROM to move the Direct Page to this RAM would speed up execution over the standard double speed POKE.You can disable internal address decoding so BASIC could be copied to RAM and patched. Interesting idea, somewhat like how the CoCo3's Basic is patched(?).Was/is there any hardware that used /SLENB? I've only seen it described briefly with no detail as to how it affects the system. So far I haven't seen too great a speed up between DRAM and SRAM with just testing R/W accesses. This afternoon I ran tests comparing the same code accessing DRAM and SRAM at normal and Split-Speed. The prg writes 256 bytes to mem, then does a block move loop of this page. As expected both runs, one using DRAM and the other SRAM, at default speed were within a second or two of each other for 200 passes of the loop. Using the Speed poke, the results were of course faster but the difference between DRAM access and SRAM for 200 passes only showed to be ~10sec.But keep in mind the 200 passes represent 51200 Peek/Poke pairs executed on the RAM. 200 page moves @ Default speed: to $3E80 10:46 to $C000 10:43 200 page moves @ Split-Speed: to $3E80 7:47 to $C000 7:36 So the major speed differences in the above tests are the Basic function running faster, and the differences between the DRAM access and SRAM access times is minor overall. My conclusion is the real speed up will be seen when running code from the SRAM. Now to work out a ML routine to test with. Yogi 1 Quote Link to comment Share on other sites More sharing options...
JamesD Posted August 5, 2015 Share Posted August 5, 2015 (edited) Ok, to speed up BASIC, we can try moving the direct page and the stack to the new SRAM. Other BASIC settings could be altered so the former stack space could be used for variables and even variables might be moved to SRAM but I don't know what to change to do that. This code hasn't even been assembled let alone tested but it will give you an idea of how the direct page and stack could be moved to SRAM. I haven't coded for the 6809 in a long time so no promises the syntax of functionality is correct. ; copy direct page and system stack to SRAM expansion ORG $3f00 DI ; disable interrupts ; save the content of registers STD tempd STY tempy STX tempx ; copy content of direct page to new location LDX #$0000 LDY #$e000 LDB #$ff cpy1: LDA ,x+ STA ,y+ DEC b BNE cpy1 LDA $e0 TFR a,dp ; set the DP register ; move system stack to new RAM STS tempp ; save the stack pointer LDD #$7fff ; top of stack space ; get stack size SBCB tempp+1 ; subtract stack pointer SBCA tempp STD temps ; save stack size LDD #$feff ; top of RAM -256 ; get new stack pointer SBCB temps+1 SBCA temps STD tempp ;new stack pointer LDY tempp ; destination address TSX ; get the current stack pointer as source cpy2: LDA ,x+ STA ,y+ CMPX #$8000 ; top of BASIC stack? BNE cpy2: LDS tempp ; set new stack pointer ; restore the content of registers LDD tempd LDY tempy LDX tempx EI ; enable interrupts RTS ;exit tempd fdb 0 tempx fdb 0 tempy fdb 0 temps fdb 0 tempp fdb 0 end *edit*We could also move the disk buffers to SRAM to free up more space for BASIC. Edited August 5, 2015 by JamesD 1 Quote Link to comment Share on other sites More sharing options...
JamesD Posted August 5, 2015 Share Posted August 5, 2015 (edited) There may be a couple 6502 opcodes in there. Du-oh! *edit* Remove the DI and EI and replace them with these: ORCC #%01010000 ; disable interrupts ANDCC #%10101111 ; enable interrupts Edited August 5, 2015 by JamesD Quote Link to comment Share on other sites More sharing options...
JamesD Posted August 5, 2015 Share Posted August 5, 2015 (edited) I'm looking at the direct page pointers that would need to be modified.0021, 0023, 0027, 0074 and that's just what I've found so far.*edit*0021, top of stack may be the only one that needs changed but the other variables point higher than the stack so I don't know what BASIC will do if 0021 is a higher number than the others.Insert this code before moving the direct page? LDD #$fefe ; top of RAM -256 -1 STD $21 ; tell BASIC where the new top of stack is. Edited August 5, 2015 by JamesD Quote Link to comment Share on other sites More sharing options...
JamesD Posted August 5, 2015 Share Posted August 5, 2015 (edited) So something like this: ; copy direct page and system stack to SRAM expansion ORG $3f00 ORCC #%01010000 ; disable interrupts ; save the content of registers STD tempd STY tempy STX tempx ; move system stack to new RAM STS tempp ; save the stack pointer LDD #$7fff ; top of stack space ; get stack size SBCB tempp+1 ; subtract stack pointer SBCA tempp STD temps ; save stack size LDD #$fefe ; top of RAM -256 -1 STD $21 ; tell BASIC where the new top of stack is. ; get new stack pointer SBCB temps+1 SBCA temps STD tempp ;new stack pointer LDY tempp ; destination address TSX ; get the current stack pointer as source cpy2: LDA ,x+ STA ,y+ CMPX #$8000 ; top of BASIC stack? BNE cpy2: LDS tempp ; set new stack pointer ; copy content of direct page to new location LDX #$0000 LDY #$e000 LDB #$ff cpy1: LDA ,x+ STA ,y+ DEC b BNE cpy1 LDA $e0 TFR a,dp ; set the DP register ; restore the content of registers LDD tempd LDY tempy LDX tempx ; set zero page info for stack LDD #$ STD $21 ANDCC #%10101111 ; enable interrupts RTS ;exit tempd fdb 0 tempx fdb 0 tempy fdb 0 temps fdb 0 tempp fdb 0 end Edited August 5, 2015 by JamesD Quote Link to comment Share on other sites More sharing options...
Van Posted August 5, 2015 Author Share Posted August 5, 2015 Thanks JamesD. I'll dig into this, I find that reading source code is the best way for me to learn So far I haven't looked too hard at ECB's mem map so this is a very good entry point for me. Yogi Quote Link to comment Share on other sites More sharing options...
JamesD Posted August 6, 2015 Share Posted August 6, 2015 Thanks JamesD. I'll dig into this, I find that reading source code is the best way for me to learn So far I haven't looked too hard at ECB's mem map so this is a very good entry point for me. Yogi This might be of some use to you http://www.lomont.org/Software/Misc/CoCo/Lomont_CoCoHardware.pdf Quote Link to comment Share on other sites More sharing options...
Van Posted August 6, 2015 Author Share Posted August 6, 2015 This might be of some use to you http://www.lomont.org/Software/Misc/CoCo/Lomont_CoCoHardware.pdf Thanks, Yes A+ on that doc. I've had a local copy here for a few weeks as a goto ref. But up to now have been focused on HW issues mainly. Also got a copy of "500 Peeks, Pokes and Execs" (think that's the title) that I've skimmed thru a bit. Wish there was a "Compute's First( Second, Third...) book of the Tandy", read the Atari ones cover to cover many times BITD Yogi Quote Link to comment Share on other sites More sharing options...
JamesD Posted August 14, 2015 Share Posted August 14, 2015 ... ; set zero page info for stack LDD #$ STD $21 ... That part should be deleted. Quote Link to comment Share on other sites More sharing options...
JamesD Posted August 14, 2015 Share Posted August 14, 2015 (edited) So, I'm looking at the Extended Color Basic Unraveled book and it appears to be different than Lamont's book.Patching BASIC to move the DP register would be pretty simple since the DP register is only set in one location... which is different by basic version. Just replace a line of code with a JSR to the address where the hidden MICROSOFT string is at the end of the SIN() table and put the replacement code there with an RTS at the end.The code needed to modify the location of variables and the stack is easy enough, it's all set in one spot. I might need to dump the memory test and assume it's a 64K CoCo or shorten the memory test. But I haven't found where BASIC checks to see if the program has run out of space for lines yet. Edited August 14, 2015 by JamesD Quote Link to comment Share on other sites More sharing options...
JamesD Posted September 11, 2015 Share Posted September 11, 2015 Code to move the direct page to cart RAM. I'll have to build a BASIC program that loads this before I can test it on the RAM cart. Maybe a combination of Ahl's benchmark and this so I can benchmark before and after. ; copy direct page and system stack to SRAM expansion ORG $3f00 3F00 1A 50 ORCC #%01010000 ; disable interrupts ; save the content of registers ; we can get away with using the stack because the content ; of the stack will be moved as will the pointer 3F02 34 36 pshs a,b,x,y ; copy content of direct page to new location 3F04 8E 0000 LDX #$0000 3F07 108E E000 LDY #$e000 3F0B C6 FF LDB #$ff cpy1 3F0D A6 80 LDA ,x+ 3F0F A7 A0 STA ,y+ 3F11 5A DECB 3F12 24 F9 BCC cpy1 3F14 96 E0 LDA $e0 3F16 1F 8B TFR a,dp ; set the DP register ; restore the content of registers 3F18 35 36 puls y,x,b,a 3F1A 39 RTS ;exit {$0000} end [No Errors] Quote Link to comment Share on other sites More sharing options...
Van Posted September 11, 2015 Author Share Posted September 11, 2015 Too Cool! I've been kind of quite lately, been setting up a tool chain. So I'll test assemble this to make sure my setup is working Yogi Quote Link to comment Share on other sites More sharing options...
JamesD Posted September 12, 2015 Share Posted September 12, 2015 Too Cool! I've been kind of quite lately, been setting up a tool chain. So I'll test assemble this to make sure my setup is working Yogi I assembled it with ccasm but I didn't use any features unique to that assembler. Quote Link to comment Share on other sites More sharing options...
Van Posted September 12, 2015 Author Share Posted September 12, 2015 I assembled it with ccasm but I didn't use any features unique to that assembler. OK. I thought that I would try out some of the asm options in RainbowIDE to get a feel for it. I installed the trial ver, guessing that the nag screen is the only limit ( no time limit was mentioned). If Rainbow is limited/ unuseable will revert back to Notepad++ and CLI tools. Kind of used to this setup for 6502 and PIC stuff Yogi Quote Link to comment Share on other sites More sharing options...
JamesD Posted September 12, 2015 Share Posted September 12, 2015 OK. I thought that I would try out some of the asm options in RainbowIDE to get a feel for it. I installed the trial ver, guessing that the nag screen is the only limit ( no time limit was mentioned). If Rainbow is limited/ unuseable will revert back to Notepad++ and CLI tools. Kind of used to this setup for 6502 and PIC stuff Yogi I tried using the RainbowIDE years ago. Even paid for it. There were some annoying bugs that never got fixed and then suddenly the author announced a new IDE and the problems I was having never got fixed. I use Notepad++ and CLI tools now. Quote Link to comment Share on other sites More sharing options...
Van Posted September 13, 2015 Author Share Posted September 13, 2015 I tried using the RainbowIDE years ago. Even paid for it. There were some annoying bugs that never got fixed and then suddenly the author announced a new IDE and the problems I was having never got fixed. I use Notepad++ and CLI tools now. Oh well. Gotten used to NP++ and the NP Exec plug simplifies the build but was hoping for a more integrated setup. 'Grass is always greener' syndrome I guess Messed around with JAC!'s plugin for Eclipse but without extending the coding it doesn't seem like there is an easy way (NP++ style) to add a 6809 assembler ( there's kind of a kluge way to re-direct the build, it seems). His plugin is a quite nice 6502 environment with lots of options, so the next Atari or C= thing I jump into, will use it. Yogi Quote Link to comment Share on other sites More sharing options...
JamesD Posted September 13, 2015 Share Posted September 13, 2015 FWIW, the Rainbow IDE editor seemed to work fine. It was the build function that gave me issues. Quote Link to comment Share on other sites More sharing options...
